Adapting narrower hub rear wheel to wider dropout
I have a MTB with rear wheel inside dropout distance of 135mm (26" wheels). I decided I wanted a narrower wheel for city use, so I go a 1.5" wheel. It works OK, except that I have to use spacers and/or washers to take up the extra 10mm of space (I'm assuming that the hubs of fat-tire wheels are 10mm or so wider than the hub of my 1.5" wheel). That may be why I have broken the axel every few months. Are there 1.5" wheels that have wider hubs to fit wider MTB frames?
Quoted: 4206 Post(s)
Liked 3,870 Times
More data would help us help you. QR or nutted axle? Cassette or freewheel? Its tough for us when you use mixed dimensions (hubs with tires). Yes, 26"/559 ISO wheels can be had with a 135 wide overall locknut dimension, in pretty much any axle or cogset configuration. QBP, a major US supplier to your LBS, shows quite a few in stock right now as example.
Axle breakage is also mentioned. Have your wheels been freewheel ones? If so than a cost to that design is the uneven stress that the rear axle sees. Bending and breakage at the RH side cone's inner edge is very common, both hollow QR and solid nutted axles suffer from this. Cassette hubs (using what we call a freehub body to slide the cog set onto) have an axle bearing location that reduce the axle bending tendency. While a different cogset and thus chain, would be needed this is a good consideration if those added parts are in need anyway. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2338 Post(s)
Liked 2,823 Times
do you mean 1.5 inch tire? . you can get narrow tires to fit 135 mm 26 in mtn bike wheels here is an example https://www.biketiresdirect.com/prod...-385?fltr=3774
that would be the better way to go if you breaking axles which I assume is because your are putting a road wheel with 130 or 126 or even 120 size on
Likes For squirtdad:
Thanks
Thanks. It's got rim brakes and threaded 6-cog freewheel. I use the hollow quick-release axles. I have a narrow wheel that my 26 x 1.5 tires fit onto.
The cassette hub sounds like something I need if it lessens axle breakage. What are the most common cassette hubs nowadays (re. availability of parts)?
I checked QBP. Their website is VERY bad. I recently found out about bikeparts.com, and it looks like a good source.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Why is the wheel you had previously not going to work for your tire? If it is a 135 spaced 26" wheel it should fit the tire just fine unless it is something ridiculously wide but you have rim brakes so most MTB rims from that era where pretty narrow compared to now and a 1.5 tire is not that tiny at that time. I would just use the old wheel or get a proper wheel that is 135mm spaced that fits the criteria you need!
Freewheels are a pretty outdated standard but if you are running only 6 speeds in the back there aren't really great sources for cassettes out there for 6 speed 7 speed yes but 6 speed is pretty much exclusively freewheel. If you are running friction you can run just about anything but we still don't know enough about your set up to really help a ton on that regard. If you have a high quality derailleur from that era (say Deore, Deore LX, XT...) than you could say upgrade to a 9 speed set up pretty easily with a 135 spaced cassette wheel a 9 speed shifter and a 9 speed chain and cassette and you wouldn't have to change cranks or rear derailleur.
I have a couple bikes running 9 speed on 7 and 8 speed rear derailleurs and at one point one of them did have 7 speed chainrings but I ended up swapping to a LX crank because I wanted an external BB and the crank at the time was an outdated no longer in production Bolt Circle Diameter (BCD or sometimes PCD) and didn't want to deal with that anymore plus it also was Octalink but the BB was fine and the previous crank to that was a 7speed early XT crank which got moved to a different bike and sold.
The 26x1.5 tire fitting on the rim is not a problem. I have a frame I like, but the wheel I have been using for the last few hundred miles has a hub that apparently was made for a frame that should have hubs about 10mm wider. That's probably why I have been breaking the rear axle every 7-8 months or so. I like the narrower higher-pressure tires for urban commuting.
Re. 'outdated', that's me! I'm at least a couple of decades behind in pretty much everything. I still listen to shortwave radio, and still snap photos on film and develop the negatives in my kitchen.
Re. cassette hubs, which system is better re. availability of replacement parts?
I am guessing you couldn't check QBP as their website is pretty good and one of the easiest to search on but you can only do so if you work at a shop with a QBP account unless some unscrupulous employee decided to share the login with you which could easily get them fired and cause issues for those of us in the industry who work at shops who have legit accounts we aren't sharing. QBP is not a consumer site it is for dealers and the industry and these don't seem like questions one who works at a shop would ask.
Clark W. Griswold
Liked 3,994 Times
Get a proper wheel with the correct spacing: your local shop can more than likely get it. The Sta-Tru Double Wall Rear Wheel - 26", QR x 135mm, Freewheel, Black is a fine option and will likely work assuming what you have told us is correct. There are currently probably 200+ in various warehouses in the U.S. and your local shop has access to them or a shop near you should.
In terms of better a cassette is going to be better assuming you have 7-13 speeds at the back but if you have 6 or below freewheels are what is out there. IRD still makes quality freewheels but there is plenty of low end stuff out there so you aren't in total trouble but it is not a real continuing standard aside from for single speed stuff. However again if you are looking to move to a cassette again assuming you have 6 at the back you will need new shifters, chain and a cassette along with a wheel that is cassette compatible which is also easy to find and if nothing else easy to build up.
Sounds like you're using an older 126mm OLD freewheel hub with (possibly) a longer-than-normal axle in a frame with 135mm rear dropouts. Is this correct?
Unless you put all the spacers on the non-drive-side and re-dish the wheel, using a narrower freewheel hub with a larger OLD frame lengthens the unsupported part of the axle outboard of the bearings on the freewheel side, making it easier to bend or break an axle (as Andrew R Stewart described above). If you added spacers evenly to each side to keep the wheel centered, you did that.
f you feel you simply must continue to use that hub, then going to a solid axle may help. More metal (no channel for the QR skewer) means a solid axle would be somewhat stronger and stiffer. Downside is that you'd need to carry a wrench with you in case of flats, which would be much more of a pain to fix roadside.
IMO your best bet is to get a rear wheel with a freewheel hub and 135mm OLD. You could also rebuild the wheel with a 135mm QR freewheel hub, but that's possibly going to cost more than simply getting a new prebuilt rear wheel (new hub, very likely new spokes/nipples, labor if you don't do it yourself) .
Likes For Hondo6:
Quoted: 6195 Post(s)
Liked 4,810 Times
Is the wheel that was made for the bike usable? Why can't you put a narrower tire on that wheel?
Likes For Iride01:
Likes For icemilkcoffee:
Likes For alcjphil:
I found the info at the Sheldon Brown website
Unfortunately, I never saw the original rear wheel-- I got the frame in a swap and then later got the wheel in a different swap.
Yes, the frame is meant for fat knobby tires, but this bike is for urban commuting, which is why I like the narrower, high pressure tires.
I found ALL the info I needed at the Sheldon Brown website! It is so great and I recommend it for everybody who does maintenance themselves. Just google "Sheldon Brown"
Quoted: 1819 Post(s)
Liked 1,694 Times
Likes For alcjphil:
Quoted: 1562 Post(s)
Liked 1,734 Times
Or better yet, search up user 'Sheldon Brown' here on bikeforums:
https://www.bikeforums.net/search.php?searchid=14655205
