Atala ID Help
Quoted: 66 Post(s)
Liked 185 Times
Atala ID Help
Someone had this bike out by the road for sale cheap so I bought it. I think it is a Grand Prix from around 1971 based on some other posts on this site. This one dose not seem to have a serial number is there a way to find out what year it is? Would the campagnolo detailers have a date stamped into them? Any chance the steel rims and stem are original?
Quoted: 3814 Post(s)
Liked 3,345 Times
yes, date looks right
usually serials are placed on side of seat tube about four or five cms below seat lug
you might wish to check this area under strong lighting in case marking was put in lightly
usually, the fame size as measured in inches c-t-t is stamped in two places on the underside of the bottom bracket
stem and saddle cannot be original but balance of fittings appear to be OEM, from what is visible in images supplied
WingsToWheels
Bikes: Italian, French, British
Quoted: 84 Post(s)
Liked 66 Times
Agree with juvela, definitely looks like a 1971 Grand Prix Model 104 M, made of Tullio high tensile tubing and with Valentino Extra derailleurs.
Quoted: 66 Post(s)
Liked 185 Times
Thanks for the help. With the bike outside and using a flashlight I am able to see the serial number. The bike is a 1973. Can anyone tell me what brand the
stem should be?
stem should be?
Quoted: 811 Post(s)
Liked 1,024 Times
My guess and it is only a guess. Is it should be 3T. Or ttt.
Liked 3,345 Times
the OEM stem & bar set was a 3TTT Tourist
bar may well be original
here are some images of a set, the extension in this case is nine cm -
diameter: 22.2mm
clamp size and bar centre: 26.0mm
diameter: 22.2mm
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Agree; this is an early 70s Atala Gran Prix.
