EVO Tour wheels?
EVO Tour wheels?
I need a new rear wheel. I just get around town any more so don't need a great wheel; some jerks bent mine up (A Sun CR-18 I built) while I was at the gym this morning, so I don't want to spend a lot of money. REI has 2 that fit (700c, 28mm tires). The EVO looks better, but I can't find a manufacturer or reviews (only 1 at Amazon). A search turned up only 2 vendors. Anybody know anything about it?
REI: https://www.rei.com/product/202024/e...00c-rear-wheel
Lessard: https://lessardbicycles.com/products...op-evo-tour-19
Amazon: https://www.amazon.com/Wheel-Shop-Si...ws/B01LZ5BMM4/
Total Cyclery: https://www.totalcyclery.ca/wheel-sh...ar-silver.html
Senior member
Quoted: 943 Post(s)
Liked 658 Times
EVO is the house brand of Cycles Lambert, also known as HLC, one of Canada’s larger bike parts distributors.
What you are looking at is a very basic entry level wheel built with generic parts.
I sold loads of wheels like it from Lambert when I had the bike shop.
Always a good idea to check the spoke tension and stress relieve it before putting it to use.
Likes For Dan Burkhart:
Really Old Senior Member
Assuming you have a decent/good quality hub, why not just get another CR-18 rim and use your existing hub & spokes?
I would get new nipples if yours aren't smooth turning.
Likes For Bill Kapaun:
Because I'm depressed and don't feel up to it. The hub is a Shimano FH-T610 I installed in 2014, with spokes that are even older. I haven't bought a new spoke in > 20 years.
Quoted: 6196 Post(s)
Liked 4,810 Times
Just glancing quickly at the links, but for the EVO links, I see no specs. So what's the OLD (drop out spacing or Over Locknut Dimension) of that hub and is it even a 700C (622mm BSD) rim. As well it looks like it's intended for a freewheel and not a free hub as the REI link is for.
It says it is.
It comes in both.
Likes For Arthur Peabody:
Google Maps says CA-OR border is 42 degrees N. It says Oakville ON is at about 43.45 degrees N.
But you're definitely farther south than Eugene, OR (about 44 degrees N).
I saw that one too (with query for "oregon california border") - then I looked at the map available on their website where they indicated the latitude was 43.80+ degrees N. The map showed the location to be just a bit south and east of Eugene, OR, if I recall correctly.
Bottom line: it was way off. Eugene OR is about 150mi north of the CA/OR border.
If you instead query that same site for "california oregon border", you get 37.78+ degrees N for the latitude. That location on their map is some distance due east of Fresno, CA.
What that site appears to be doing is only using the first word in the search string (the first state name listed) and giving you the lat/long they have as a placeholder for the state. Might be the geometric centroid; dunno what they're using to determine it.
Wikipedia and other sources I've seen all give 42 degrees N as the latitude of the CA/OR border. The "distancesfrom" website is the only one I saw that gives 43.8x degrees N - or 36.7x, degrees N, depending on how the query is worded.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
If that's from the "distancesfrom" website, well, I wouldn't trust it.
Remembering Sergeant Preston, I realized it's finally out-of-date! You'll have to explain to your grandchildren why he says, 'I arrest you in the name of the Queen.'
Quoted: 4806 Post(s)
Liked 3,931 Times
The 45th parallel is a little north of Eugene. Most Oregon highways have signs posted for it. (The 38th is somewhere close to the Bay Area. The sailing rag, 38th North, is published in Tiberon or Sausalito as I recall.)
Many don't realize it, but pretty much all of the US/Canada border east of the Mississippi River (e.g., everything east of the western Lake Superior/49th parallel junction) is south of 49 degrees - including the northernmost point of Maine in Aroostook County, just across Kelly Rapids from Pohenegamook, Quebec. Some of that northern border is well south of 49 degrees.
And FWIW, what appear to be the southernmost points in Ontario (Pt Pelee National Park and Pelee Island near Windsor) do in fact seem to be south of 42 degrees latitude.
Not giving you a hard time. I've found geography and maps fascinating since an early age.
Thanks. I was down in the dumps because vandals had bent my wheel. I recovered my confidence, bought another CR-18, built a wheel today. I hope it works.
