What's the popular opinion of riser stems?
Good, bad, indifferent?
Yesterday I picked up a 2012 Cervelo P2 for a steal. Well, not totally a steal. I did have to put a few hours into it to get it road ready. But I took it out today for a test ride. Rode 34 miles and honestly, by mile 15 I was almost ready to leave it by the side of the road. Everything about the bike is good, except for how aggressive the position is.
I ride tri bikes all the time, so I'm used to, and even prefer, the geometry of a typical tri bike. But this thing is so aggressive, it's literally painful. The steerer tube barely comes up to the lowest seat post height, which bends me over far more than I can hold for any length of time. But there's really no additional steerer tube to go up. All the stack is already used. And I can't go down any further on the seat post without hip angle issues.
So I need to go up about 2 inches, give or take, on my stack. I don't have any steerer tube left to go up, so my thinking is one of those jacked up stems at like 45*. I think that can get me another inch or so. Then I can take the elbow pads up with spacers to get me in a position I can hold for time. I certainly don't want one of those adjustable angle stems because they just look hinky to me. I'm not happy about it, but I think a fixed 45* stem could be a cheap solution to this problem.
Is there anything concerning about using a stem to get me up a little higher?
Quoted: 781 Post(s)
Liked 1,810 Times
I would rather just picked up a new fork to be honest if it is causing that much pain. If you raise the bars, then you have to futz with the seat position and then you might never find the correct position and you are really limited by the stem rise anyway. Should be able to pick up a good fork for not that much money.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 57 Post(s)
Liked 159 Times
The Velo Orange happy stem might fit the bill, I have not used it but do have a lot of VO parts and find them good quality.
https://velo-orange.com/products/vo-happy-stem-31-8mm
Likes For Small cog:
I never understood the taboo of a riser stem, but I came from the MTB world where they are common. It's the cheapest way to see if the bike can fit, so try it out.
Worst that happens is you try a couple, nothing works, and then you sell the bike. Best case it fits and you love it.
Expired Member
Quoted: 3753 Post(s)
Liked 5,682 Times
Unless you are a flipper, it's not a steal if it doesn't fit.
Likes For shelbyfv:
Shelbyfv, I am with you on this. The bike fit, as described, is way off and should be sold off as it is the wrong fitment for the rider. Nothing rides sweeter than a bike that fits properly. You can take that to the bank.
Quoted: 1440 Post(s)
Liked 1,996 Times
it’s possible a riser stem will help (?)
maybe a 25 degree stem similar to the Ritchey stem pictured above … there are a number of other similar stems available (including Salsa, Uno etc)
there is nothing wrong with a riser stem - just as there was nothing wrong with larger cassette / lower gearing, wider tires, etc
Quoted: 395 Post(s)
Liked 899 Times
Popular opinion on bikeforums is that they’re silly looking. Popular opinion in the real world is that they can be incredibly useful for fine tuning your fit. I wouldn’t use “popular opinion” as a deciding factor to see what works for you.
If you need more than a couple inches extra height, you might have the wrong size bike or wrong bike entirely.
Expired Member
Liked 5,682 Times
I could use the same reasoning, buy trousers on sale with inseam two inches shorter than correct.
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 410 Post(s)
Liked 831 Times
If aesthetics are important to you, then a 2" riser may do the job but still look "hinky". I wonder how much a new/old fork with a longer steerer will cost? With spacers and a modest rising stem you can get the stack that you need.
JohnMFlores.com | YouTube: JohnMFlores
Insta: JohnMichaelFlores | TikTok: @johnnymotoflores
Pennylane Splitter
Bikes: Yes
Quoted: 1839 Post(s)
Liked 1,488 Times
Maybe try an adjustable stem and see if you can 'fine tune' it to your size. This is a Ritchey version, I have an older version on one bike and it worked to get the bars up about 1.5":
Also maybe try a head tube extender. They work, but may not be appropriate if you are sensitive about popular opinion:
Likes For skidder:
Riser stems, they look goofy but hey, you gotta do what you gotta do.
That said, it sounds like this bike simply doesn't have a geometry suited to you.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 882 Post(s)
Liked 1,232 Times
Expired Member
Liked 5,682 Times
I don't think it was mentioned why the bike was purchased. If it has better components, they could be swapped to OP's existing tri bike that presumably fits. If the goal was to show up with a "cooler" bike, that will be dashed by any of the various stem kludges.
Likes For bboy314:
Quoted: 7083 Post(s)
Liked 11,180 Times
I don't speak for the masses, but my opinion of riser stems is that they are ugly and suggest that the rider bought an ill-fitting bike.
Likes For Koyote:
Liked 1,996 Times
which is not uncommon (and unfortunately too common) - especially older bikes with a short / cut steerer
note how many newer bikes are now equipped with a longer steerer and spacers (obviously excluding bikes with one piece bar / stem)
Liked 11,180 Times
while this might be the case - there is also the possibilty the size / fit of the bike is appropriate - but the bar height is too low
A riser stem is unlikely to get her that much additional stack because of, well, trigonometry. And even if it would work, it's a hack for an ill-fitting frame.
The bike was not a "steal." It was wasted money.
Quoted: 1625 Post(s)
Liked 2,677 Times
Sounds like you are running aero bars? You might want to go to a shorter stem and get some that sit higher. Maybe get some ideas from a local coach?
Liked 1,996 Times
OP states that she needs about 2" more stack. The bike doesn't fit.
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 224 Post(s)
Liked 335 Times
Triathlon bike with riser stem kinda negates the whole triathlon geometry.
Likes For XxHaimBondxX:
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 299 Post(s)
Liked 406 Times
A stem change is a great way to fine tune a bike fit.
If the stem is not 90° from the steerer tube, but angled down, you could just flip it over to get a rise instead of a drop. Assuming that's not an option, I like the suggestion in Post #3.
I have an adjustable stem on one bike, not only does it look hinky, but it's also a LOT heavier than a one-piece stem, which kind of defeats the point of that bike, IMO. (it doesn't matter on my commuter eBike)
Changing handlebars would be a last resort for me, esp. on that bike.
Method to My Madness
Quoted: 2035 Post(s)
Liked 1,528 Times
VegasJen: You would be better off with one or two bikes that fit rather than several that do not; the latter is a false economy.
You can use this tool to determine what stem would put the handlebar at a more comfortable accessible position: Stem Comparison Tool | yojimg.net
