Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Experience with a Dutch Lock
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Old 05-22-23, 07:23 PM
prairiepedaler
Bikes: Looking for "the One"
Liked 323 Times in 212 Posts
Does anyone have experience with these "Dutch" locks? They are also called ring locks. Are they problematic, easy to defeat etc? There are several different manufacturers of them. I think in conjunction with other locks, they'd be another layer of deterence. I'd like to see if it is possible to fit one of these locks to a fork, then use a u-lock through the rear triangle of the frame attached between the wheel and the stationary object.
prairiepedaler is offline
Old 05-22-23, 07:46 PM
Velo Mule
Velo Mule's Avatar
Quoted: 809 Post(s)
Liked 1,023 Times in 665 Posts
It is a bit tough to tell without anything else in the picture, however, since you are calling it a Dutch type of lock and from the looks of it, it would attach where the rear brake caliper is located. they are ideal for commuter, shopping and pub bikes. These range quite a bit in quality and strength is my understanding. They are typically easy to use but may not be the most secure. They can not save your front wheel from being stolen or the whole bike from being picked up and thrown in the back of a car, van or truck. Some people put a cable through the loop in this lock to lock the frame to a post and the front wheel before coming back to put the other end in the loop and locking it.
It may be a good sign that Kryptonite is making this style of lock. I don't know how good it is but they usually back up their locks with some sort of guaranty. The other lock maker that tends to be good and have this type of lock is Abus.
Despite the fact that I like these locks, I don't have one. How bad is that. I just use a cable and combination lock.
Velo Mule is offline
Old 05-23-23, 08:02 AM
Iride01
Iride01's Avatar
Quoted: 6195 Post(s)
Liked 4,810 Times in 3,318 Posts
Locks only deter the casual thief. So still, I'd be careful how valuable a bike I lock up with that lock and leave unattended.
Iride01 is online now
Likes For Iride01:
Old 05-23-23, 03:16 PM
FBinNY
Quoted: 5788 Post(s)
Liked 2,581 Times in 1,431 Posts
They are not high security at all, but simply a deterrent to opportunistic "grab and ride" type thefts. So, if you're a bike courier working in an area where the delivery runs don't involve leaving your bike for more than a VERY few minutes at a time, they're fast and convenient. Same if you're using the bike for daily errands and your primary security is keeping it in sight or leaving or only for short periods, ie. buying an ice cream cone.
OTOH, they're a quick and easy way to secure a wheel, when added to better security, like a U-lick or chain for the bike.
So, like everything else security related, consider the area, how long you need to leave the bike, and then balance the required security level against things lime weight and convenience.
FWIW - a key element of security is more psychological then mechanical. For years while living in NYC I'd leave my high end road bike "locked" outside restaurants and small shops secured only with my left pedal's toe strap looped through the chainstay. Never had an issue probably potential thieves realized that just riding off wasn't possible, and also assumed that nobody would be dumb enough to rely on a toe strap unless they were watching the bike from close by.
FB
Chain-L site
FBinNY is offline
Old 05-23-23, 04:11 PM
I-Like-To-Bike
Been Around Awhile
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times in 1,045 Posts
Casual thieves are the only kind I am concerned about; my relatively old and inexpensive bicycles are neither high end nor flashy, and do not appeal to those looking to steal bikes with those features. A frame lock is adequate for the security of my bike that came equipped with it, I typically use a cable lock though because after over 20 years of use the key looks as if it might break after just a few more uses.
I-Like-To-Bike is offline
Old 05-24-23, 01:36 PM
veganbikes
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times in 2,665 Posts
I use mine all the time except mine is from ABUS. They are not primary locks at least not here in the U.S. but as a secondary or tertiary lock they are fantastic. It keeps someone from easily stealing your rear wheel and can be combined with various accessory chains to lock it to something and only would require one key. For me I use it in conjunction with a Bordo 6405 (for the frame) and a Bordo Lite (for the front wheel) on a very expensive bike and don't worry too much about it. It is also a handy lock for when I am out and about with friends say at a restaurant where I can be very close to the bike but don't want to keep my hand on it while I eat or if I bring it inside someplace it is an easy way to prevent casual theft.
I used to hate café locks because I hadn't used one and didn't quite understand them but now after having one for a couple years I am sold. The beauty of my locks are that they are keyed-a-like from ABUS and I can add as many locks as I want to the set with that same key number so everything is secure but I don't have to fumble around with multiple keys. In the case of my e-bike and the e-bike I had gifted my father I have essentially 6 locks that are all keyed the same so if something happens we are both covered or if I need to borrow the bike or something I can go over and borrow it without having to get a key or if someone forbids one of us gets hurt and needs to lock up the bike and have the other pick it up it is super easy to do because we share a key.
veganbikes is offline
Old 05-28-23, 01:59 PM
CliffordK
CliffordK's Avatar
Quoted: 18377 Post(s)
Liked 4,512 Times in 3,354 Posts
I didn't know Kryptonite got into the market. Hopefully they are looking at quality issues.
Mom and Dad bought a couple of those ring locks in Italy years ago. They don't look like much, and might trip up thieves that are unfamiliar with that type of lock.
I'm not sure the old locks were even hardened, although the new ones probably are.
I might consider one of those for a touring bike, so one could lock the bike when using a restroom or going into a convenience store for a minute.
I like the idea of using it on a front mount to deter theft of a front wheel. I think it may interfere with rim brakes, although surely it would be fine with disc brakes.
CliffordK is offline
Old 05-30-23, 04:00 PM
Wasted Tuition
Wasted Tuition is offline
Old 06-03-23, 02:00 PM
prairiepedaler
Indeed, I also shared that thought. A dutch up front and a u-lock or chain through the rear triangle would be perfect.
Old 06-03-23, 05:11 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Here's the old fashioned American version...
https://www.masterlock.com/products/product/1517D
Lots of people used these when I was a kid. Granted, all of the above caveats did and still do apply. And don't forget to park next to an expensive bike secured with a cable lock.
Gresp15C is offline
Old 06-03-23, 08:17 PM
veganbikes
Clark W. Griswold
I feel like I could just look at that lock and it would open...
Wasted Tuition such poignant remarks, truly the Mark Twain of our generation. Also kidding again not serious just having fun.
Likes For veganbikes:
