Rim strips for Campagnolo Zonda C17 wheels??
Bikes: 1978 Masi Gran Criterium, 2011 Bianchi Sempre, 2018 Pinarello Gan K
Quoted: 5 Post(s)
I just received a new set of Campagnolo Zonda C17 disc brake wheels. Based on the smooth and curved inner rim surface, I assumed that rim strips were not necessary. But the Technical Specifications in the User Manual specifies a 20.5 mm rim strip. I can't see what benefit adding a rim strip might provide. I know this is a very popular wheelset so I would appreciate hearing if other users installed a rim strip. Thanks in advance.
Quoted: 645 Post(s)
Liked 797 Times
Sprockets away!
Bikes: 2021 Prior Prime 105 Disc, 2015 Cannondale Synapse 105 Disc, 1996 Brodie Quantum, 1984 Norco Monterey (SRAM automatix two-speed), 198x Cramerotti Campagnolo Chorus (restored)
Quoted: 36 Post(s)
Liked 15 Times
No rim strips on my Zonda's either, and nothing at the valve hole. No issues for two years of riding, well in excess of 8000km. Love my Zondas, although the manual said rider weight limit was somewhere around 170lb... I just managed to squeak under 175 this year, but i'm not telling my rims that.
The bigger question in my mind is, why aren't these wheels good for going tubeless? Campagnolo says no, but their construction seems to suggest they'd be fine... The only hole is the valve stem, wouldn't a TL tire seal really well if you installed a TL valve?
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 5 Post(s)
Thanks for the replies. I like the idea of using some rim tape near the valve stem hole.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Ensuring that the valve hole doesn't have any sharp burrs, maybe giving it a light chamfer, is all you should need to do.
Likes For ThermionicScott:
Quoted: 3952 Post(s)
Liked 7,297 Times
I asked Campy about that several years ago. I don't have a copy of their response anymore, but I remember two issues they cited: the rim isn't sealed at the weld, and the rim profile isn't correct for tubeless.
Sprockets away!
Quoted: 36 Post(s)
Liked 15 Times
You're right... I remembered the limit was something like 5lb lighter than I was, which was about 185 when I bought them. I'm 175 now. Rode 25's on them for about a year, then switched to 28's instead... Sooo much nicer with 28's.
Absolutely no point is using rim strips with zondas or any Campy/Fulcrum wheels without holes for nipple access. Zondas are not tubeless ready. I use Fulcrum racing 3 DB wheels that are tubeless ready with no rim strip required. I use michelin tubeless tires.
Quoted: 5 Post(s)
Thanks for the information. I can appreciate how prolonged braking with rim brakes could cause thermal stresses for the tube. My bike has disc brakes. I have used the Zonda wheels without rim strips for several months now without any issues. My usual ride includes a long descent (and ultimately ascent), that's posted as a 7% grade. Overall I consider the Zonda wheelset to have been a great upgrade.
