Velox bar plugs
Fuji Fan
Velox bar plugs
Before I get creative, are there any tips for getting the smaller star washer to catch on the larger washer when installing Velox bar plugs? So far, the screw keeps spinning and never tightens. I tried using a wrench to tighten the nut down, hoping it might help catch something, but have had no luck.
My next thought is to use something to provide texture to the larger washer.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
I try to get them started outside the bars and then install them as a snug fit and finish tightening them.
Quoted: 3811 Post(s)
Liked 3,338 Times
have installed and removed quite a few of these and have never encountered this symptom
first thought is two possibilities:
either parts assembled in wrong order
or there is damage to the threads of either the screw or nut...or both
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Oil the threads, this has worked for me.
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
As thinktubes said start them outside the bar until you get a pretty snug fit and then it wont spin and will expand out when you turn the screw,
Quoted: 472 Post(s)
Liked 1,028 Times
Down in the dungeon at the LBS we keep rubbing alcohol available all the time for easing rubber/metal interfaces. Mostly for getting grips off and back on. For the Velox plugs it could help. Tighten them up nice outside the bars then wet the plug and ease it into the bar. Finish tightening. The alcohol evaporates in an hour or so. The reverse helps too when you want to remove rubber bar ends or mirrors that have been in there quite some time.
Quoted: 3810 Post(s)
Liked 6,699 Times
I use hairspray for such applications. Bonus for its pleasant smell.
Likes For nlerner:
Fuji Fan
I was born anosmic, so I cannot tell if you are being sarcastic or serious. Is the smell necessary for its effectiveness.
I tried 3 new plugs. I bought 4 new sets, so I guess I could technically check the rest, but those 3 seemed like a sufficient sample.
Quoted: 3464 Post(s)
Liked 2,829 Times
If you must, get a small disc of sandpaper 80 grit about right and stick it to the back side of the compression washer- punch a hole and assemble- that should add to the friction.
that written- velox plugs were designed for the bar tape to fold into the bar bore, if you are trying to install with nothing... good luck
Likes For repechage:
Liked 6,699 Times
”Pleasant” is relative to the smeller, I suppose. But the smell is evocative of early memories I have of my mother at one of those old-fashioned beauty parlors back in the day.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
Many of us know there isn’t any other use for that stuff in Lerner shop.
Likes For Spaghetti Legs:
Liked 2,829 Times
Quoted: 1372 Post(s)
Liked 1,751 Times
Make sure that they tread easily before attempting to install into the handlebar. Snug slightly, insert and tighten. This system has always worked for me...
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
Quoted: 394 Post(s)
Liked 346 Times
Finger tight and make sure the star washer is not worn smooth. And, as said above, make sure the screw threads easily and not binding.
