Stoker's wireless with cadence
Riding Heaven's Highwayson the grand tour
Bikes: '10 C'Dale Tandem RT2. '07 Trek Tandem T2000, '10 Epic Marathon MTB, '12 Rocky Mountain Element 950 MTB, '95 C'dale R900, "04 Giant DS 2 '07 Kona Jake the Snake, '95 Nishiki Backroads
I’d like to replace my stokers wired bike computer with a wireless one with wireless cadence. I’m considering either a: VDO C3DS, VDO C4DS or Sigma 1606L DTS, each with the wireless cadence feature.
Has anyone used any of these in the stoker position?
If so, has the signal from both cadence and speed sensors been reliable?
Or is there something comparable that I should be considering that has proven very reliable?
Bill J.
Bill J.
Bikes: Long Recumbent, Short recombent, racing bike, MTB, beach bike,Tandem,Fixy.2 twentys and a folding bike
Sigma
No it's a bugger of a thing.... interferance from all sorts of things....cuts in and out and only works half the time
If I was doing it again [next time] I'd stick with the wired one.
Maybe others have had more luck with them...
Bikes: Rodriguez Toucan tandem, Rodriguez Rainer Lite sport/touring
We use a Garmin Edge 305 with wireless cadence.
Were using 2 VDO C3DS one on Capt.. and one on the stoker both using one sensor the speed is mount on rear wheel and cadence on rear stoker crank. The transmitting distance for the VDO C3DS is about 15ft so range is no problem and they have no interference that we have ever seen working flawlessly.
I'm also using a slightly larger magnet on the crank for cadence so the sensor picks it up better.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Bike & SCUBA
Bikes: 2007 Seven Axiom 007 Tandem with couplers, 1994 Litespeed Catalyst, 1992 Cannondale Road Tandem, 1990 Cannondale Road Tandem, 1984 Gitane Tour de France
We are using VDO C2DS computers with speed only. The pickup is on the front wheel and works great for both the captain and stoker positions
Here is a brief follow up on my original request for help on selecting a wireless computer with cadence for my stoker.
First 'thank you" to each of you that responded because it did make a difference in my selection.
I ended up buying the VDO C4ds as the Edge 305 was well outside my budget for this project. I actually would have gone for the C3 because the C4 had more features than I could use but on the day I was ready to buy the best price opportunity came on the C4. I paid $85.49 for a new one with the cadence option including Tax and shipping.
The installation was pretty simple and the instructions were easy to follow. I used the existing magnets from the captain’s wired system. Getting both of the C4 sensor’s data to read correctly on the screen took a couple tries but it did set up as described.
We took it for a 45 mile test ride on New Years day and it worked perfectly. I could not be happier…the only down side is that now, this captain wants to toss his old Cateye and get a matching C3 or C4.
Bill J.
Bill J.
Good to see it worked out for you. If you do opt for another get the CD4 and it will work of your existing senders. The CD3 may work with the CD4 senders I'm not sure you can email VDO and ask but they may be different and you would need to install another set of senders. I know the CD2 and CD3 will not work together not sure about CD4 and CD3 combo. You can pick up another VDOC4DS for around $79 you don't need the cadence for it.
Bikes: Santos Dual Travel touring tandem, MSC Zion MTB-tandem, Santos SCC03 MTB, Santos STR01 trekking bike, Cannondale F500 MTB, Kalkhoff E-bike, Centurion Cross 4000 cyclocross bike (converted to road bike)
We tried and retried, both with and without a Garmin GPS on the front handlebar, but the same differences always come up.
Does anyone have similar experiences and/or can anyone suggest any solutions? Changing the wheel size came to my mind but then the actual speed will be way off .....
