Question overhauling my pedals
Hi all, I'm new.
I'm trying to fix up an old bike. The left pedal makes a very strong click on down stroke, so I thought I would re-pack the grease. When I disassembled the left pedal, the outer race has 10 bearings, and the inner race has 12 bearings. The right pedal has 13 bearings in both outer/inner race. How many bearings are there supposed to be in each race? Do I need more bearings, or can I shuffle them for 12 bearings in each race?
I found this white lithium grease in my garage. It's opaque white, and a little runnier than the old grease that was in the pedals before. Is it good for this purpose? My local bike shop has the park tools polylube that I see people use in youtube videos, but I'm hesitant to get that giant tub when I'm only working on my one bike.
Quoted: 194 Post(s)
Liked 204 Times
If your right and left pedal are a matched pair then they both should have 13 balls at each end. The reason for the loud click is the shortage of balls, some of which have probably disintegrated with use (or been lost during a previous rebuild).
Leave the lithium grease where you found it, head off to your local auto or hardware store and get a tub of general purpose grease. People here can talk for weeks about grease, but nothing on a bike except a coaster brake hub is really under that heavy a load. It just has to stay in place.
I use white lithium grease when repacking anything on the bike, pedals, headset, hubs, bottom bracket, etc. It's white, not opaque, actually looks like Campagnolo grease, and it feels thicker than the Park stuff. You can get this stuff at Lowe's.
I don't know what kind of pedals you have, but the vintage ones I overhaul usually have the same number of bearings in both races, inner and outer. The count is often 13, or 26 in each pedal. Unlike a headset, you can normally pack a pedal race full of bearings without leaving any dead space.
Btw, is there any trick to pulling out the dust cover? I spent a long time prying with various screwdrivers, and ended up putting in a screw to gain purchase, but that left a hole that I'd have to caulk over.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Quoted: 6196 Post(s)
Liked 4,812 Times
Conversely, if putting it together and adjusting it, you have a lot of wobble and play occasionally but it otherwise runs smoothly (when it's not wobbling), then you probably don't have enough balls in it.
Quoted: 303 Post(s)
Liked 136 Times
[QUOTE=gululok;22227405
Btw, is there any trick to pulling out the dust cover? I spent a long time prying with various screwdrivers, and ended up putting in a screw to gain purchase, but that left a hole that I'd have to caulk over.[/QUOTE]
Use the shortest screw you have to fill the hole. Then, in the future when you want to lube the pedals, remove the screw and use a grease gun
with a blunt 'needle' fitting to inject grease into the hole til it extrudes from the other end of the pedal, replace screw and you are done.
This was Speedplay's standard approach to lubing their pedals and it works well. One indication for relube is a pedal that spins freely.
Lubed pedal will just spin a turn or so.
