What's Your Minimum Climbing Speed to Stay Upright?
As a new tandem rider (around 250km so far), I noticed that our minimum speed for climbing hills is around 7 km/hr. Any slower and the bike feels like it will keel over.
Feels as though on a tandem, I have to climb a bit faster than if I were on a single.
What's your experience?
My stoker is great at not throwing her weight around so we can crawl at 2-4mph if needed and I can hold the tandem at a stop for several seconds at times quite like a track stop. I give her great credit for the great trust she has in my ability to keep it upright I wouldn't dare do it with anyone else.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Bikes: 1998 Co-Motion Co-Pilot, 2015 Calfee Tetra
Quoted: 177 Post(s)
Liked 6 Times
When you get down really slow (& likely breathing really hard) you find out there is a big difference between 3.5mph & 3mph (5.6kph & 4.8kph). We have ridden as low as 3mph for a short distance near the top of a steep hill.
hors category
Quoted: 8 Post(s)
Liked 5 Times
We've gone really slow and have never fallen over... but my wife is a petite flower and well-manner stoker which makes everything easier on a tandem.
I think the only way I can sum-up the difference is to note that it's simply different. So much of our riding is done on the tandem that almost everything has become rote and not all that much more unusual than similar experiences on single bikes.
Bikes: Santana Arriva S&S, Calfee Tetra S&S, Cooper, Ritchey, Trek T2000, Trek Carbon ATB to name a few.
I used to think that about 3 1/2 mph was as slow as we could possibly go. Then we got older and slower and more experienced I guess and we do 3 1/2 kph in France during the summer. I can not go that slow here in California in the winter, maybe because we are doing club rides most of the time and that slow is not allowed?? Back in about 1977 when Bill McCready was teaching me how to Captain a Tandem and teach tandeming, he would drop into granny and do an extremely tight circle, to make a U Turn, at about 2 mph or less. The key seems to be maintaining headway thru pedaling and then you can go almost zero and still keep balance. The key to a track stand is making headway while being stopped if that makes any sense. Not swinging from side to side is the other key. Smoothly my friends.
Dick Powell, www.OutfitterTours.com
Retired Founder & Former Owner of The Bicycle Outfitter of Los altos, California
Quoted: 77 Post(s)
Liked 19 Times
Slowest ever for us: 3 1/2 to 4 mph at 9,000+ ft. elevation with 6% steady grade.
Get into granny gear and just 'twiddle' . . . and yes, a good/trusting stoker is a huge + !
You know you're moving slow when a caterpillar can cross underneath your tandem and not get squashed!
Pedal on TWOgether!
Rudy and Kay/zonatandem
Pedal on TWOgether!
Quoted: 177 Post(s)
Liked 6 Times
"You know you're moving slow when a caterpillar can cross underneath your tandem and not get squashed!"
Rudy - I love this picture!
Bikes: Santos Dual Travel touring tandem, MSC Zion MTB-tandem, Santos SCC03 MTB, Santos STR01 trekking bike, Cannondale F500 MTB, Kalkhoff E-bike, Centurion Cross 4000 cyclocross bike (converted to road bike)
Indeed, keep on pedaling is important for making tight turns and I'd like to add that squeezing the rear brake makes it even easier. We went down some very tight hairpins on a mountainbike tour of the French Alps last year by using this technique. On many occasions we do a short trackstand in the middle of a hairpin to determine where the front wheel is to go. This to the amazement of many a solo rider
Quoted: 303 Post(s)
Liked 136 Times
The slower you go the more difficult it is to ride a straight line, ditto the higher the
crank torque, as in steep hills. Higher cadence helps a little, but if you need to keep
a line it will take extraordinary balance to do so under 3.5mph up a hill. Doing slow
donuts is a lot easier, bears and chimps can do it. If you can wobble several feet
side to side then going slow is also less challenging on two wheels.
Cyclist- Bike 'n a half
Bikes: Custom S & S Bushnell Tandem, Eddy Merckx Ti
About 3 mph tandem or single. If we/I can't go any faster than that, it's probably safer to walk.
We have managed a long, steady climb at about 4.7 km and occasionally we have been slower. Our 'trick' is to have the Captain's pedals advanced by 90 degrees ahead of the Stoker's. That way there is always someone in 'power', and there are no power surges.
I never thought about any effect on going slow, but what you said makes sense. I think I will try it again.
Dick Powell, www.outfittertours.com
Founder & Former Owner of The Bicycle Outfitter of Los Altos, CA
With no power surges, the whole transmission should last much longer than if there is strong pulsing from two riders pushing at the same time. However, you will no longer be able to rise out of the saddle.
You will notice your shadow, and be convinced you are at different cadence. Know that it is an optical illusion.
We start, climb and lately sprint out of phase (90 captain leading) out of the saddle. Our slowest constant climbing speed is about 3 mph. Never encounter a hill that required us to go slower... or maybe the fear of falling gave us that little extra push to keep the speed up.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
I'm afraid we're going to find out. Just decided to enter the Tandem division for Everest Challenge.
17% grade at 10,000 feet, after 28,000 feet of climbing (in the 2 days) should produce the answer.
hors category
Quoted: 8 Post(s)
Liked 5 Times
I know you did this last year on your single bike, but how many times have you and your stoker done anything like this?
pan y agua
Liked 728 Times
She's done some fairly hard riding in past years. (70 mile ride finishing up L' Alpe de Huez would be her toughest ride to date.)
Most of our tandem rides have been a bit more leisurely.
We have our work cut out for us.
Time for a change.
Liked 5 Times
Never. Starting a 7 month plan now to get ready.
Just find the steepest hills in your area and do repeats on them. Didn't help us but I like to suggest others to suffer the pain we did.
Spike Milligan
Spike Milligan
Year-round cyclist
In 2006, with the loaded tandem pulling a loaded trailer (self-contained touring for 3 persons), I climbed most hills at 5 km/h, but a few at 2,5-3 km/h.
