Washers to install brake caliper
Quoted: 24 Post(s)
Liked 17 Times
Hello,
I am installing a larger front brake on my bike as part of a project to build a wheel. I have the wheel almost done, and I test fitted the brake parts today. The idea is to go from 160mm front rotor to a 203mm front rotor (on an aluminum daily-use commuter).
Photo of test fit:
I bought an adapter to move the caliper so that it fits the larger rotor. Its description was vague, but it seems to fit. It comes with 4 little washers, and not for right under the bolt head (those flat washers are already on the bolts).
Are these like shims? Do they go under the adapter/caliper to fix fitment problems? What did I miss? Maybe it will be obvious when I fit it together for real, but I don't see the purpose as of yet.
Thanks for any thoughts.
Photo of test fit:
Quoted: 5793 Post(s)
Liked 2,585 Times
I gather that neither the instructions packed with the adapter (or not) didn't cover this, nor was there anything on the maker's site.
So, granting that you got more washers than need for the bolts, you're probably safe to assume that they're provided as shims to float the brake to best position vis a vis the rotor.
FB
Chain-L site
FB
Chain-L site
Quoted: 24 Post(s)
Liked 17 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Hello,
Photo of test fit:
Photo of test fit:
