View Poll Results: Folding-Wire-No Preference
FOLDING TIRES
21
65.63%
WIRE BEAD
6
18.75%
NO PREFERENCE
5
15.63%
Voters: 32. You may not vote on this poll
Tire Opinion Please-Folding or Wire?
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I know which I prefer and why, but I would really like to hear what others think. If money and weight is not an issue, do you prefer folding tires or wire bead and most importantly, WHY?
Thanks in advance for all replies.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
For me it is simple. On a vintage bike with a NON-hook bead rim, wired-on. A folding tire will blow off a non-hooked rim at a lower pressure all things being equal. There used to be some tight folding tires designed for the older rims, but they are long gone. They later had warnings on the package "NOT for non-hook bead rims". It was a luck of the draw situation with Japanese tires and some handmade Italian clinchers being usable, but going to a wire-on was far easier. I did carry a folder as an emergency spare.
If the rim is a hook bead, folding all the way, for storage and for less weight.
Likes For Bill in VA:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Interesting question. I'm not aware of any reason to choose wire beads other than they are cheap.
Quoted: 1944 Post(s)
Liked 2,164 Times
I don’t think I’ve bought a wire bead tire in years. Except for the vintage rim issue above, you are basically just adding weight to save a few bucks.
If I had a fleet of bikes, it might be different answer.
John
John
Likes For 70sSanO:
Liked 2,979 Times
clinchers. It's usually what the preferred tires come in for my use.
-Oh Hey!
-Oh Hey!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
I am a notorious cheapskate and stopped buying folding tires once I stopped racing. Outside of racing I don't see any reason to spend and extra dollar for a folding tire. Just not enough difference between them in a low performance setting to justify the extra cost. With that said, if you are a typical bike dork, you will buy folding and think it is the bees knees.
Likes For TiHabanero:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Tubulars, anyone?
Likes For Phil_gretz:
Quoted: 2604 Post(s)
Liked 1,933 Times
I've got a couple folding tires I'll pack for traveling spares. The rest of my stash is less expensive wired beads.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Wire, please
Would only buy folding tires for packing if going on a long trip. First and only one I tried was an absolute bear to get on the rim; in fact I bent the rim trying to get it on. Not that they are all like that, but once burned, twice shy.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Personal experience here. For years I've been using folding tires on my bikes for no particular reason than availability in the size and tread pattern I wanted at the time. I recently picked up a wire bead Vittoria Randoneur for cheap and was really surprised at the ease of installation compared with folders. Hardly any massaging at all to smooth out the bead seat and the ride is surprisingly softer than the folder I have on the front and definitely more comfortable than the folder I replaced. Weight's not an issue with me because I am just out for the enjoyment of riding and the exercise. Thanks for all your responses so far, I have really enjoyed reading them.
Liked 2,979 Times
The last folding tire i installed was a Pirelli Velo tubeless ready on a carbon [iirc 50mm] wheel. Was easy. Kevlar tends to be easier to slip on when the tire & wheel are colder. Like under 40F colder.
-Oh Hey!
-Oh Hey!
Quoted: 1562 Post(s)
Liked 1,734 Times
Recently I though I'd cut up a wire bead Specialized touring tire for disposal. There wasn't just one wire per bead. Inside each bead there were 3 wires! Just what in the heck was the reason for this massive overkill? The tread of the tire has a mesh of wires embedded inside just like car tires. It was just a crazy amount of overengineering. Oh yeah- the tire failed because the sidewall developed a bulge and started splitting open. All those steel wires didn't prevent that.
But yeah to answer the original question, there is no reason for wire bead tires to exist anymore. Please don't encourage them.
Likes For icemilkcoffee:
