Cannondale Topstone Shimano 105 front derailleur cable routing issue
Hi Guys,
I've got a new Cannondale Topstone Carbon 105. During shifting the front derailleur shift cable jumps off the cable routing at the derailleur. This happens during shift to the smaller gearwheel. I can't link the video as I am a new member.
This causes the cable to loose a friction of tension and the derailleur's inner plate get's in contact with the chain.
Is this a normal behavior? I don't think so. Any other Topstone drivers having this issue?
Thanks
Cheers
Julian
Thanks
Cheers
Julian
Quoted: 3242 Post(s)
Liked 2,090 Times
If it's new, take it back to the shop. Sounds like the cable is installed incorrectly. I have an aluminum Topstone and do not have this problem.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
Not only isnt that normal, I dont actually understand the issue its so far from normal. The cable should never jump of of its routing at any point.
Hope its a quick fix!
Likes For mstateglfr:
Thank You for your comments. I really would like to show you the video clip of the cable slipping sideways. But I can’t ’cause I am new here. Can I PM the link to someone posting it for me? Thank you. I appreciate your help.
Edit/PS: can‘t return it to the dealer quickly as it was shipped.
Liked 2,090 Times
It's the Shimano 105 front derailer (series 7000). Do a YouTube search for installation and service. You'll need a metric Allen key set - I think it's a 5mm, might be a 4. Shimano also has the dealer service instructions on their website, that'll show you how the cable is supposed to be installed. Or take it to any local shop, they will probably work on it, but there's often a huge wait currently do too CV.
Thanks.
i‘ve already taken it to a local store. The said the design causes the slip off. Because the carbon frame has the cable hole further to the rear. That causes the cable to run angled into the derailleur. That‘s the same the dealer told me on the phone. However this always causes the bandwidth to be shifted cause the cable has a longer distance to travel when slipped off. I can hardly believe that‘s normal. If it is the case - it‘s a clear and serious design error by Cannondale.
Sunshine
Liked 7,496 Times
I don't think you can PM till 10 posts either.
Any shop can work on this, its effectively a universal component since it is on many bikes in every shop(in 105 or Ultegra level).
It‘s not about adjusting the Derailleur in general. It‘s about the cable routing arriving angled at the Derailleur causing an offset. I have bern to a local shop with it.
Liked 2,090 Times
And not for nothing, have you contacted Cannondale or the original dealer ?
Thanx Steve. I‘ve joined the Facebook group
yeah I‘ve contacted the original dealer. He said it‘s just the way Cannondale builds this bike. Not sticking 100% to the Shimano rules as the cable does arrive angled at the Derailleur.
I‘ve tried to contact Cannondale. They don‘t have an office in Germany and are not very responsive at the European office. If I can‘t find a solution I will contact Cannondale USA.
