Continental GP 5000s on vintage rims
feros ferio
Quoted: 1397 Post(s)
Liked 1,339 Times
Is it just me, or is anyone else unable to mount Continental GP 5000 tires on a vintage 700C rim? I can't even get the first bead over the edge of the rim. I bought these to replace an older set of Continental 4000s, which, though a tight fit, were doable. Rims are Campagnolos with 14mm inside width.
If I own it, I ride it
Quoted: 593 Post(s)
Liked 663 Times
They are difficult to mount, as are many of the newer high zoot tires, Specialized Turbo Cotton for example. I know I have seen a list of rims that Grand Bois does not recommend their tires be mounted. It can be done with some work using a tire jack. And dang I can't believe I forgot that fact a few days ago (and three patch jobs) while trying to mount some of the aforementioned Specialized tires.
Bikes: Bicycles? Yup.
Quoted: 488 Post(s)
Liked 1,627 Times
I made the mistake of buying tubeless ready GP5000s for my 650b project rims. They were so hard to mount that I'll pull them off and re-mount before riding them. If they're not easier the second time...it's replace or get a support car follower.
Likes For BTinNYC:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 992 Post(s)
Liked 658 Times
Yeah, I've had trouble. I had a topic going here perhaps 2 years ago, the best advice was to lose the thick rim bands and use Caption tape to gain a tiny bit more room to shove the bead down into the center of the rim while mounting. Significant improvement so now I use that tape on all bikes. And I'm putting GP5000's on about everything.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Quoted: 1587 Post(s)
Liked 1,761 Times
The GP5000 is notorious for being hard to mount. You have to use a tire jack. My advice is to stock up on GP4000S II while you can still find them. They are easier to mount and softer riding than the 5000.
Likes For icemilkcoffee:
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 169 Post(s)
Liked 351 Times
To echo what others have said, 5000s are generally a tight fit. If you're mounting a tubeless-ready version, use tubeless tape instead of other rim tapes, even if you're using tubes. A paper towel or rag provides extra grip when pushing the last bit of the second bead into the rim. I also find insulting the tire as I wrestle with it helps me... mentally.
Likes For Rooney:
Crawlin' up, flyin' down
Quoted: 1046 Post(s)
Liked 2,586 Times
FWIW, I have zero issues mounting Conti 5000s (or 4000s, for that matter) on Mavic Open Pro rims.
Mounting on old Gentleman rims? Yeah, that requires a tire jack, which I always carry with me now.
aka: Dr. Cannondale
Quoted: 2159 Post(s)
Liked 3,457 Times
I also went to Capton/Kapton tape four or five years ago, much easier to mount tires and just as good as any other rim tape IMHO.
Impossible to mount some of these newer tires on really old, hookless rims, tho- I’m looking at you, Weinmann Concave.
Likes For rccardr:
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,301 Times
Newer tires are sized for use on modern (wider, and with deeper center channel) rims.
I struggled to change tires while using Panaracer 700x45 "Smoke" knobbies on my MA2 rims back in the 90's, but was able to do it trailside using one plastic iron once I changed to Rox lightweight rim tape which was quite thin.
I am running a GP5000 25mm tire on the original front Campagnolo Lambda rim on my 1989 Klein, but I forget what tape that I put on there.
After some months, and at 80psi, the tire measures only 23.75mm wide on the narrow (i13mm) rim.
But the same tire measures bigger than 25mm on a contemporary i18mm rim.
I don't think you will find any remaining stock on the old GP4000 tires. Maybe the new 28mm tires will be about right on your rims though.
Bikes: 1988 Gitane Team Replica, 2022 Trek Top Fuel 9.8
Quoted: 67 Post(s)
Liked 58 Times
I spent about an hour last night just getting one GP 5000 on a Campy Zonda C17 wheel. It's tough.
I've not used Continental tires, but I similarly have great difficulty in mounting new Vittoria Corsa clincher tires on to my Mavic MA2 rims.
So, I now pre-stretch the tires: I first install new tires on to a set of newer wheels, and inflate the tires to 110 psi and leave them for three full days. The tire's kevlar bead stretches out a bit, and I can then install the tires on to my MA2 rims, using a VAR tire jack. (I first tried two days, but that was inadequate.)
Aftter a bit of on road use, the Vittoria tires seem to stretch out a bit more, and they become an easy hand-install.
You might try the same pre-stretching technique if you have a set of wheels with modern rims available.
Andrew G.
Andrew G.
Likes For Andrew_G:
Making up the numbers
Quoted: 110 Post(s)
Liked 518 Times
Always* with a single layer Ritchey or Continental plastic rim tape and definitely not Tubeless Ready tyres.
As long as the bead is in the centre of the rim bed I seldom need a tyre lever.
*except on the Shamal C17s which need no rim tape, a quite brilliant innovation.
Nothing quite says wall hanger like drillium toe straps
Quoted: 981 Post(s)
Liked 1,844 Times
My set of GP5000's went from a new pair of Mavic Ksyrium wheels and slipped right into a set of Araya rims from around 1980 without any extra hassle.
Quoted: 3464 Post(s)
Liked 2,834 Times
For all you guys who had no problems installing tires, may I introduce you to the ambrosio elite 19.
Likes For repechage:
Liked 2,834 Times
Some of these new tires are primarily designed for tubeless use, the bead is different in cross section, square exterior corners
recently looked at a few videos of the bikes in use in the TdF, tubeless, tubulars, only one showing with a tube in the
open casing.
the riders are going wide, 28,30mm, due to the mod wide rims, some 28s measure in at 29+mm
open casing.
Pedalin' Erry Day
I put some on Wolber Super Champions a while back and don't recall it being particularly difficult.
Liked 1,301 Times
Quoted: 1207 Post(s)
Liked 1,370 Times
It helped leaving the tires outin the sun to bake for about 30 minutes when I had to mount a set last year.
2015 Bianchi Intenso
Likes For malcala622:
Quoted: 2338 Post(s)
Liked 5,121 Times
I'm running them on a variety of new and old rims and haven't found them that tough. I'll warm up any tire I find tough to mount before I resort to my tire tool.
The last set went on some newer first gen Fulcrum Racing 0's and the last bit was tough. Overcome with some spit on the rim and strong thumbs. These rims are like 15mm internal with no deep center channel. So nowhere to push the bead to get me so looseness for the final bead set over the rim.
Steel is real...and comfy.
You've mentioned "Capton" tape several times.
Is "Capton" a brand name or do you refer to "Kapton" tape.
Kapton is a brand name for a polyimide film. I've never before heard of Capton and a quick search yielded nothing..
feros ferio
Liked 1,339 Times
I am going to try that right now.
Quoted: 1959 Post(s)
Liked 2,051 Times
I put a pair of new GP5000s on a 95 Cannondale with Wolber somethings and they went on like a new pair of GP4000s--tight but I'm sure they will stretch. (I have recently made a bad decision by reusing a pair of Matrix rims on a new wheel build. I should have cut those wheels into little pieces. Nothing fits on them.)
Master Parts Rearranger
Quoted: 1557 Post(s)
Liked 2,029 Times
Sounds like what I've experienced. MA2/MA40s, especially with traditional Velox tape, make tire mounting varying degrees of difficult. I'm full Kapton tape on everything now. Two layers does it. 5/8" wide serves me well. Continental tires are also almost always snug, and Vittoria Corsas can be as well, though more amenable to sliding over a rim. I am not opposed to using tire levers, and for any of these, I've used only a single lever and that gets the job done. I've had to use three before--Campagnolo Atlanta 1996 rims were diabolical. I have a new pair of GP5000s in 32mm and they measure quite close to GP4000S II 28s. Go figure.
Likes For RiddleOfSteel:
Quoted: 992 Post(s)
Liked 658 Times
Clever. I wonder if I can fit a 700C wheel in the chest freezer as well?
Quoted: 1089 Post(s)
Liked 704 Times
