16" wheels for touring?
Bikes: Rivendell Sam Hillborne, Surly Big Dummy
Please excuse me for being redundant if these questions have previously been broached. I haven't been able to find the questions I'm looking for.
This is not so much a question of "Bike Friday or Dahon or Brompton?" but, all things equal, which wheels would you choose for longer rides or touring? And maybe the follow-up question: can a bike's specific attributes make wheel size practically irrelevant?
IMHO small wheels = bumpy ride. I still love them but if you can get suspension on the rear or better still front and rear, then the whole riding experience is so much nicer.
I commute daily 5.25 miles each way on my 16" wheeled Brompton.
PS you may want to check out a Moulton
Regards
Jerry
Regards
Jerry
Thanks, Jerry. Since I don't currently ride a small-wheeled bike, it's hard for me to differentiate between the two wheel sizes, because they both seem so small!
I'm actually interested primarily in two brands: BF and Brompton. I am reluctant to buy a bike, then discover that although I would like to take it on the road, the bike would not be capable - or enjoyable.
In your opinion, in riding 5.25 miles to work, are there reasons to suspect you might rather be riding a 20" wheel bike? I'm not talking foldability here, but just ride quality. There seem to be so many fervent enthusiasts for each type of bike!
Bicycle Repair Man !!!
For touring and longer distances where a really compact / fast fold is not the primary need I would look at a 20 inch wheel and when it comes to touring a bike like the BF NWT is an awesome choice.
I ride on 20 inch high performance wheels and do not find that my ride is unduly harsh and frame design will contribute to comfort and other ride qualities.
Moulton bicycles prove that with the right frame design wheel size does indeed become irrelevant as they ride as nicely as any bicycle and do not fall short in the performance department.
john - Because you live in the PNW it should be obvious that you should give a hard look at BF since they are made in your back yard... and they really are king when you are looking at a fold-able tour worthy bike.
A 406 20" wheel, is 2nd most common tire around the world, behind 559 26" mtb.
bike friday has been making knock down travel bikes for quite ,
pack in suitcase =no bike special handling fee, lots of drivetrain options..
its a custom bike.
their Tikit is an entry in Brompton's niche,
using same 349 high pressure rim/tire
fold is bigger, but because seat folds forward rather than telescope in frame,
seat height is fixed.
it has some stiffness issues, flexing the rear end tubing is its only suspension.
Todd, owner of the Clever cycle shop in PDX, rode his modified Brompton
down the Oregon and NorCal 'Lost' coast ..
blogs on it of course.
https://clevercycles.com/2010/11/26/d...t-by-brompton/
its a custom bike.
For my commute I would prefer to ride my 20" Moulton but as always its a compromise. The Brompton folds much smaller (the Moulton just splits in half) and thus the Brompton is so much better if you need to carry it places i.e. on buses or trains. I am not sure I would want to tour on a Brompton though, unless of course it meant having to carry it on other forms of transport.
If I had to tour (with minimal use of other transport) then I would use my Moulton TSR 20" wheeled bike. Its portability is enough that should I have to carry it occasionally on a train, bus or plane, it would be small enough split apart to just get away with it.
I have no experience of other folders like the BF or Dahon and will leave others to comment on their suitability.
I am curious though what has made you consider touring with a smaller wheeled bike ?
Regards
Jerry
Part-time epistemologist
A narrative on bicycle driving.
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
Quoted: 23 Post(s)
I love my Brompton, and there is absolutely nothing out there that could possibly better fit MY needs.
However, if the foldability of the Brompton wasn't THAT important to me, the Brompton woudn't be on the top of my list for touring.
1-if the touring you are planning has lots of climbing, you might be better off with a lighter bike like a high end Moulton or Bike Friday;
2-if the touring you are planning has lots of downhill, you might be better off with a bike with higher gears;
3-if the touring you are planning has lots of dirt roads, off road shortcuts and bad asfalt, you might be better off with bigger wheels, front and rear suspension (I would suggest a modified downtube FS in this case)
Just keep in mind that tire size is one of several modifiers that can play a major role on your final experience. Good luck on your final decision
Feel free to follow me on Instagram
Quoted: 321 Post(s)
Liked 7 Times
Small wheels for touring: I have done a fair bit of that on a great variety of small-wheelers.
On dirt/gravel roads I had trouble. My Birdy fully loaded would drift uncontrollably to the low side of the dirt road if it had a camber to it. In general, smaller/narrower tyres will tend to sink into soft surfaces a lot worse that large fat knobblies.
On tarred roads, no trouble. However the Birdy would develop a slow speed wobble above certain speeds (a known issue with Birdies).
I basically ignore warnings about such-and-such a bike not being suitable for whatever. And then I get great rewards.
Quoted: 659 Post(s)
Liked 7 Times
Some of my touring has been on my Bike Friday (20" wheels). In the absence of any need for the folding characteristic I still choose to use my 700c touring bike, but the difference is very small and part of my preference is an economic one - tires wear out faster on the Friday and they cost more. My Friday is not suspended, but I've found that the use of somewhat wider tires compensates quite well for the smaller wheels. On my 700c touring bike I usually run 25 - 28mm tires front and rear whereas on the Friday I use 37mm in the rear and 28mm in the front. Gearing is similar on the two bikes, in fact the Friday currently has a slightly higher top gear than the large-wheeled tourer.
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Liked 6 Times
I'd always pick my NWT for touring over my Tikit. The NWT is just a stiffer bike designed for touring and the bigger wheels work much better on rough surfaces. I run 40mm tires on both bikes, but the NWT's 20" wheels have so much more air in them. I recently went on a 100km overnight tour on my NWT that to my surprise was 80%+ unpaved and a lot of that was rocky. The 20" GS Scorchers did great and I kept up with my buddy on his 700c Surly LHT no problems.
If I only owned a Tikit I'd tour on it and it would work, but if I was buying a folding touring bike it would be another NWT.
Bikes: Brompton T6, Koga Miyata Distance, Airnimal Joey
We did a lot of touring on our 6 speed Bromptons. It's true, they are no MTB's but a sandy track sure is possible. They are no racebikes, but if you got the power you can be fast. When I don't need the folding much, - the Brompton folding is superb!- I take my Airnimal Joey. Not because of the wheelsize, but just because I like too ride that bike, right now.
But for me there is only one advise: Try before you buy.
Why? The difference is in the rider, not in the bike. So a good bike for me can be a disaster for you.
Thanks to all for their opinions and trusty well-earned knowledge. It is greatly appreciated. One thing is for certain: I have a lot of test riding to do!
Jerry: I just thought taking some tours on a small-wheeled bike would be fun! And it would allow me to make a few detours otherwise difficult to make.
Hauja
Bikes: not as many but still too many
I prefer 20 inch wheels for longer distances (over 10 miles)16" wheels without suspension beat me up.I have an old BF which I' ve managed to find some fat HP tires for that along with a suitable wide supportive sprung saddle really make things so much better.
Building around Pan Tour hubs gives suspension , a bit, .. narrow 74 axle hubs is a buzz reduction
at 1/2" of elastomer motion with in the hub,
100mm wide axle on the front and there's 1 inch of travel
thereare rear cassette hubs too and ones with discs too, though the use the bigger hole of Rohloff discs
for movement space..
Small wheels ARE better!
I used a Tikit to tour Borneo. It did the job pretty well! But yes, a 20" would do better esp on rough roads. We hit some pretty bad roads in Lao in Dec and our 20" Expedition and Dahon Speed 8 coped easily. However my friend on a road bike struggled.
https://lovethefold.blogspot.com/2009...in-borneo.html
https://lovethefold.blogspot.com/2011...o-paksong.html
My take is for commuting, the 16" wheel is more than sufficient and both the Brompton and the Tikit are excellent bikes in this regard, with the former having the edge in compactness. But if you do tour as well, go for the Tikit with double chain ring and touring racks.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Bikes: Too many....................
Quoted: 11 Post(s)
Liked 11 Times
I live by the Canadian border. Have you been to Bike Friday in Eugene? It is worth the trip, I was down there last summer and received the tour of the process. Very cool and you can ride the different bikes when you are there.
Speed Uno
Dawes Kingpin 2speed
Speed Uno
It's got electrolytes!
Bikes: Self-designed carbon fiber highracer, BikesDirect Kilo WT5, Pacific Cycles Carryme, Dahon Boardwalk with custom Sturmey Archer wheelset
Personally I think "20 inch" 406mm wheels are by far the best choice because you can get almost any kind of tire you want and in a pinch you'll always be able to find BMX/kid tires at any department/toy/hardware store. 559 (MTB 26") may be the most common wheel size in the world, but 406 wheels have to be the most common size in the US.
Other than that wheel diameter is irrelevant compared to each bike's specific attributes.
FWIW, I've seen pictures of people all over the planet on their Bromptons.
including perpetual traveling Heinz Stuck .
