Shortening handlebars
I recently purchased a Specialized Sirrus x2 with flat bars. I think I may want to shorten my bars. I'm going to slide my shifter and brake levers in first to see how l like it. What would be the best way to cut the bars, saw or tubing cutter? TIA
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If you don't have a cutting guide use the tubing cutter, they work great. Unless they're carbon of course, then you have to use a saw.
Use a tubing cutter. You will have to file off the flared end after the cut.
If you want to use a hacksaw, clamp a couple hose clamps on the bar to guide the blade through the cut.
If your a real techy, you can get a Park Tool SG-6 Threadless Saw Guide which is what I've used.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Not sure what flare is being referred to here as the blade will push the metal inward, not outward, but definitely use a tubing cutter if you have one available. Assuming it's a metal bar. BTW-you do realize that the trend in MTBing is going wide on the bars, even though it makes the trails feel a whole lot narrower haha.
Quoted: 194 Post(s)
Liked 204 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
I also have found that I needed to file the outer edge of the cut. I used a rat-tail file on the ID, finishing with a machinist's deburring tool.
Quoted: 645 Post(s)
Liked 797 Times
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
I've shortened a few metal handle bars. A pipe cutter works great!
Remember.....measure twice, cut once. In this case, you'll have to do this 2x (for two ends)
