Calculated BCD for TA chainrings/ is this right?
Bikes: Miyata six-ten, Miyata Grand Touring, Univega Sport Tour, Univega Gran Turismo, 80's Trek MTB, 2008 Dahon Mariner
Quoted: 85 Post(s)
Liked 83 Times
Hello,
I recently received a group of TA chainrings from a friend whose father used them in the 70's. I thought that the crank that his dad used was a TA triple touriste. But don't know much about the TA line, so just guessed. I now have 12 chainrings ranging from 52 down to 26, all with the same 5 hole BCD.
Using the method of measuring from the center to center and multiplying by factor of 1.701 for 5 hole bolt pattern, For 38mm between two adjacent bolt holes, I got a BCD of 66.33 If I used 39mm, 64.6. Does this sound right? I cannot find this BCD anywhere! What am I doing wrong?
Please see attached screen shot for how I determined my calculations.
I do plan to offer these rings to BF members in the future and want to have correct BCD.
Many thanks in advance.
38-40mm rough estimate from center to center.
Give thanks, for unknown blessings are already on their way.
~Native American Prayer
Quoted: 5890 Post(s)
Liked 3,475 Times
TA outer ring is 50.4 bcd but it made different inners. The cylotourist inners are 80 bcd. I thought that the smallest inner was a 26. In any case if the bolt hole diameters all line up with your small chainring, then they are all 80 bcd chainrings. The other sizes of TA rings were 152 and 116 bcd.
https://www.bikeforums.net/classic-v...otouriste.html
Sutherlands 6th has the smallest chainring at 26 teeth. It's a 6 bolt pattern. The BCD is 80; from hole center to hole center, the measurement is 40.
Quoted: 85 Post(s)
Liked 83 Times
Liked 3,475 Times
I added some more info from Sutherland's 6th. 40 mm hole center to hole center is a 80 bcd and that's consistent with your measurements. Also it's a 6 bolt pattern.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
T/A outer is the only one that is a 5-bolt, and all the ones that connect to it, the middle and inner rings, do so using a 6-bolt pattern that is also in the large ring's spider. The 46T ring in your first photo is one of those middle/inner 6-bolt rings.
Liked 3,475 Times
Right, 6 bolt pattern. Also the TA randonneur which has a 116 BCD goes down to 36; the TA Criterium which has a 152 BCD goes down to 43. You have 6 bolt TA chainrings smaller than 36.
Also with a 6 bolt pattern, you should be able to measure right across the chain ring using holes that are opposite to each other and get 80 BCD.
Quoted: 85 Post(s)
Liked 83 Times
Whoa, that is really really embarrassing? How could I miscount? Because I have never seen a six bolt pattern before this! Still no excuse.Thanks a million.
