Moved to new house with large hill
So I just moved into a new house and there is a significant hill to get to the house from where I normally ride. It’s not super long but the gradients are high and after a long ride on the flats, I’m beat. My bike has 12 speed 48/35 up front and 10/33 on the back. Gearing wise, is there a change I can make that will attack a fairly steep but not super long climb after I am tired from riding?
www.mp-aviation.com
www.mp-aviation.com
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
How come cycling terrain was not #1 on your location requirements?
ps
HTFU
pps
One of the fastest guys I know lives at the top of a killer hill. Give it time, they get smaller every time you climb them.
ps
HTFU
pps
Likes For znomit:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
SRAM Force XG-1270 12-Speed Cassette | Competitive Cyclist
If the 36T sprocket is not enough, then install even smaller chain rings (46/33, or even 43/30):
X-Range Gearing | SRAM
Otherwise, consider reducing the distance elsewhere to save more energy for the final climb back home. If none of the above works, fake a mechanical and ask your significant other to pick you up.
Likes For SoSmellyAir:
Liked 1,471 Times
It probably was. Like Eddy Merckx sort of said, don't buy upgrades, buy a house on top of a hill.
Quoted: 874 Post(s)
Liked 2,288 Times
I bought my house on top of a hill 24 years ago and still walking for the last segment of the ride. I ride vintage steel racers and have just accepted it with a 41 small chainring and a 28 large cog. At my age it’s ok . If I switchback I can make it part way sometimes but after 35-45 miles I would rather walk. I have made it on a mountain bike or a modern hybrid with some very low gears but I don’t like riding either bike. I gave the mountain bike to a homeless guy and the hybrid just sits in the garage. The three climbs are very steep and there is one that is a challenge even by foot. The other two I can ride One of my neighbors puts his bike in his car and parks at the bottom of the hill and that works for him. As far as living on the flats, I really enjoy the view we have , “ living with the hawks”. I could never go back to not waking up to the sunrise over the mountain tops.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Also, you ride a 10-33 6 speed cluster?...that doesnt sound right.
Quoted: 590 Post(s)
Liked 445 Times
I also just moved to a home that causes most of my rides to end going up a steep and sustained hill. And even with 34/32, I have issues making it up after a long day in the saddle. So I bought a 1x gravel bike with 40/42, and that did the trick, although with 40/11 I now lose the ability to go DOWN that hill with any kind of speed. Trade-offs.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
Congrats on the new house.
Presuming knees aren't an issue I'd keep the current gearing and htfu. As you say, it's just a short hill.
Likes For stevel610:
The 46/30 crankset is a popular one for good reason. The 30crank/33 combo is about 1.5 cogs lower then your low gear now. Also you will get stronger climbing that hill, Even after a long ride. While the 46T cog maintains most of your high gear. I agree the 10/33 cassette or freewheel doesn't sound right. 48/30 is an insanely high 130 gear inches. If you are correct about the chainring this change will still be valid. You may need a new front derailleur, not sure if the rear one can accommodate a few extra teeth of take up
I have a similar problem, but my hill is so long and steep that it is a day's ride in itself. I bought a nice hitch rack and drive my bike down to a parking lot at the bottom of the hill. My ride starts from there.
Sunshine
Liked 7,491 Times
No? Ok. Thats the confusion that happens without a ton of details.
A 46/30 subcompact sounds perfect then since 46/10 as a gearing ratio will be plenty for most people and the 30t ring will help with spinning on the hill.
Edited- I confused myself by merging 2 posters into 1. A different poster said they ride C&V.
OP- just get a drivetrain that has ratios which work for your new riding.
Quoted: 966 Post(s)
Liked 1,629 Times
Changing you Cassette and even your crank is the way to go. It's not much considering how much ya need to spend on a new house. Fit it in the budget with the new drapes and throw rugs. Long ago I went to a 34T Bailout gear on my freewheel and a compact crank with a 34T chain ring.
It's embarrassing to admit how much time I now spend in that Bailout gear for sure...
Liked 1,471 Times
No, I initially thought that too, but figured out he has a SRAM 2 x 12 setup. In this setup, the front derailleur allows a 13 teeth maximum difference between the two chain rings.
VFL For Life
Bikes: Velo Volmobile
Quoted: 28616 Post(s)
Liked 1,857 Times
Administrator
Quoted: 11971 Post(s)
Liked 6,651 Times
You must be a new neighbor of mine. Welcome!
Quoted: 6195 Post(s)
Liked 4,810 Times
How long have you been climbing that hill? You might just need to keep at it for a few more rides. You legs will adapt.
For a short climb, as you said it was, I can't imagine the 35/33 isn't enough.
Likes For Iride01:
Liked 1,471 Times
Quoted: 767 Post(s)
Liked 1,740 Times
You can ping pong solo as well...also Tennis...I can't tell you how much time I spent hitting the ball against the concrete wall
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Dig deep and ride it. A good step hill is an excellent bonus workout when you're already fatigued.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Same problem here.... Bay Area, House on Hill.
Started out using Cleat Covers and walking it... The walk of shame my wife called it.
Really bad day (usually HOT), I have the wife drive the SAG wagon and come get me
I've been known to drive down to the local park with the bike in the back and start from there
I have even taken BART home on occasion.
Be inventive, but don't let it stop you riding, you'll get stronger.
I now bike up it knowing it's going to be a ~300W climb... short but sharp.
Gearing down definitely helped, it takes some research to look up Front/Read derailleurs and how their capacity is specified by the manufacturer.
I changed my cassette last week. went to 11-36 and I'm enjoying it.
If you want specific recommendations, you will need to post exactly what equipment you are currently using.
Mine as an example
RD-R8050-GS Rear Derailleur
FD-R8050 Front Derailleur
R8000 50/34 Crank
PG-1170 11-36 cassette (Yes this cassette is over the Shimano Specs and should not be installed)
Barry
Mine as an example
R8000 50/34 Crank
Barry
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I have about a 2-mile climb back to the house if riding road. MTB- hardly any since I have 40 miles of trails all over me in the mountains. I had to harden up. It is only 2 miles, so not awful unless it is 90+ out. I do run a compact here in Colorado. 50/34 and 11-28 (though I wish I could do 11-32, and I may eventually).
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
OK everyone's talking about a bigger cassette and smaller crank but totally missing the most obvious and simple solution: You know those launchers they have on aircraft carriers to get the planes up to speed enough for takeoff? Just install one of those at the bottom of the hill.
