buzz bar???
buzz bar???
Old 01-04-08, 12:57 AM
mike-on-da-bike
buzz bar???
i have read a few post where guys have taken some solder off the buzz bar on the controllers to get some more amps flowing but no diagrams,what is this buzz bar they talk about?i need just a few more amps to flow
mike-on-da-bike is offline
Old 01-04-08, 01:31 AM
karma
karma's Avatar
Liked 6 Times in 3 Posts
its called a shunt resister. you add a little solder to it to up the amps on the hubmotor. but if your not careful you can damage the fets in the controller under load.
as you can see in the pic i allready added solder to the end it works.
https://www.rc-electronics-usa.com/current-shunt.html
cheers
File Type: jpg
File Type: jpg
karma is offline
Old 01-04-08, 11:29 PM
mike-on-da-bike
mmm ok thanks for that karma i just got my extra battery to up my currie a bit more,just gunna use an extra 6 volt lead acid in series with the 24 volts to make 30 volts,that should be just enough tourqe for the little hills i think i am not after a real fast bike just an increase of say 5 to ten percent more power,will post some pics and specs when i do some tests
Old 01-06-08, 10:25 AM
mike-on-da-bike
yep found em karma they are two home made strips of wire for shunt resaistors on my setup i also found a top site you may be interested in looking at to do with these things,even shows you how to make your own controllers etc very good site for dc motors and the like.https://homepages.which.net/~paul.hil...llersBody.html and here is the main link i went through https://evchallenge.swantafe.wa.edu.au/electronics.asp
Old 01-07-08, 10:41 PM
mike-on-da-bike
that is good wire there a guy re-wired a little currie with that type and he said he go more torque plus more spped,he did say that he wound it much tighter than the factory wind,also that wire will take alot more heat as it is well insulated by the looks,normal winding wire just has an eneamel coating wich will melt off if gets too hot
Old 02-02-08, 06:19 PM
mike-on-da-bike
mmm think i wont play with that shunt resistor after all as it is my understanding it is there to restric the current for a good reason and maybe that will put too much current through the controller and blow him
