Tennis Elbow
Tennis Elbow
So I've been off the bike for almost a week now. Got bad tennis elbow. Doc said I need to give it time to heal. Apparently, pulling the brake lever is the exact angle that really enflames it. Anybody else have to deal with this? Any tips to get it to heal and get back on the bike?
RICE - Rest, Ice, Compression, Elevation.
I’ve also had it, although not from riding and did have any issues riding through it.
Using one of those compression bands below the elbow allowed me to still do the activities that usually aggravated it and otherwise would have been painful.
Tennis elbow, or rather lateral epicondylitis, is an inflamation of the extensor tendons of the wrist and hand, the extensor carpi radialis brevis . If you have inflammed these tisses during use, you must rest them for recovery. Some lateral epicondyle bands can help and take tension off these tissues. You can also take the anti-inflammatories of your choice consistently to reduce symptoms. Of course, reduce the activity that caused this issue is also key. This can take a while to resolve.Elevation has nothing to do with this. It's not a swollen ankle.
Likes For Jicafold:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
Quoted: 601 Post(s)
Liked 781 Times
Dont brake
Seriously most of us can learn to ride and turn at higher speeds.
Likes For joesch:
Quoted: 501 Post(s)
Liked 633 Times
Played over 20 years of tennnis, including competively and college and never had an elbow injury (or any other) from it. Fast forward a couple of decades and I got it shaking a thermometer to get a wet bulb temp, GO FIGURE! I aggravated it by banging it into a couple of things, short story, it took almost 8 months of avoiding the motion(s) that aggravate it, and rest (and not opening jars) sucks getting old!...
Quoted: 2604 Post(s)
Liked 1,933 Times
My "tennis elbow" times come when I unconsciously lock my elbows while riding. My fix is to change my body angle (lean over more), vary grip and torso position every 5-10 minutes, and (not surprisingly) don't lock my elbows.
BTW, it's possible to bend your elbows and lean forward even on straight bars -- it just takes a little bit more thought.
Quoted: 18422 Post(s)
Liked 15,571 Times
Likes For indyfabz:
Quoted: 601 Post(s)
Liked 781 Times
Not a trick question as a bike can steer without a rider and ofcourse requires counter turning Also a bike has no need for brakes or pedals as it slows down or speeds up on depending on the terrain.
Quoted: 8285 Post(s)
Liked 9,054 Times
Brake mechanic I worked with got it in both arms. He had to take 6 months off work and the PT put him on a weight lifting regimen of moderate weight and reps.
I think tendonitis can be addressed with warming up slowly and allowing the muscles to get "loose" before doing whatever is aggravating the tendons.
Doc wants 2 weeks of rest and anti-inflammatories. Crap, was just getting to the point where I was back in the fast group. Injuries suck.
Bikes: Specialized Allez Sprint Comp
Quoted: 32 Post(s)
Liked 408 Times
I got it playing tennis (odd, right?)
Rest, ice, heat, stretches, strengthening exercises. Yes, heat: flush the tissues. They are low-blood content and flow tissues, so they need a little help. Don’t cook them, but take a hot bath and soak the elbow. Follow up with ice.
Liked 9,054 Times
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1099 Post(s)
Liked 3,757 Times
Every one/case is different so YMMV but, I had a really bad case from repetitive motions at work. I did rest, bands, heat, physical therapy not much luck (for months). Switched physical therapists, in the first five minutes he said,"The problem is your shoulder is weak, so your elbow is doing all the work" Now instead of focusing on treating the elbow, we focused on strengthening the shoulder, elbow problem went away quickly. Like many things, better results treating the cause, than the symptom. Tough part is always finding the right person to identify the cause?
Quoted: 3955 Post(s)
Liked 7,303 Times
Having had elbow tendonitis many times, I'd say a two week recovery with OTC anti-inflammatories is pretty optimistic. If you want faster results, try Voltaren, iontophoresis, PRP, or a cortisone injection.
Yea, it's 2 weeks with OTC anti-inflammatories, then we go to a steroid injection. They prefer to use the injection sparingly if possible.
Liked 7,303 Times
You don't want to do cortisone injections in the same joint on a regular basis, but if you haven't had one recently, I'd jump straight to it.
The injection doesn't go into the joint. It goes outside the joint where the muscle anchors at the lateral epicondyle. Still, there are always side effects such as atrophy and depigmentation.
Liked 7,303 Times
As an update, I got turned onto Voltaren by a buddy. It seems to be working really well so far. It's making living with this much easier. I actually was able to ride Sat and Sun using the arm band.
In orthopedic surgery, where I work, in the joint means, exactly that. Directly into the joint itself. The condition of the OP, lateral epicondylitis, is not in the joint. It is extra-articular. Saying "into the joint" in a lay forum is misleading. What you are referring to is laterality.
Excellent. Good for you. Voltaren is a bit more potent than ibuprofen or naproxen. It may have more side effects though....headaches, diarrhea, dizzyness...
Liked 7,303 Times
Liked 7,303 Times
