Surly Disc Trucker vs Trek 520?
Quoted: 67 Post(s)
Hi,
Is there any reason on my first touring bike to choose
My current take is that the trek 520 here in canada is $300 (CAD) cheaper than the surly and the trek throws in the front and back racks for free.
So i'm absolutely going with the Trek, unless I"m missing something here....?
Any advice would be appreciated.
JP
JP
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Hi,
JP
JP
Some obvious differences between the bikes-
- QR for Trek and TA for Surly.
- Racks for Trek and no racks for Surly.
- Aluminum fork for Trek and steel fork for Surly.
- Smaller stock tire on Trek.
- Trek trail is 56mm and Surly trail is 67mm in the largest sizes(what i ride and know).
If you are good with the aluminum fork, quick release, and lower trail of the Trek- then get it.
Likes For jpjuggler:
Sunshine
Liked 7,492 Times
Its a measurement that takes into account your head tube angle, the amount of offset/rake of the fork, and the tire size. In practice, it shows how steering will feel. There is low trail, neutral, and high trail. This measurement is not inherently good or bad.
A low trail bike will steer well with a front load on the fork or handlebars. A high trail bike will feel stable and planted at high speed and going down hills. Those are basic examples to show that there are benefits to both designs.
Since you are a novice, ignore that I mentioned trail. Seriously- there is no benefit to knowing the numbers if you dont know how they will feel compared to other bikes you ride(and the trail of those). The numbers are only meaningful if you have other numbers and experiences to compare them to. Eliminate the trail from consideration.
I am not being flippant here and this is sincere- buy whichever you like the look of more. The drivetrains are basically the same, both have the same chance of successfully carrying you where you want to go, and the frame geometry numbers that are different are differences that would be lost on someone new to the game.
You like the fact that Trek has both racks and is cheaper? Cool- grab that. If you like the look of the Surly more and think that will make you happy each time you look down? Cool- grab that.
You win either way with these bikes as they are both capable of touring on from the start.
Likes For mstateglfr:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
You might look at Kona Sutra too.
https://konaworld.com/sutra.cfm
Better components all around for less (at least in the U.S. it costs less).
Likes For tyrion:
Likes For robow:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For Cyclist0108:
I've been thrilled with my 2020 Trek 520. The aluminum fork is the big issue steering people away from it. I really like the forks weight savings. It feels like all of my past touring rigs. It's a non-issue to me. It has 2000 miles of loaded touring and lightly loaded commuting miles on it. Not one issue yet.
Miles to Go
If the REI ADV 1.1 is an option for you, it has disc brakes, and racks included for a lot less money than the other two.
Sunshine
Liked 7,492 Times
I dont understand the front rack as there is no brace between sides, but maybe thats a design thats common and I am just not aware of all the designs out there. If it is a common design, I think I would still stick with my JANDD Extreme that has a top platform for storage and to help ensure stiffness on each side of the fork when holding panniers.
The weight limit of the Trek 520 is 275 lbs. (that includes weight of rider, gear, AND bike). That's a "no go" for me then.
Miles to Go
I have never used a rack like this either, and share your concerns - although these racks are very popular, so they must work OK.
I have a rim brake LHT, and intend to attempt to purchase the REI ADV 1.1 when they do the 20% off sale (they do this at least annually for bikes - not sure when).
Yes its a really good option. hybrid brakes, good drivetrain components, good gearing range.
Quoted: 3461 Post(s)
Liked 1,467 Times
Quoted: 67 Post(s)
hi, as I'm in canada, when I convert usa dollars to canadian, and add in taxes and import duty, it doesn't come out much cheaper if at all, but I really appreciate your suggestion.
