questons about going tubeless
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Ok so I am my own mechanic and build my own wheels and never really have thought about going tubeless. So far it seems I would have no advantage or reason. I have Kinlin BDOP DIY wheels I built. I run Conti Grand Pri 4000 II (23mm) and have not had a flat in my 2 years or so. I run 110-115 front and 100 rear at 175 lbs. I really have no issue with ride quality and going less psi is not something I care about but seeking opinions. Could it be going tubeless is safer on descents or turns?
Is going tubeless better and will I see any improvement? Finally what do you need to make the change. I pretty sure these Kinlin cx279 rims are tubeless compatible.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Quoted: 399 Post(s)
Liked 185 Times
Oh thanks I thought they were. In any case they are good hoops. I was thinking of building a set of DT Swiss 440's with OC rear 28 24 and some novatec hubs, with plain out DB wheelsmiths spokes and brass nips.
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
Do you really run more tire pressure in front than in back? I think you've got it backwards.
Thirst is stronger than the rules. - Stars and Watercarriers, 1974
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Edit: cross post with above. Noticed the same thing.
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
As it seems you prefer gambling over taking proactive flat prevention measures, and that you're so comfortably certain about what you haven't experienced, then I say yeah, don't bother with tubeless.
However, if the way in which your certainity about the Kinlin's being tubeless compatible turned out to be false prompts you to reconsider your other assumptions, then you may find some potential benefits in going tubeless.
No matter how you cut it though, no one needs tubeless, so you'll have to be working on a more sophisticated assessment than that, e.g. a more nuanced understanding than "I don't get flats, ergo I don't need tubeless."
Bikes: '98 Rhygin SS road,'99 Fat Chance Ti Fat, '95 Azonic Mtn bike, '88 Giant Sedona.
I got a new set of Ksyrium SL's in 2012, after 12 years on the Heliums, with 2 flats over that time. I had never heard of road tubeless until I read a.review of the SL's where the tester ran some Fusion 3's, and loved the ride. So I ordered a.set, and haven't gone back to tubes yet. 23 mm tires running 80 R and 75 F. Try it,!you mightnlovenit n
cycle-dog spot
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
I run tubeless in my commuter. Sector 28s on Stans wheels. Really nice. Really like them.
I will tell you, while you won't get flats in the traditional sense, a puncture takes time to heal with sealant.
During that time, a 27 tire will drop from about 90psi to 20 or 30 psi. So while you are not swapping tubes, you will certainly pull over and add air. I imagine this would be worse on smaller sized road tires.
For what it's worth...
