Gravel bike sizing dilemma
Hello,
I am new to gravel biking and I am in the market for a bike. I originate from a MTB background and I am quite familiar with geometry and my needs relative to the style and fit of a mountain bike but I am a little stuck when it comes to the gravel bike. I’m around 5,7/5,8 and I am sort of inbetween sizes on the particular bike I want (nukeproof digger rs) I am between a small and a medium. But I am leaning more towards a small to ensure a more upright riding position due to some recent lower back problems but the excessively small reach numbers on both sizes put me off abit. My main mtb has a reach of 460mm with a 50mm stem. And the small digger has a reach of 404mm which will then have a 60mm stem plus the drop bars. Does anyone have any experience with the sizing in regards to all of these elements or can tell me the reach/size they use relative to their height.
I would like to try the bike for size which would be the easiest option but unfortunately can’t do so.
all help and feedback is greatly appreciated
Habitual User
Quoted: 4957 Post(s)
Liked 8,102 Times
At your height - yeah - it's not surprising you're in between fame sizes. Changing the stem length and angle to get the right fit for your body is easy and pretty common practice. Keep in mind that a smaller frame will also likely have a shorter stack height, which may make it more difficult to get the bars into the higher position you need.
Since my preference is to be lower and probably more stretched out than you, my numbers probably aren't relatable. All my stems are slammed to the headset top cover without any spacers, and none of them have a positive rise. That's just what works for my body.
Quoted: 3245 Post(s)
Liked 2,093 Times
Oddly enough, the reach of both my mt. bikes, from middle of the seat to middle of stem at the bar is the same, or within 10mm of all my road bikes, at 67-68 cm. I chose the medium C-Dale Topstone gravel bike as the same ETT as my road bikes, at 56cm. I vary the stems a bit as my carbon road has the h-bar an inch lower. From what you stated, I would think a 460 plus 50 stem, at 510, will make the small Digger at 404 plus 60, or 464, too small. The Digger medium has at least 20cm more ETT and might be a better choice.
Everyone's body and preferences differ, so this is a terrible way to select a bicycle -- luckily, as noted above, the size doesn't matter because there are so many methods of adjustment.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 244 Times
Hello,
I'm 174 (maybe 1" taller) and based on effective top tube and stack figure, would go small as the 560mm with the 60m match most small/52 gravel frame 2 UK fitters advised me to go for.
When I spoke with Ragley (founded by the guy would design Nukeproof bikes and previously PlanetX/ OnOne bikes), Ragley told me to go small and told me the following:
If your height and inside leg measurements put you in-between two sizes, then your upper body should be the deciding factor in selecting the best-sized bike for you. Your upper body dimensions determine your reach, and this affects how 'stretched-out' you'll be along the top tube of your bike. To work out if you have a long or short reach, you need to determine your 'Ape Index' (arm span minus height).
- If you have a positive Ape Index (i.e. your arm span is greater than your height), then we suggest you go for the larger of the two bike sizes.
- If you have a negative Ape Index (i.e. your height is greater than your arm span), then you will probably be more comfortable on the smaller of the two bike sizes.
Likes For Fentuz:
What's you leg lengths?
the ape index looks like a good indicator and I’ll have a look now and see what I come up with so thanks a lot
There isn't enough difference between adjacent sizes to matter. With the bike in-question, the medium is +14.7mm of reach, and +18.7mm of stack. The latter is one stem spacer, and the former is less than the adjustability offered by saddles, seat posts, stems, and bars.
however I don’t want to buy a bike and have to adjust seat position and stem length to extremes in order to achieve a comfortable riding position as in years to come my position/feel will change and I do not wish to limit adjustability further down the line
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
You can’t compare frame reach numbers between drop bar road/gravel frames and MTB. MTB frames have for a long time been a bit longer, and in recent years gotten a LOT longer.
My MTB has a frame reach 73mm longer than my gravel bike.
With a mighty wind
Quoted: 1090 Post(s)
Liked 874 Times
I used to think I was 5’9”, then at a physical about 10 years ago they told me I’m 5’8”. Jerks!!
So I’m possibly 1” taller than you, maybe not. I would not consider a small. My medium, has a lot of seatpost showing and i gradually increased my stem length to either 110 or 120 while experimenting with fit.
Is it safe to assume your body measures similarly to the average male of your height? 30ish inseam, arm span similar to your height, no major mobility problems (back or neck)?
Assuming your body is anywhere near mine, I think a medium is a better bet.
Look at the picture below, imagine the hoops I’d need to jump through to get a smaller frame into the same riding position.
There is also no limit to future adjustability, since there is almost no position that is possible on one of these bikes and impossible on the other. The only such positions that might exist are on the opposite ends from where you are -- ie, the smallest setup for the small, and the largest setup for the medium -- and you don't care about those at all. If you did care about those positions you wouldn't be "between sizes" in the first place.
I have personally owned 51 and 58 cm Cannondales simultaneously and they had identical contact-point setups, and they both used common off-the-shelf parts, nothing exotic at all. That's an extreme example, but there just isn't very much difference between frame sizes, when compared with 200mm of seat post travel, 50mm of saddle travel, and an enormous array of stem and bar options.
If you want to spend days hemming and hawing over this decision, that's your prerogative, but it just doesn't matter (with respect to fit anyway, there might be other reasons to buy one size or the other -- such as buying bigger to maximize on-bike storage space ).
Likes For TC1:
Quoted: 275 Post(s)
Liked 244 Times
On a mtb, upright position, the load is mostly on the hip. On a road bike/gravel, the position loads both hip and arm. If the reach is too long, you will stretch and strain you arms, neck, shoulders (20mm extra reach hurst/fatigue me).
Like I said, I am 174cm, length (heal to inseam) is 78cm, arm (shoulder to thumb crook) is 57cm and I would go for a small digger
Liked 2,093 Times
That may be. I was somewhat surprised to measure my '22 large Epic Evo, vs. my '19 medium Chisel as the same 67 cm from middle of seat to middle of stem, which is essentially the same as all my road bikes. My Epic has a 50mm stem, the Chisel a 90.
Quoted: 1110 Post(s)
Liked 1,204 Times
I'm about your height (5-8), and always get a "medium-ish" frame rather than a "small-ish". The main reason is I prefer to err on the side of higher handlebars rather than lower. Others differ on that preference. The larger frame will have more head tube length, and therefore bar height. You can always get the bars up a little higher with the M, since there's only so many spacers that are allowed under the stem (usually 3.5 or 4 cm). The reach will be a bit longer, but usually not much more than a cm which is generally well within the normal adjustment of stem length to match up between the two. If you're looking for the most versatility shading towards an upright position, the M will always get you a couple-three cm higher. If you're more interested in a lower position, the S will always allow you to get a bit lower. If you don't have a strong preference, both will get you in the middle - the S with more spacers, the M with less.
Standover can be an issue, but not so much these days with slanted top tubes.
FWIW, I don't believe you can extrapolate much fit info going from MTB to "Gravel". Gravel bikes, at least for what I use them for, are definitely are more akin to road bikes. I've always had great success picking a gravel frame (before gravel became a thing i did the same thing with cross frames) based on comparing geometry to my most comfortable road bikes and simply deciding whether I could make if fit similarly with normal saddle and stem adjustments, remembering that saddle position is for position over the pedals, not reach to the handlebars..
Likes For Camilo:
