“Golden Anniversary Ride” bike: 1974 Falcon
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
I think I mentioned earlier that in 1974, my friends and I all turned 18 and bought “decent” bikes; with next year being the 50th anniversary of that, I am restoring three of those bikes for my friends and plan some kind of celebratory ride for the four of us. Now that the weather is far less riding-friendly and I am indoors, it time to start.
First up is this 1974 Falcon. There are few things about identifying the bike a bit problematic, despite it being a one-owner bike. The shop where he bought it, well, I worked there that year for about 6 months that year, and all of the Falcons sold there were built up from bare frames with components chosen by the buyer and the staff — no two alike. And, I cannot claim to have the entire line-up memorized anyway. That other Falcon I did earlier this year, also 1974 and also from a childhood friend, had a nice spec with 531 butted tubes and Campy dropouts, and no chrome at all. This one has no-name dropouts (but they look “forged” to me and have an integral RD hanger) but the fork is chromed, as are the head lugs — and nowhere else. No clue which model. And, there’s a lot to clean up, it’s been hanging in a garage a long time.
Mish-mash of components: SR cranks, Campy NR derailleurs, Suntour barcons (I think I sold them to the owner later, after I tired of them), Fiamme bars and stem, Weinmann centerpulls, Brooks Pro saddle on a straight steel post (!) The wheels are plain Normandys and 27” steel rims, he and I seem to recall he quickly decided to ditch the tubulars and these were the only wheels I had hanging around in my basement at the time.
Mostly it needs rehab, all cleaned/polished/lubed/assembled. The wheels go away, as I have a spare set of 700C alloys with Campy hubs to donate; and that gas-pipe seat post must go (my micrometer suggests 26.4mm despite being quite out-of-round, does that sound right?)
It took much of the day to break it down to the last nut-bolt-and-washer. Hey, I found I had one of those Campy pedal cap wrenches! And, oddly, the front brake had 10mm pivot bolts, and the rears were 11mm? Of course the “most fun” were getting the springs disengaged on the derailleurs and calipers, and I am sure to be cursing when the time for reassembling them comes around. Regardless, it is time to break out the new ultrasonic cleaner for the first time; my plan is Simple Green XD (straight, or a solution?) and how long is a reasonable “session” in the machine for each batch (I expect to treat each component’s parts separately so I do not mix up the parts).
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Quoted: 3814 Post(s)
Liked 3,345 Times
this model three-tube 531 plain gauge
expect you would discover a pillar size of either 26.2mm or 26.4mm
dropouts appear to be either Campag Sport 1010/1 or the the Agrati replica thereof
since you have satisfied yourself that they are unmarked that would indicate the Agrati version
both have the small hole to accommodate the spring of the Campag Sport model gear mech
due to lugs am thinking frame earlier than stated date
do not wish to question that it may have been purchased new in 1974 but it appears to come from a slightly earlier time
a bit odd that dropouts exhibit eyelets while fork ends do not
fork ends appear to be true forged as a raised area around track nut can be seen...or this may be just a washer...
this usually makes one suspect a fork replacement
crown appears to be Vagner model DL
Ernest could be quite eclectic when it came to selecting bits for his frame construction at any given moment in time so it is best not to place too much weight on catalogue representations...
Likes For juvela:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
For the calipers, overhaul one at a time and use a small screwdriver to pry the spring back in place. Take pics along the way if necessary.
Likes For SurferRosa:
Quoted: 987 Post(s)
Liked 641 Times
Instead of photos, I have another bike sitting here with NR derailleurs and Weinmann brakes as a reference.
Quoted: 3464 Post(s)
Liked 2,831 Times
Falcon was a small enough mfg that buying a smattering of frame sets of varying build dates does not surprise.
looks like a reasonable bike.
review the old seat post for scraping that might indicate where tight spot(s) might be.
Likes For repechage:
Liked 3,345 Times
forgot to mention above -
there is a good assemblage of early seventies Falcon paper here -
https://velo-pages.com/main.php?g2_itemId=26656
the nineteen seventy-four catalogue -
https://velo-pages.com/main.php?g2_itemId=27334
advisory: looking at Falcon paper can sometimes raise more questions than it solves...
Ernest also went on to fabricate cycles under his own name a few years later
Quoted: 939 Post(s)
Liked 2,946 Times
I went through similar machinations trying to identify the Falcon I bought a few years back. With the help of the VCC marque enthusiast (he can be found on cyclechat under the username mandobob) the closest possibility we got to is a San Remo Mk II, possibly late 60's - early 70's. The rounded seat stay treatment at the cluster and the larger seat tube diameter are clues. Mine very closely resembles this: https://velo-pages.com/main.php?g2_itemId=27461 with the exception of the chromed lugs and that seat stay treatment.
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
The replacement fork looks to be the American market version of the top model San Remo 76. Most of them in the UK had the Davis style Fork Crown but the US had these. I’m looking for a fork just like it for my San Remo 76, now I’m jealous!
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
The bike is interesting in that it is the only non-Raleigh/Carlton that I have seen with that early-'60's design of wrap-around seat stays. The chain-rings look to have some life left in them. How does the freewheel look?
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Likes For 1989Pre:
Liked 3,345 Times
me local Falcon stockist in California at this time had the model 76 exhibiting the Davis crown so perhaps both types were exported to the U.S.
variation may have been due to Don Ernesto using what he could get given the conditions of the boom (wylde speculation)
as recalled, the model 76 was only available in the team/house colour of powder blue at this epoch
can make no claim to Falcon expertise
Quoted: 987 Post(s)
Liked 641 Times
Both of the "1974" Falcons currently at my house have the wraparounds. Thanks for the input on the chainrings, I'm trying to save my friends some money. Freewheel goes in the trash.
Liked 3,345 Times
been meaning to inquire regarding the cycle's stem
from what can be seen in photo it appears it might be a FIAMME
be this correct? if not, does it show any markings?
thank you!
thank you!
Quoted: 987 Post(s)
Liked 641 Times
Hmm, I have no interest in, or sue for, the wheels that I am removing -- Normandy high flange hubs but 27" steel rims. I wonder if, once cleaned up, a bike co-op would find a use for them? To save a bike with damaged wheels, I guess they are better than nothing (barely!)
Quoted: 987 Post(s)
Liked 641 Times
Update: Photo of some components after not only cleaning, polishing and coating, but reassembly (finally!) Actually, parts from all three of the winter projects: Falcon, Legnano and Falcon (but I wasn't planning on posting the same photo three times).
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Liked 3,345 Times
he has made mention previous of Wolfgangs
Likes For juvela:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
w00t!
There were 135 Confentes, but only one...Huffente!
Quoted: 987 Post(s)
Liked 641 Times
Correct. That said, I wonder if a good coat of car wax would also work well. So far on my bikes, I am pleased at how the components retain their shine over time -- but, then again, I am a fair-weather rider, no rain or mud; I would be curious what, for instance, PNW riders experience.
I finally looked up the meaning of that. Thanks.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
My 1971 American Eagle (Nishiki) Semi-Pro (Competition) had wrap-around seat stays.
Quoted: 987 Post(s)
Liked 641 Times
Started on reassembly of the Falcon today. First item was, of course the headset. I had previously bought a headset race press to push the races into the frame’s head tubes and, on at least one bike, it’s too short for long head tubes as those are rarely seen on modern bikes. The Falcon proved the same, so I resorted to the Old Method — a rubber mallet and patience. Not too bad. Unlike the Peugeot, this one has loose bearings instead of caged — unusual for a Campy in my experience. I had been very careful during disassembly, and had 23 for the top and 23 for the bottom and once in fresh grease, it seemed like a lot of space left over. I did research online plus my 1974 Sutherland’s shop manual, and it says 3/16” bearings on Campy, and 20 to 22 balls. Also, the by-eye method is jam is as many as will fit, then remove two so the headset will not bind up while turning. So I needed a couple more and I fortunately have bags of each possible size. Checking with my micrometer, the bearings are… 5/32"? Huh? That’s common on non-Campy but the races clearly say Campagnolo, so this must be some version one normally does not see. Regardless, in place now and smooth as silk; final adjustment can wait until towards the end of the project, and I included the brake cable hanger in the “stack” anyway.
Bars and stem were next, and on all three bikes I am setting the stem at the maximum marked “safe” height, just to make the bikes easier to ride. Brake levers went on, they are the tiniest bit bent left/right, but I suspect not enough to notice upon casual inspection, or while riding.
To install the bar tape — wait a minute! Glad I remembered…. This bike has handlebar-end shifters! So, those are in place, and that meant the upper sections of cable housing and it helps to install the housing stop on the downtube to help hold it all there. Now the tape is on, again over the Fizik brand gel pads. The combination of the thick cushion tape and the gel pads makes the bar look a bit “fat” but I’ll bet the reduction in shock to the arms will pay off while riding. And the bar end shifters feel a bit gritty in actuation; I just now got some guidance from the forum, and feel confident I can slide the ratchet mechanisms out and clean/lube them, hopefully that helps.
The wheels need to come back off briefly, as I forgot to polish up the hubs and spoke for additional sparkle. Also, on both the Falcon and the Peugeot at this point, I am going to apply the “ceramic coating”, basically a wax but better, that I started using on both cars and the gloss is great with that stuff and should help protect the bike. I think so far, it looks pretty good. The tire “look right” — there is room that I possibly could have installed fatter 30mm ones (available in black only ☹️) but that’s probably not a lot of difference in ride, and might have looked odd.
Quoted: 987 Post(s)
Liked 641 Times
OK, the bike is “assembled” now, really only still needing a water bottle and cage; that said, I need to go over the bike 100% (and then some) making sure every bolt is tight and correctly adjusted. In particular, the headset is just finger tight. After that, it needs at least two shakedown rides with tightness checks in between.
Sadly, the batteries in my household scale have died, so I cannot give even a ballpark weight. Nice enough components but it is straight-gauge tubing, and a 25” frame as well. Probably approaching 25 pounds? Then again, that might be pessimistic.
A couple of things:
(a) No surprise but going from 27” wheels to 700C means brake reach is affected and even in the bottom position, not QUITE enough reach. Therefore, a little grinding of the caliper is in order; sure, it would stop right now, but how many stops until tire blows? And there are tire savers installed and getting the brake perfectly centered and tight while preventing the tire savers from doing Rock Around the Clock is not easy — at least on the rear; on the front the center bolt was long enough for two NyLock nuts (M6 x1mm, by the way, cheap from Amazon in stainless in packs), one of which holds the brake and the second for the tire saver.
(b) First time dealing with barcons in so many decades. After the rebuild the SunTour shifters seem to work really well — but the cable routing strikes me as really inelegant, I have a clip holding the cables together below the handlebars, and I still need a zip-tie directly above the housing stop on the downtube to keep the cables from drooping. Moreover, the shift cable housing comes rather close to the front brake’s straddle cable assembly. Is there a fix?
(c) there is also a zip tie on the chain stay just aft of the housing stop for the rear derailleur. The ‘modern’ housing is a bit stiffer than I am used to and wants to exit the stop at an angle. I am hoping it settles into its new shape and the zip tie becomes superfluous. Or — last year member “oneclick” made up some special ferrules that fit my Raleigh project perfectly for this exact reason, I think I still have one or more in my “cables and small parts” box.
A couple of things:
