32 vs 36 Spokes?
#51
Quoted: 4806 Post(s)
Liked 3,928 Times
Yes, you are right. I stand corrected. i was thinking TT and road speed. This thread is about racing the wheels on a bike stand. (Where are we going to find a stand for Didi's bike?)
#52
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
#53
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
So here is a question is 36 spoke but done with titanium spokes lighter and better then 32 with steel spokes? I've heard 24 spoke wheels are more Aero but I also can't help but think it might be the shape of the rim.
In the early 90's I remember the 32 spoke craze hitting the BMX scene but people quickly realized that they could build a 36 spoke wheel lighter and stronger. But that's also when double walled rims started showing up but by then 32 spoke was already passé. The 32 spoke wasn't really transferred over to BMX but more so MTB.
old school HUTCH BMX articles 1986-87 (jjrbmx.com) I can't find the original article but..
Diamond Back Turbo Lite Rim (It was full of diamonds cut out of it) 27 oz, (I happen to know that the regular version was about 445 grams or 15.7oz and this one had Diamonds cut out) 13.5 oz =382.72 grams per rim
Spoke SRP titanium = 7 oz. I think it's safe to divide these by 2 = 99.22grams
Hub = Hutch aluminum with titanium axles 14oz (Pair) I think they listed these as a pair because the rear is obviously going to be heavier then the other. It's cheating but I'm going to divide it by two. 198.5 grams
= 680.44 grams per wheel or 1360.88 grams for the wheel set.
When I check the vintage Araya catalog BMXmuseum.com Reference / 1980-1995 Araya Catalogs Some of the road bike rims show a 10 gram difference between 24 and 36 spoke but the BMX ones seem to be rated the same.
I couldn't find 32h hubs with the weights listed. I used this site to calculate spoke weight. Spoke Weight Calculator | SpokeService | Canada's Bicycle Spoke Supplier
Rim = 455 grams
Spoke = 222.4grams (Saipan Race)
Hubs = 198.5 grams (I decided to use the same Hub they did though titanium axels were hard to get bitd.
= 875.9 gram which is 195.46 grams heavier.
One interesting thing about the spoke site is you can easily see the difference in weight between 32 and 36. And depending on the thickness of the spoke you can save up to approx. 30 grams.
Rim = 455 grams
#54
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I'd just like to point out that these are definitely not sub 1500g 32 spoke wheels.
I know that it's entirely possible to build a sub 1500g 32 spoke wheelset, particularly for a rim brake setup, I just don't understand why anyone would do this.
A lightweight 32 spoke wheel is compromised on both ends of the spectrum. If you are chasing grams, there's little sense in building with extra spokes. If you are worried about strength, there's little sense in building with ultra-light parts.
You can put snow tires on a Corvette.
It's like riding a bicycle
#56
As someone with a bike that has 36 spokes and another with 32, my main concern is that the wheel is of sufficient quality to get me from point A to point B via route C. I suspect riders looking at wheels based on the aerodynamics are not using them to commute or a utilitarian purpose and instead racers and amateur time trial type of rider.
#57
Liked 2,971 Times
-Oh Hey!
-Oh Hey!
#58
lots of interesting info out there, this site covers a ton of new wheels>
https://www.hambini.com/testing-to-f...icycle-wheels/
highlights of above link>
this site is also a fun read>
https://blog.silca.cc/part-5-tire-pr...d-aerodynamics
did you know that a worn tire can be a drag?
- Wheels that performed well were noticeably resistant to generating areas of turbulence
- Wheels that performed well mitigated generated turbulence quite well
- Wheels that performed well had a lower rotational drag compared to their competition
- Wheels with a deeper rim section are generally more aerodynamic than shallow sections
- The difference between wheels of a similar depth is very small and it would be difficult for a human to be able to detect this during riding
- The difference between a low profile wheel and a deep wheel would be picked up by a human riding.
- The FLO cycling and Hunt wheels performed badly, they appear to have been designed by individuals with a limited understanding of aerodynamics of rotating objects. As such they generated unnecessary separation and could not deal with the separated airflow
- The Aerocoach disc and 75mm deep section front wheel showed quite interesting results. This wheel was essentially an aluminium wheel with a clip on fairing. At low to moderate speeds, the wheel performed reasonbly but as the speed was increased the wheel started to perform quite erraticaly. The front wheel construction is agriculturual and large gaps exist between the spokes and the non structural fairing. These gaps generated pressure disturbances and caused the flow to behave erratically. As the speed was increased, it’s performance became quite poor in comparison to the immediate competition and this was mainly due to the poor front wheel design. A picture of the problem is shown below
#59
starting to understand how over inflation can actually slow you down,
as the tire becomes harder, your body starts to bounce around more, with rough pavement compounding the effect,
https://blog.silca.cc/part-4b-rollin...-and-impedance
"Impedance
Tom Anhalt was one of the first to take tires used in roller testing into the field to try and replicate data. What he found was quite a shock!
While the data matched at lower pressures, the real world data diverged somewhat dramatically from the roller data at higher pressures!
This divergence is the result of impedance losses overwhelming the system as the tire is over-inflated. Most interestingly, this initial test was done on 'good' asphalt, which really brings up questions about lower quality surfaces.
The new theory on Rolling Losses is that both Surface Impedance AND Casing Losses were adding together to create total rolling loss. "
"Impedance
#60
no wonder they like the big tires and lower pressure at Paris Roubaix
"This theory predicts that below the Breakpoint pressure the system will be dominated by Casing Losses (though still affected by impedance) and at higher pressures the system will be dominated by Impedance Losses, though still affected by Casing Losses.'
#61
Off grid off road
Large wheel diameter would effect aerodynamics too- longer spokes create more drag.
Therefore a BMX wheel would be the best option
#62
Liked 2,971 Times
wheel dish will change the efficiency based on purpose & environment conditions. ITE, I'd rather roll with the weight penalty of having more spokes than fight potential hazardous crosswinds.
-Oh Hey!
-Oh Hey!
#63
Wheel dish is fixed by hub design; it can not be chosen to fit conditions. There are only two choices for wheel dish: correct or incorrect, and as long as it's correct has no effect on "efficiency" (whatever that is).
#65
I would think that anyone, regardless of occupation, who communicates in either their professional or personal life would be in favor of clear language.
#66
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Likewise, I think cyclists sometimes use terms that make sense conceptually, even if they are not exactly correct. "Pedal circles" is a common technique for pedaling efficiency (yes, I just had to use the term... couldn't resist), but no matter how good or bad your form is, you're pedaling circles because the cranks won't spin the pedals in any other pattern.
To a layman, "efficient" just means what we can sustain for a longer time period, or optimum for a level of exertion. We don't necessarily realize that the actual amount of energy consumed isn't the factor there, and honestly, we don't care. Regarding that other thread, I would be annoyed if someone told me, "60 RPM is the most efficient cadence... but you don't want to do that".
Likes For urbanknight:
#68
Liked 2,971 Times
My fault for the wrong word used, but I'm referring to the rim thickness. An 80mm rim will "cut" the air better when going straight when compared to a 30mm rim. That's comparing like materials used & quantity of spokes.
-Oh Hey!
-Oh Hey!
#69
Quoted: 3352 Post(s)
Liked 1,056 Times
I would still like to know the difference between a 32 spoke wheel and a 36 spoke wheel. Does anyone know.
#70
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
