Eureka! Nishiki GRAN TOUR 15
Quoted: 801 Post(s)
Liked 754 Times
(Please excuse the mess. It's Monday.)
I have been searching for a nice tourer for a good long while...About 8 years now. Certainly, there have been opportunities that I passed on that would've been fine. But nothing that really met all of the requirements:
- Room for ~38mm tires and fenders
- As many braze-ons and eyelets as possible
- ~57cm top tube (so many tourers are looooong for their size)
- High quality tubing
- Non-canti brakes if 27" to avoid possible incompatibility w/ 700c conversion
- Standard threading/diameters all around (no french, please)
- Vertical dropouts
That last one, vertical dropouts, was the hardest. The bike is a tourer and it will wear fenders, but horizontal dropouts + attaining a perfect fender line is not the easiest. I've seen people use springs and other doohickeys to get the fender close to the tire but then able to shift when removing the wheel...probably not the most difficult thing to set up but I was hoping to avoid all that.
Anyways, after moving to the Bay Area I knew there would be a bevy of high quality vintage frames all around. Just a matter of keeping a watchful, if passive, eye. At first, only the Bay area was under consideration via Craigslist, but after realizing how many people only use Facebook Marketplace I gave in to trawling endlessly through Facebook's terribly organized website. Lo' and behold, did something pop up around Sacramento, not far from where I work once a week.
The Nishiki Gran Tour 15 is not easy to find online. Most mentions are its slightly newer iteration, the Ultra Gran Tour. Seeminly identical, and luckily in the 1981 Nishiki Catalog (truly a dearth of catalogs compared to some other brands).
The Ultra Tour 15 is "state of the art" in touring bicycles, with featherweight chrome moly double butted tubing and carefully selected touring componentry. It is not only luxurious but also affordable.
My favorite qualities? Well, as said before, the vertical dropouts are choice. As well as the non-canti brake calipers, and the huge tire-fender clearance, I've seen others run this model with 37mm tires plenty of room to spare for fenders. The Ukai 27" rims are cool, too. Nice aluminum box sections in fairly good true, but they'll need some attention and possibly a couple spokes replaced. The chrome plating is pretty sweet, too.
Plans for the future...keep it as close to stock as possible for a good while. Just a good full overhaul, and probably replacing the tires with Paselas even if the guy who sold it said the tires are new. Probably handlebars, too. And, after enjoying the bike for a year or two, if it indeed IS 'the one', an oxalic acid dunk, spreading the frame to 130mm, building a custom wheelset with proper box section rims and a dynamo front hub. Changing the gearing to 48-34 in the front and 12-32 in the rear, 9 speed And that's...it. It shouldn't require anything else to be replaced, and it'll look damn near identical to its stock setup, just with better gearing and wheels. Haven't made a decision on the paint. It's pretty rough in some spots.
More pics below. I'll do a proper photoshoot after taking the overhaul. Might take a month or two.
Likes For Piff:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2200 Post(s)
Liked 4,634 Times
That looks like a very nice frame! Double eyelets are a definite bonus when using racks. What frame angles and fork offset?
Likes For non-fixie:
Bikes: Old Carlton frame and fork. Old Nishiki frame and fork, single speed build? 2003 Scattante full carbon/Ultegra. 90’s trek steel with full 600(purchased for the components) Also vintage K2 full suspension
Quoted: 22 Post(s)
Liked 32 Times
Sweet good find! Paint detail on forks is nice
Quoted: 801 Post(s)
Liked 754 Times
Regarding eyelets, depending on if I really like the frame my plan in the future is to also add mid-fork eyelets, centerpull posts, seatstay rack attachment points, more bottle bosses...etc. Repaint in the same colorway, too. There's a set of decals on ebay I've got my eye on...
Thanks! I was stoked to find it, even if the paint is a bit rough in places. The detailing also caught my eye, on the fork ends, the lug cutous, and the bottle bosses too. Plus, Nishiki getting the seatpost and cranks filled in to match the frame decals. The lugs aren't thinned/filed at all, but seems to be good brazing all around. Another interesting detail is that the dork disc passed the magnet test-- it's aluminum!
Shifting is fun!
Bikes: Yes, please.
Liked 4,634 Times
There are different levels of dorkiness?
Quoted: 795 Post(s)
Liked 1,797 Times
I like the semi vertical dropouts that are in alignment with seat tube makes for some really nice clean lines,
Likes For zukahn1:
Quoted: 5890 Post(s)
Liked 3,475 Times
Good looking bike. Bikes that came stock with 27 inch wheels and center pull brakes with reasonable reach tend to have good clearance for tires and fenders. I have a 70s era Raleigh Gran Sport and Motobecane Grand Record; both can take tires with reasonable volume and fenders but neither has vertical drop outs.
Likes For bikemig:
Quoted: 801 Post(s)
Liked 754 Times
I'm pretty far gone by my own measuring. Dorkiness levels ascending:
Using a dork disc because it came on a bike >>> Buying a dork disc to put on a race bike >>> Finding it curious that a disc is aluminum >>> Being excited that a disc is aluminum and thinking of ways to fit it onto a freehub.
Likes For Piff:
Quoted: 801 Post(s)
Liked 754 Times
Okay, for the life of me I cannot figure out how to remove this shifter clamp. Suntour LD-1600, if I'm not mistaken. https://www.velobase.com/ViewCompone...a162d&Enum=104
Any advice?
Any advice?
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Any advice?
Any advice?
These clamps tend to be sticky- after backing it off a turn or two, tap it lightly to get it loose from the frame. To get it off the frame, you’ll need to back it almost all the way off and then disengage the block from the straps of the clamp.
Reassembly is the opposite, and keeping the ends of the straps engaged with the block while tightening everything is a trick. I’d make sure the threads are good, clean, and lubed before trying to reassemble everything.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 801 Post(s)
Liked 754 Times
SunTour went crazy for “endless clamps” back then. It works kind of like a brake lever clamp, where there’s a small block that’s drawn tight by a nut on one side. I see a hex- stick a wrench on it and see if it turns counter-clockwise.
They're very nice shifters, incidentally. Smooth, non-slip construction, lightweight, what's not to like!
Quoted: 765 Post(s)
Liked 660 Times
I vote for not painting. I would not give it an OA bath, either--it seems pointless in this case.
Touring bikes are supposed to look well-used. You're good.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 801 Post(s)
Liked 754 Times
There is some rust weep from a couple drain holes, and a little at the top of the seat tube, but most everywherr else is clean. I just would prefer to do a soak if I plan to keep it forever. Can't hurt, and I'd like to do it once to learn.
