How critical is size on a Tour Easy?
Quoted: 11 Post(s)
I should ride a Med. frame.
There's a small advertised locally. Any chance it would work ok? Out of the question?
Thanks,
Thanks,
Quoted: 1572 Post(s)
Liked 643 Times
Local bike = test ride. Decide for yourself.
Probably won't work. There's not much room for adjustment on them. But go ahead and test it out.
Bikes: Santa Cruz Heckler, EZ Sport AX, Lightfoot Rambler, Electra Townie 24D "The Holy Grail of Beach Cruisers"
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Kind of doubt it. I ride an XL Gold Rush, but started out with a large Tour Easy. On the TE I had the seat all the way back in the adjustment slots and my knees still ached because the adjustment was too "close". When I switched to the correct size, I was a lot more comfortable and a little faster.
Jeff Wills
Jeff Wills
Bikes: RANS Stratus 700, Bacchetta Corsa, HPV Gekko FX 20, Rover Tandem
Quoted: 13 Post(s)
Here's Easy Racers chart showing what frame is needed for a person's X-seam. https://easyracers.com/docs/X_Seam_Guide.pdf
Since you ride a medium and smallest X-seam for a medium is 39" and largest X-seam for a small is 39.5", you would have to have a 39.5" X-seam or less to fit a small. You can try riding it but I doubt it will fit you.
