Headset help -- old Atala
I have an old Atala frame that needs a new headset. It's not a particularly nice frame, heavy tubing and stamped dropouts and cottered cranks, nonetheless I wouldn't mind getting it rolling again. Does anyone know offhand if I would likely need to get some kind of unusual headset, or if your basic 1 inch threaded headset available today would work? I may try just replacing the balls and seeing what happens, too. Thanks!
Bikes: A bunch of old bikes.
Quoted: 294 Post(s)
Liked 901 Times
I think taking it apart and thoroughly cleaning the cups and races will tell you if it needs replacement or not. If they are in good shape and not rusted or pitted, new ball bearings and grease should take care of it.
Good luck
Good luck
Likes For daverup:
Quoted: 3035 Post(s)
Liked 3,926 Times
It will likely need Italian threads, but ISO threads should work too. Stack height could be an issue, but again, everything looks pretty standard.
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 52 Post(s)
Liked 115 Times
If the bearings in the headset are in retainers, and you find the bearing races “dimpled” from wear, replace with loose balls. Doing this, you can usually get a couple more balls in the cup and race which will even out the roughness, at least for a few years!
Likes For evwxxx:
Quoted: 3872 Post(s)
Liked 3,469 Times
+1
cycle appears mid-1960's
if curious regarding a specific date it should be marked in serial
first two digits indicate year of manufacture
serial stamped on the side of seat tube about 5cm below seat lug
frame:
frame constructed with Agrati lug pattern "SPORT" Nr. 000.8050/E/U
fork crown Agrati "AMERICA" pattern Nr. 000.8528
dropouts Agrati Nr. 000.8002
fork ends Agrati Nr. 000.8010
fittings -
3TTT Tourist stem & bar set
Weinmann centrepull brakes
chainset and pedals may be a replacement
hubs Gnutti large flange QR
rims likely to be Maccari
brake cable clips REG (Rampinelli)
model of cycle appears to have been the Gran Prix
here is the catalogue page for the 1971 Gran Prix (closest year found)
manufactured by Cesare Rizzato
+1
frame:
fittings -
Likes For juvela:
frame:
fittings -
+1
frame:
fittings -
And thanks to everyone who replied. I'll how checking out the races goes. Good to hear the headset shouldn't be hard to replace.
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,623 Times
Many old headsets "feel" like they need to be replaced before you overhaul the damn thing.
Likes For SurferRosa:
Liked 3,469 Times
headset -
as mentioned above, usually a cleaning and replacement of balls will get things moving evenly
the failure order in cup & cone bearing assemblies is ball, cone, cup
your set looks like it will have loose balls rather than retainers and take 26 or 27 5/32" balls per stack
if there is a slight amount of brinelling (dimpling of bearing races) its effect can be somewhat reduced by removing one of the races and remounting it after turning it very slightly
should you determine a replacement required it would be OK to fit a BSC ("english") dimension set which is easier to locate; the difference between Italian and BSC is only five degrees of pitch
if you are to fit a replacement one parameter to be aware of is the concept of "stack height"; the is the amount of steerer height the assembly takes up when mounted. your set has a stack height of between 34 and 38 mms. so you would not want a set with a greater stack height so as to preserve full engagement of the locknut's threads.
one variable not as yet discussed which can affect headset operation is the possible deformation of the fork. from what can be seen in images provided yours appears to be undamaged so should be fine.
this diagram may be of help -
[your set will have no seals]
headset -
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Looks like an Atala "Gran Prix." These used a Magistroni headset. Unless the parts are worn to the point of needing replacement, just clean it up and repack with fresh grease and balls. If it does need replacement, any ISO thread headset with similar or lower stack height should work.
Liked 3,469 Times
fabrication of Magistroni marked products ceased in 1965
cycle appears slightly later
of course Rizzato could have been using up existing stock
Bianchi Goddess
Quoted: 2968 Post(s)
Liked 3,048 Times
"You can't tell what in the pickle barrel until you get the lid off" Foghorn Leghorn, I think
I agree with everyone else you need to take it apart and see what's happening inside first. I don't know if it's been mentioned along with putting an extra ball in without the retainers, if the crown race and lower cup are dimpled you can rotate them so they are 180 degrees opposite each other. If it's a spare spare bike for your spare bike or a loaner it doesn't need to be concours perfect condition.
Sugar "Kane" Kowalczyk
Thanks for the help, all. Turns out I had an unused Tange headset lying around, that luckily had a 27.0mm crown race. I was able to get the old one off and the new one on without too much difficulty. It will be nice to get this rolling again, with 700c wheels it will clear some *really* big tires.
Likes For coffeecherrypie:
Is that a split in the top tube? Look about 2/3 the way from the lug to the brake cable clip. There is a longitudinal feature that looks like a split in the tubing but could be just a split in the paint.
Liked 3,469 Times
there is a short deep scratch of about one cm in length
doubt a split
doubt a split
Quoted: 486 Post(s)
Liked 661 Times
Out of curiosity, would you mind a few detailed photos of the headset you removed (cleaned up a bit)…. Would like to know if it was a Magistroni or not and just to get an idea of what they were using whatever the brand BITD.
The top tube is indeed in bad shape, borderline unrideable, except that it's very very thick tubing so I think it's OK. The split highlighted above is just a paint issue.
Liked 3,469 Times
thank you for this update!
IIRC the tubeset employed on this model is something such as Z50 or Zeta
it is a hi-tensile seamed set of thinner wall than the proverbial "gas pipe"
would guess there is plenty of "meat" there for it to hold together for the stated objective in first post
Chrome Freak
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
Liked 26 Times
I loved how Atala managed to chrome the lugs, rear triangle and fork tips on a relatively low line frame. On the other hand, it's Italian chrome so it didn't hold up.
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
