Where do you guys store your nuts and stuff
Not nutsacks. But when working on a bicycle, where do you store your nuts/little parts? I am new to all this, but usually have different cups. Like for the derailleur i'll label it derailleur and just put everything for it in there.
Quoted: 2604 Post(s)
Liked 1,933 Times
I think the only time I take a derailer apart, the jockey wheel and nut stay on the table while I'm greasing the bearing. (Ditto Campy shifter parts during a rebuild.) Bottom line, I don't have parts for my parts lying around, and things like brake pads or cleats can stay in the box or bag they came in until I'm ready to use them.
Common things like M5 bolts live in zip-lock plastic bags. Since I don't have to look for one very often, I don't mind digging.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Agree
I only work on one bike at a time though.
Quoted: 4236 Post(s)
Liked 2,949 Times
I do need to get some sort of container for my common-sized nuts and bolts. My dad has these boxes with pull out clear drawers (maybe 2"x2"x8") that I've been jealous of for a long time. Need to find some like those.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
There are magnetic cups for putting small parts in. Alternately, get a 2 gallon zip-lock plastic bag and do disassembly of small parts inside the bag. This prevents a small spring from going ballistic and embedding invisibly in the carpet 10 feet away.
Quoted: 241 Post(s)
Liked 232 Times
I use a bunch of Ikea kid's plates to hold parts and assemblies. They are cheap, something like 4 for $2, large enough to hold a brake or derailleur, unbreakable, and cheap enough that if I damage one I don't feel to bad about tossing it. I also have a few divided plates for separating the parts when working on something. (The ones I have are actually square, not circular.)
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 566 Times
A handful of dinky Tupperware-like containers work fairly well. One for all nuts/bolts/parts related to the derailleur. Another for hub parts. Etc. Can be closes with the lid, labeled and stored for easy visual identification later, if postponing re-use of those parts. Larger tube for larger assemblies.
Haven't needed much else, over the years.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Anything at hand, though cardboard egg cartons would certainly absorb the grease and oily fluids....
Liked 1,933 Times
Liked 2,949 Times
Yeah, I have a park one of those on my stand for immediately used stuff. By no means is the Park one necessary (or even better than others), it was just available when I needed a new one..
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
During a re-build, I get out a fresh copier paper box and set it within its inverted lid. Then individual components go into the box. Disassembled or loose parts go within Ziploc baggies and then into the box (headsets, bottom bracket bearings, loose downtube shifters). Then any new cables, chains, bar tape, whatever go into the box. I then can start on the frame without any loose things bouncing about.
For long-term storage of loose and sundry items, I have a stack of compartmentalized lidded trays that hold everything: One for bearings, another for cable housing parts and brake parts, another for larger items like replacement derailleur pulleys, spacers, lockrings, pump pegs and the like, and one more for fasteners.
All long-term component storage is in individually labeled shoe boxes by component type: derailleurs, cranksets/bb, brake, cable housing, pedals, handlebar tape/plugs, shifters. This system is patterned after Marie Condo's method, and it really works well. It's simple to find anything in seconds.
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Yep, the big bag thing is a good idea,(it's also commonly used when working on firearm parts that have tiny springs), but another good idea is to have a big retrieval magnet on hand, that you can wave over a wide area or carpet or flooring, and pick up tiny steel parts. They're not very expensive, but can be real handy.
Mine looks a lot like this one.....https://www.sportsmansguide.com/prod...agnet?a=679952
(I actually got turned onto these things while crewing on boats, they're used to rescue tools and other stuff that may have fallen into the silty bottom from the pier or boat.)
Quoted: 2026 Post(s)
Liked 1,096 Times
For organized storage of small parts like nuts, bolts, washers, bearing balls, etc. a multi drawer small cabinet is extremely useful. Here is an example: https://www.homedepot.com/p/Stalwart...7422/205190694
This one is a bit large for just bicycle items but I use a similar one to organize all of my SAE and Metric fasteners, bearing balls and miscellaneous small hardware items. There are smaller versions with fewer drawers at lower cost.
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
I have a multi drawer cabinet as well which I store small parts in. Very useful. When I am working on a bike and want to keep small parts in one place I use the lids off old peanut butter jars as holders.
Quoted: 645 Post(s)
Liked 797 Times
Harbor freight usually has a bunch of small parts storage solutions for less $ than the big box hardware stores
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
https://www.harborfreight.com/materi...ase-93928.html
You can get them for about $6 when they run their coupon special
