question about Malone 3.1 brakes
Bikes: Trek DS 8.4 Trek Madone 3.1
They are freaking LOUD!! I bought the 2013 new about a week ago. Most components are 105. Is it just because the pads need broke in or are they junk? I remember seeing a review where someone else complained about brakes and tires. I had the lbs change tires to Gator skins. Should I change pads?
Suggestions please
Steve
Suggestions please
Steve
Bikes: 2016 Emonda ALR 5, 2014 Trek 7.2 FX
They're probably tektro junk or something. 105 5800 brakes are wonderful.
Quoted: 8 Post(s)
I think the Madone 2.x and 3.x brakes aren't even the old Tektro 540 junk from before...they're even worse now. Anyway, if they seem to operate well, keep the brakes but swap the pads to salmon or dual-compound Kool-Stop pads. I did that with my older Madone 2.1 w/ Tektro's and it was a great improvement.
Quoted: 4806 Post(s)
Liked 3,932 Times
Also, do the pads have toe-in? Ie are the fronts of the pads closer to the rim than the backs? Can those holder accommodate toe-in if it is not there now? (With some brakes and some pads, you can loosen the nut that secures the pad, toe them in with your fingers and re-tighten. Or you may have to spin a lopsided washer around to get the toe-in,) Really, any shop setting up a bike that nice should be seeing to it that there is some toe-in to the brake pads. To not is violating a fact every mechanic worth his grease has known for the past half? full? century.
Ben
Ben
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Suggestions please
Steve
Suggestions please
Steve
Also, if you're getting a squeal, maybe scrub down your braking surfaces on your wheels with a wet rag and wipe the pads themselves too, a tiny bit of lube getting on the rims will make them sound awful when you brake.
Beware the caliper springs. I guess sweat worked its way into the spring on my rear brake, and it rusted and stopped giving resistance after about a year of owning the bike. I ended up buying a pair of new SRAM Apex calipers for something like $30, they seem to be much better and they match the crank on the bike so there's that.
So should I change the pads or the whole caliper?
Is this what I need?
Shimano Ultegra BR-6800 Brake Caliper
how difficult is it to change? I have every tool I could possibly need
Quoted: 1422 Post(s)
Liked 7 Times
You're on the right track, but there is a 5800 version ( 105 ) of those brakes ( breaks ) that will work fine also.
You should only need a 5mm allen wrench for the cable bolt and the mounting bolt. Might need a 4mm for the shoes, I can't remember right now.
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
Not you. The guy that I quoted #dangerd
Duke Ulysses
Quoted: 165 Post(s)
Liked 175 Times
More to the point, 5800 brakes are a great value, and work really well. Easy install, also.
