Shimano 105 Brake
Shimano 105 Brakes
I just ordered a Cannondale CAAD 8 6 and saw that it comes with Cannondale C4 brakes. I was thinking of upgrading the brakes. Will the Shimano 105 be a good upgrade that is worth the money? Will it stop much better than the stock ones? I don't want to upgrade them unless it will be a noticeable difference. The weight savings if any isn't that important to me. Also, what are some good cheap pedals to buy? Once again I don't need anything fancy, just something to use for the mean time until I decide what route I want to go. I am new to road bikes, so sorry if this has been posted before. I tried to search the forum, but it didn't return any results because the words were too common. Thanks for the help.
Bikes: 2017 Specilized Roubaix, 2012 Scott CR1 Team, Felt Z85
Quoted: 26 Post(s)
I swapped out my no name stock brakes that came with my bike with 105's because they "spongy" on descents. I would wait to see if the C-dale brakes have any performance issues. If they do you can go the cheaper route and replace the the pads first.
Quoted: 551 Post(s)
Liked 277 Times
What type of pedals are you looking to get? Road specific, mountain, combination of platform and clipless?
If you are going to come off as a dooshy noob, trying to correct another with a veiled attempt at an insult, at least learn how to spell "brake" properly. Your style however, is atypical of a 41 member...welcome
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 646 Times
If your C-dale brakes are Tektros, I found Tektros (the ones which came on my Roubaix Elite) to be difficult to modulate well, especially on descents. They - Tektros - seem to work fine enough for inexpensive brakes. I chose not to bother with new pads, put on 105 calipers - big improvement. I think it's a worthwhile upgrade for riders who are finicky about braking performance.
Flying Pig
Bikes: 06 Specialized Allez Sport, '10 Trek Fuel EX 7
Try new pads like koolstop or Swiss as suggested. Most likely they'll last longer and perform better than the stock pads. Even better if the stocks are non-cartridge pads.
Note that new brakes/pads do take some time to "wear-into" the rim, a bit like disc brakes. So you may not notice much improvement from the start.
Bikes: 2010 Felt F5, 2010 Dawes SST-AL
No need to be confused CNY James you are a senior member. It's not good to be a confused senior. The guy is getting a bike without pedals, but tries to save money on them. At the same time he wants to buy overpriced higher line brakes (did I spell correctly or third time will be a charm?). I think OP should be confused, not you
105 brakes are the best mid-range brakes out there. Dura Ace brakes are the best in the world and Tektro's came out the rear end of a cattle.
World's slowest cyclist.
Bikes: Cannondale CAAD5 and Cannondale Rush
My front C'dale brake had too much toe in which was causing poor braking. I did a bunch of research on the Shimano brakes and basically their bottom of the line Sora is part for part identicaly to the Tigra (except for color/screen print name). At the 105 level you get a lighter brake with ball bearings to make it feel a little smoother. This won't help you stop all that much better. I recommend getting a Sora if you're not worried about weight and aren't super picky about how the handle feels.
I actually have rode the bike before. I tried to buy an exact one at my local bike store, but they sold it before I made the decision. They didn't have anything in my size. If you are not going to be helpful, then don't post in this thread. Everyone else has been very helpful so I appreciate that. BTW, thanks for the warm welcome.
I bought a roadbike, but it came without a saddle. With a saddle stem but without a saddle. I was so anxious to ride my bike that I rode it for hours like that. Now my butt hurts and I need to trash your thread.
Welcome to the forum. Beware not everybody will be nice to you.
But seriously, do you really expect your brand new brakes to fail on you???
No I don't expect them to fail. But whenever I get something new, I always want to modify it. I'm like Tim the Toolman from Home Improvement. More power!
Upgrading is most of the fun. That said, you would have saved some time and likely money by buying a better-specced bike to start with. What was wrong with the CAAD8 w/ 105?
I would have loved a CAAD8 with the 105, but it was around $455 more. The bike I bought was on sale. I figured I would be happier with the Tiagra components and I could always upgrade later if needed.
Century bound
Bikes: Felt AR4 and Cannondale hybrid
Welcome to the forum, I see you can think for yourself and are just looking for a little guidance. As you have already found, not all advice is good advice. For me, I think dollar for dollar 105 is hard to beat. Good luck with your new bike and ride safely.
Darn! If you buy 105s upfront how far are you going to upgrade it? I think 105s are the end of the upgrade road. Of course you can spend more money on it but with every dollar spend you get diminishing marginal utility. So why would you start with 105s and have such a short upgrade life. Isn't upgrading the "most of the fun"?
Bikes: BMC RoadRacer SL01, Kona Kula FrankensteinDeluxe, Schwinn Powerglide.
105 brakes are great. I think you'd be very happy with them. That said, see if the stock brakes perform for you first.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
You may also want to consider SRAM Rival brakes. I got mine for less than 105's and in test rides thought both were very comparable.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
brakes are overated. I have tektros on a couple of bikes and ultegra brakes on a couple of bikes. the pads make all the difference. you'll be fine with the tektros, just make sure they are set up right and the pads arre good.
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
When I switched from the stock Tektro to 105 on my old bike it was a huge disappointment. Good for the bling factor, but I doubt you will notice any practical difference. The mechanics are pretty much the same as is the weight. Like others have said, pads will probably make the biggest difference. Get the 105's if you want the 105 logo...but don't expect a performance difference. Based on this I decided to not "upgrade" the Tektro brakes on my Defy 1.
