122, 128, 130 BCD - all with 38T smallest ring?
I'm working on my son's bike (Raleigh Competition) which has a later Nervar Star crank. According to Velobase it has a 128 BCD. Looking at Sheldon Brown's five-arm crank crib sheet, I see that the smallest chainring is given as 38 teeth. That's what's on the crank now. The table lists 38T as the smallest chainring for 122 and 130 BCD as well. I assume that must not be the theoretical minimum, but the practical minimum (the smallest produced by the manufacturer). Or are the chainring bolt diameters sufficiently different that it affects the smallest possible chainring?
Sutherland lists:
38T as smallest for 122
38T as smallest for NERVAR 128
39T as smallest for all 130's
Sutherland lists:
ambulatory senior
Liked 3,681 Times
Likes For 52telecaster:
working on my sandal tan
Liked 2,579 Times
38T is definitely possible for 130mm BCD. I have one, but I see evidence that the chain plates are able to contact the mounting tabs on the crank spider. I wonder if that is why most production chainrings are a tooth or two bigger than their theoretical minimum.
[MENTION=52458]jonwvara[/MENTION] makes a 37T 122mm BCD ring, of course.
Likes For ThermionicScott:
ambulatory senior
Liked 3,681 Times
38T is definitely possible for 130mm BCD. I have one, but I see evidence that the chain plates are able contact the mounting tabs on the crank spider. I wonder if that is what is why most production chainrings are a tooth or two bigger than their theoretical minimum.
the 39T limit on 130 BCD sets listed on me Sutherland is likely due to it being a fairly early edition
Howard revises the manual every few years
Likes For juvela:
verktyg
Smallest Chainrings
Over the years I've found that at least 5-15% of the specs in Sutherland's Handbooks are wrong or . I have a second edition the we used back in the 70's (error factor 15%) and a 5th edition that covers the C&V era that I'm interested in (5-10% error factor).
37T were the smallest 122mm BCD chainrings that Stronglight produced. This 1980 catalog page shows the 105 Bis "drillium" chainrings but they made 37T standard chainrings too. They don't show up in any catalog prior to 1980 but... I have at least 15 bikes with Stronglight 49, 93, 104 and 105 cranks that I've mounted what I thought to be 38T chainrings on. When doing a tooth count, I found that over 1/3rd of them are actually 37T rather than 38T! Several date back to the late 1970's.
The 3 silver chainrings are 38T - the black one is 37T.
Shimanos are the only 130mm BCD cranks that I have experience with. I found that some of them are limited to a 39T small chainring without a modification.
Shimano 600 Crank with a 39T chainring.
A 38T chainring on the same crank. The chain will drag when going over the top of the spider arm.
I'm running 48T or 49T outer chainrings with 38T inners on most of my Shimano cranks. File about 1mm to 1.5mm off of the spider above the chainring bolt hole. This minor modification solves the clearance problem.
In defense of Sutherland's, during the bike boom, many bikes were sold or serviced by shops with little or no experience working on derailleur bikes; e.g. lawn mower shops, ski shops and so on. Sutherland's was a good resource for those kinds of businesses when for example they needed to replace a BB and so on.
Some of the dimensional specs were off when it came to little nuances like components with wide open manufacturing tolerances like BBs, hubs, FWs, and headsets. It was better than nothing because we had to learn ourselves by trial and error. We focused on better quality bikes so it became an issue for us.
juvela I'm not picking on you... just pointing out & sharing weird exceptions learned the hard way....
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
blahblahblah chrome moly
Stronglight 93 et al. at 122mm should be able to take a 36t with a little trimming of the spider arm tabs. I plan to make one, have the holes marked out, needs drilling counterboring and trimming, just haven't got a round tooit.
CAD drawing is from here.
Mark B
Mark B
Likes For bulgie:
Technically not true for the 130. There are some 130 cranks out there drilled for an 86 3rd ring. Takagi made triples in both 130/86 and 110/74. I'm guessing some other brands did as well.
verktyg
Doubles Not Triples
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Old fart
Liked 3,461 Times
You can file a little material off the end of the spider arm to prevent this. Ofmega actually machined their 144mm BCD cranks to provide clearance for a 41T ring, which was otherwise subject to the same issue:
Likes For JohnDThompson:
While I appreciate the discussion of all the possibilities in the surrounding BCDs, is there any chance a 36T or 37T 128BCD chainring for Nervar Star cranks was ever produced?
Probably completely impossible at 36t, unless there's some hack I haven't considered.
The website I use, that does CAD simulations based on BCD and teeth, doesn't have Nervar as a choice in its drop-down menu.
But if you put in 37 and 130 mm, you see the "valley" between two teeth actually touches the bolt hole. Nervar has a bolt circle radius just one mm smaller, so you could get that silly millimeter of clearance if you were desperate enough. Maybe with a smaller bolt diameter, smaller hole?Do the same thing at 36t and I think you'll agree — ain't happenin':That's not even the worst place, a couple of the other holes overlap the chain roller even more — maybe I shouldn't have cropped the screenshot that way.
Mark B
Likes For bulgie:
- A factory-made triplizer middle ring for 130 BCD (TA, Stronglight, Shimano, Mavic, Willow, FSA or Thorn) can be adapted to 128. You only need to ovalize the holes by 1 mm each, like with a file or dremel. Looks a little wonky, but only if you look real close, and it works fine.
- Or a new triplizer can be made with an actual 128 mm BCD (no ovalized holes) by starting out with a 38t ring with a 74 mm bolt pattern. Rare but they're out there, I know where to get one right now. Then you add 5 new holes at 128 mm, and the granny bolts to the original 74 mm holes. I have done this, works a treat. Oh yeah you have to cut the inner "shelves" off the spider arms, like making it into a Track crank. The "shelfectomy" is a 15 minute job if you have a vise, hacksaw and file, and you are handy.
- Or a new triplizer can be made with an actual 128 mm BCD (no ovalized holes) by starting out with a 38t ring with a 86 mm bolt pattern, that is, a Stronglight 99 ring, not quite as rare. Then proceed as in item #2 including the shelfectomy.
- Finally there's the Campy old-Record (aka "NR") way, where the 5 spider arms are drilled and tapped for stand-off bolts that the granny attaches to. Here's one I made that way to take an 86 mm Stronglight 99 granny ring:
That's time-consuming ($$), and even just the 5 Campy #818 standoff bolts often sell for well over $100. Though there are cheaper alternatives to the Campy bolts shown here, like generic industrial bolts from McMaster, this is only really an option for someone (like me) who's just crazy about their Nervar Star and nothing else will do. For most sane individuals, there are easier ways to get the needed gearing. If you're one of the crazy ones, let's talk.
Mark B
Likes For bulgie:
feros ferio
Liked 1,369 Times
I am using an Origin8 38T chainring on a Shimano spider with an SRAM PC-58 chain on the Bianchi without any issues. The chain links do ride on the ends of the spider, but this does not appear to cause any issues.
Likes For John E:
Liked 1,467 Times
+1 on the mild ovalizing of chainring bolt holes to make a 130 fit a 128 bcd Nervar Star. For a while I ran my Allegro using a 47T Sugino ring I modified that way, and it was discrete and drew no attention.
Likes For rustystrings61:
Mark B
Mark B
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Edit: Just read Bulgie's post #13 and unreservedly accept his word that a 36 o r 37 probably wouldn't work with 128 BCD.He is a real machinist, and I'm a guy who just works with machinists sometimes.
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Mark B
Mark B
I might be able to import a 144 bcd ring drawing to detail out some milling for lightness and style as done using a ring I have as the design reference.
‘still need to have someone mill it out though.
I'm not saying send it to the guys I know, but maybe you know someone with a little CNC that you can trade favors with.
Yeah, well, 85% of being a machinist is having the necessary machine tools....
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
I know a couple guys with little hobby-sized benchtop CNC mills, that can handle parts this size in aluminum. They're slow but you don't have to stand there watching, you can go for a ride while it chugs away.
I can probably find someone, looking at the original and all the chatter in the slots, need to design a wee bit of tooling to hold the chainring effectively.
