Long-pull inline brake levers?
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,011 Times
Any inline lever will work just fine. It is not doing the cable pulling. If you are looking for flat bar levers there are lots of options but my favorite would be Speed Dial 7s from Avid if not the Paul Love Levers.
Quoted: 2498 Post(s)
Liked 741 Times
Speed Dials are great but they are not 'inline levers'. I don't personally know of ANY long pull inline levers (Cross Levers), but if the o.p. says that Paul makes some, and they are ok with the $$$ then, who am I. But, if it were me driving (and it was) I would use standard short pull levers, and matching inline levers, and either get short pull calipers, or 'Travel Agents' to convert the pull ratios at the caliper.
Do they? The Tektro RL720s (for example) are described as compatible with cantis and road calipers, but not V-brakes.
Likes For Yan:
Must be symmetrical
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 191 Times
So yea - but the amount that it pushes the housing equals the amount of cable pulled. It isn't the anchor for the cable. You may find that you have to bring the lever to the bar to get braking... although you could just run your pads closer to your rim.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
So maybe technically they should be called “short push” or “long push”. But the bottom line is you still want to uses the right one.
Must be symmetrical
Sorry my comment was meant to be ironic, not start an argument , because this is clearly the basis of how all bike cables function. Just poking fun with a bit of Newton.
Advanced Slacker
Liked 2,537 Times
Yes, in a Bowden cable and housing system as found on bikes, pull of the cable and push of the housing are equal and opposite forces, they are equivalent and achieve the same thing. It doesn't work any other way.
And it is a good concept to understand. And now I know the name for it (Bowden Cable)
Quoted: 4806 Post(s)
Liked 3,933 Times
So, long push CX levers. Someone should step up and make them. Long push or LP. To use with linear pull (LP) calipers. I like.
Practical concerns. To get a longer push, the housing needs to stand further off the handlebar and seat at a higher location from the lever pivot. Also the housing will move more. I suspect that it will be a little harder to arrange this to be as tidy around and under the handlebar wrap. I'm guessing a couple of prototypes needed.
Clark W. Griswold
Liked 4,011 Times
Yes actually.
From Park Tool:
The in-line lever pushes on the housing, effectively making it longer, which causes the brake caliper to close on the rim.
