Need Brake Suggestions for a Track Bike Fixie and Toe Clip or pedal Suggestions
Buying a Windsor The Hour Today. Need Brake suggestions! And toe straps suggestions
Going to try the fixie life. Found a Windsor the Hour (what a name!) for $100. Currently set up with no brakes. I will ride it around the neighborhood as is but I will Def want to put a front brake on for riding around my hilly city.
So what is a good but not super expensive basic brake to put on. I'm hoping I can put a front on but I only saw a rear mount in the picture. Plus it just has basic flat pedals but I am assuming I need toe straps at least so any suggestions for those?
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/900x2000/screenshot_20240524_133916_9091d6341bd5a701f383a4b0e4006d7e643df30e.png)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/900x2000/screenshot_20240524_133908_b6d5b3668a3bf8fa08a325584120c47127d87f48.png)
Buying a Windsor "the Hour" track bike to try a fixie. But it has no brakes and I'm not ok with that. So I'm looking for brake suggestions. I'm only.paying $100 for the bike so don't need $100 brakes but I'd like something reliable.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/900x2000/screenshot_20240524_133916_935bf78f61591b986641cb4641d1ab16c3153e49.png)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/900x2000/screenshot_20240524_133908_2afd8498350519ee7b9be1f39aafb839b8ec9b3f.png)
These are the mounts if that helps.
Also need toe straps. Want this for city riding so don't really want Clipless.
Duplicate Thread Please Delete
Liked 4,081 Times
Brakes - yes! Measure vertically from the brake hole on the crown and rear brake bridge down to the center of the rim. That is your brake drop. Look at the nut side of each, crown and bridge to see if it is recessed for a modern brake with Allen nut (my bet) or has a flat for a regular nut and washer (like all older bikes). Then find a set of calipers that have that drop and the right nuts. Shimano dual pivots, either new of from the coop box will do nicely. Tektros don't have the bling but will stop you well. They come in black which you may prefer. New will come with levers. Tektro levers are cheap, good, fit my hands very nicely and are on all my bikes.
Likes For 79pmooney:
THEN..Brake hole in rear on the seat stay to center REAR rim, correct?
I just tallied that up....over $50 per brake!!! Am I wrong?
If not I may pass. This Windsor is only a So So bike I'd be getting for $200. Seems like I could get a similar spec (so-so) new from BD for $300, right? And then I wouldn't have to go to the trouble of putting on brakes.
This is basically what you need to measure, both frame and fork.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/900x675/img_8872_82fe34e72709b1c6c402bdc7c82ee2c1fc337924.jpeg)
And then determine whether you need nutted, or recessed nut brakes.
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/500x375/img_8873_d3646817a5df1967ab9f69111808bbc0a2e4372e.jpeg)
Yes, new bike parts cost money. If you have a co op in your area, or a shop that sells used parts, you can probably find some calipers pretty cheap.
Thanks! That makes more sense!
Sounds like I'll have to put $130 into it to make it safe to ride though. That's more than I wanted. Maybe I should just get a Kilo TT (or should I get the Pro like the Zachster recommends)
Clark W. Griswold
Liked 4,266 Times
The Windsor is a very initially cheap bike that has a brand name from an old defunct brand to give it more clout. I wouldn't put money towards it used and new I probably wouldn't either. A pound sign: KiloTT is better than the Windsor but is the same situation "brand" wise but generally spec's wise is ok enough to try it out but nothing great. The Pro is slightly better but little notches. If you are stuck online for some reason Wabi seems to make some more decent fixed gears. Otherwise your local shop might be able to get something fun or build you up a pretty awesome bike.
In the end though if you want good braking good quality pads and stiff shoes with high quality polished stainless steel cables and good stiff housing is what you want for good braking without as much cost as actual calipers and levers. I recommend SwissStop (or SRAM which uses SwissStop pads) or Kool Stop for pads and Jagwire Pro or Elite Kits for cables and housing (you will generally have extra stuff which you can file away for future usage which is excellent).
For pedals some variant of the XT PD-8120 is my go to. I cannot recall which ones I have had for years and which model I have on another bike but XT clipless is I think the best way to go. Good quality, long lasting pedals with excellent bearings. They do make some more expensive XTRs and cheaper non-series ones but the XTs I think are the best way to go in terms of overall cost.
I would not want any cages or clips or anything like that with fixed gear personally I like something I can get in and out of easily but also have good foot retention that is adjustable. I have multiple bikes so I can have another bike with just nice flat pedals but for fixed gear I want confidence and clipless pedals are confidence for me along with ease of use.
Clark W. Griswold
Liked 4,266 Times
Original thread here:
https://www.bikeforums.net/general-c...ggestions.html
Expired Member
I'd avoid clips and straps if you are not already familiar. Choose flat pedals or clipless, especially for urban use.
Likes For shelbyfv:
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista Vitus 979 Duralinox
Liked 6,926 Times
Merged duplicate threads.
Likes For cb400bill:
Clark W. Griswold
Liked 4,266 Times
Agreed or most everything except riding on flats fixed is not as fun as a new rider. I did it and slipping off the pedals going down a hill was not fun.
Likes For veganbikes:
Forum Moderator
Liked 6,926 Times
Merged duplicate threads, again.
I used my usual SPD-SL clipless on my fixie - I wanted some sort of foot retention and having to reach down to cinch or loosen a toe strap on a moving pedal didn’t see like a good idea (to me anyway - I know some folks are fine with straps)
Likes For 13ollocks:
Expired Member
The Motobecane you've been pondering would make a nice fixie.
Liked 3,050 Times
Likes For squirtdad:
Liked 4,081 Times
One thing I am certain of. I cannot tell at all if I am keeping my foot straight and not twisting it when my RPMs get over 200. So I would not know if I am securely cleated with clipless or about to unclip. And there's no way I'm looking down! (For reference, most of my riding in my days of single sided fix gear hubs was on 42-17 (67") or the like. That's 100 RPM at 20 mph. 200 at 40. Cars have clocked me at 45. In my younger and crazier days I went much faster (and drivers thought I was nuts. Never tried to pass or come alongside.)
