Go Back  Bike Forums > Bike Forums > BMX
ball bearing size for GT bmx hub?
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Old 12-05-21, 01:56 PM
rickpaulos
Quoted: 125 Post(s)
Liked 159 Times in 92 Posts
took this hub apart and found 3 different size balls in it. 1/4" - 7/32" - 3/16". 14mm axle.
anyone know what the correct ball bearing size is?
right side cage.
left side:
rickpaulos is offline
Old 12-05-21, 04:28 PM
Js760
Liked 10 Times in 3 Posts
Can’t help out, but you might get a better answer on the GT owners FB page.
Js760 is offline
Old 12-09-21, 03:18 PM
cbrstar
BMX Connoisseur
cbrstar's Avatar
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times in 69 Posts
It's tough to tell which one is which. But typically rear bearings are 1/4" in most rear hubs. You might want to check your front hubs to as I have a feeling the original owner got the bearings all mixed up for both hubs.
cbrstar is offline
Old 12-10-21, 03:37 PM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 135 Post(s)
Liked 173 Times in 111 Posts
Make sure you don't have one size on the drive side and a different size on the non-drive side. It looks like a std hub with freewheel. Hazarding a guess, the large bearings go on the drive side and the smaller ones on the non-drive side.
When a hub destroys itself like that, bearings can travel through the hub to the other side.
You need to remove the axle & freewheel and look at the cups and cones.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
Old 12-13-21, 11:39 PM
rickpaulos
Quoted: 125 Post(s)
After a bunch of trial and error...
The hub shell is threaded on both sides. freewheel standard 1 & 3/8" on one side, odd ball 1 & 3/16" on the other side (the side with the 16 tooth ACS FAT freewheel). The cups are different sizes. Smaller on the side with smaller freewheel threading. The cones are the same outer diameter but the bearing surface is cut smaller on one cone. and one cone is shorter. So left and right specific cones. 5/32" balls on both sides seems to work best. larger sizes have the balls running on the edge of the cones, not in the center of the bearing surface. About 15 balls on each side. Seems sensitive to having what I'd say is enough. Turned much smoother if I took out one. (kinda like a headset). 14mm axle x 1.0mm pitch. What the hardware stores call extra fine pitch (but they don't carry that anyhow).
The ACS FAT freewheel is noticeably fatter than normal single freewheels. I found out that ACS also makes left side drive specific freewheels. This ACS FAT seems better quality than the endless stream of bso single freewheels.
