Wolber TX Profil wheelset w/ Specialized hubs
Quoted: 535 Post(s)
Liked 346 Times
700c
126mm rear
32 spoke
Rim inner width: 14.25mm
Rim outer width: 19mm
Spokes are 2.00mm DT Swiss straight gauge
Wheelset spins nicely and appears true and round.
Brake wear is even along rims, and very minimal. This is a low mileage wheelset.
Note: Rear skewer is ever so slightly bent at its threaded end but still functions fine.
Note: After taking photos, I noticed a blemish on the front rim. I determined it to be a light colored over spray. I've indicated it in an additional photo for clarity. The good news is that I was easily able to remove it with some light elbow grease.
Will ship to CONUS only via shipbikes dot com which should run between $21 to $36 for standard insured no signiture required delivery.
You may request higher insured signiture required delivery option for an additional $4.80 if you wish.
$70 plus actual shipping SOLD LOCALLY
PayPal only. Friends and family preferred, or add 3% for Goods and Services.
126mm rear
32 spoke
Likes For deux jambes:
Quoted: 535 Post(s)
Liked 346 Times
This is the once blemished spot previously mentioned. Its been rubbed out since taking the photo and is now clean as it should be.
Quoted: 5888 Post(s)
Liked 3,471 Times
Those are cartridge bearing hubs. They are excellent hubs. I rode a set across the US in '97 and they are still very serviceable. I really should rebuild them one of these days but they turn smoothly.
Likes For bikemig:
Quoted: 535 Post(s)
Liked 346 Times
Liked 3,471 Times
It's not hard to double check. If you unscrew the locknut, you'll see if it is a cartridge or cup and cone. I built a few wheels with these BITD as they are just terrific hubs and to my eye, these look like the cartridge bearing hubs.
We used to grab them at the shop and remove the axles and respace them for the BMX bikes. They weren't Phil's but the were excellent sealed bearing hubs. I picked up a pair last year NOS just to have for that very reason.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
Quoted: 1639 Post(s)
Liked 829 Times
Those Wolber rims should be really good . I built a wheelset using similar Wolber Profil 20 rims and they turned out the be the strongest, stiffest C&V wheelset I have so far, even at just 28 H spoking. Never even had to re-true them yet, after building and riding them some years ago.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
