Tourney 7 speed shifter alternatives
I had a bike mishap and broke the Tourney SL-TX50-7R shifter.
I am having a tough time finding one. No one has stock and they are pricey.
Can I use any Shimano 7 speed like a SL-TX30-7R as a replacement or does the shifter have to match the Tourney rear derailleur?
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Any Shimano 7 speed shifter will work.
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
Yes, any Shimano 7-speed shifter will do.
Cantilever believer
Quoted: 538 Post(s)
Liked 1,846 Times
I'll be honest - in over 40 years of working on bikes, I'd never seen a shifter quite like the Tourney SL-TX50-7R until one showed up on that Columbia bike I'm discussing in my other thread in C&V.
My first reaction: "That's goofy as heck. Thumbie downshifts, pushbutton upshifts."
My second reaction: "Maybe that'll be fun."
So I grafted it onto my commuting bike, shifting a 7-speed 13-25 freewheel using a old Suntour Accushift short-cage derailleur at the other end of the cable.
And it works great. Once I try to get out of the habit of yanking the thumbie down to upshift and instead push the little clicky button. I might keep it there for a while.
Meanwhile: as others have said, any standard 7 speed index shifter (thumb, Rapidfire, bar-end, twist, whatever your preference) should provide acceptable shifting performance.
But if you really want to keep the "mutant lollipop" design of the SL-TX50-7R, then the e-commerce links listed in the replies should be helpful.
Quoted: 540 Post(s)
Liked 416 Times
Any LBS will have new parts that will be an immediate upgrade, Shimano or not.
This is also the time to consider a grip shifter if you prefer.
Likes For soyabean:
Can anyone suggest a better shifter than the Tourney. It is a plastic affair and quite fragile. It does work well though.
I can't use a grip shifter because it is on a fat ebike and there is a throttle control between the brake and a small handle grip on the right side.
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,006 Times
I wouldn't really recommend any shifter to replace a tourney shifter but a bike that doesn't have tourney anywhere near it. Tourney is designed to be purely low initial cost and that is about it, no durability or quality in sight but as much cost cutting but still have something semi functional. Microshift makes an 8 speed thumb shifter which would be of some quality but you would really want to have 8 gears at the back since it is an 8 speed shifter but 8 speed these days is also of low quality. 8 speed came out in the late 80s and early 90s so 30 years ago now we are in the 12 speed era so the quality really sort of hits at 10 speed and sometimes you can find some bits of 9 speed that is still decent and not just old stuff.
Likes For PDKL45:
Quoted: 539 Post(s)
Liked 466 Times
My mistake. sorry.
Quoted: 1563 Post(s)
Liked 1,737 Times
They are all metal and they will last you till the end of time. Only drawback is that they are not ratcheting shifters. It's just a simple indexed lever.
Likes For icemilkcoffee:
Quoted: 539 Post(s)
Liked 466 Times
What I would do is get a 10 speed microshift shifter and run it in friction mode. It's my favorite method and has for me eliminated all fussiness of perfect cable tension and perfectly lubricated and micro adjusted components. Once you learn how to properly shift all you need is to have the inside and outside limits of the derailleur set. With the 10 speed friction I can change to a different wheel cassette set up very simply.
Cantilever believer
Quoted: 538 Post(s)
Liked 1,846 Times
Durable indeed, but I'm not sure if archaeologists thousands of years from now will find them in quite the same numbers as surviving Chicago forged Schwinn frames.
Likes For RCMoeur:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.ebay.com/p/1601403888
Quoted: 1401 Post(s)
Liked 1,886 Times
SHIMANO Acera ST-EF65 Brake/Shifter Combo Set
https://www.amazon.com/JKSPORTS-SHIM...r/dp/B07ZXZL3Q
and just $30 - free shipping
Cantilever believer
Quoted: 538 Post(s)
Liked 1,846 Times
My experiment with the "mutant lollipop" shifter continues. So far, so good. On a short descent I did accidentally try to force the thumbie downward without pushing the button, but it seems to have forgiven me.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
I believe this model is an upgrade :
https://www.amazon.com/JKSPORTS-SHIM...07ZXZHVBQ?th=1
Rhapsodic Laviathan
Literally any 7speed shimano trigger shifters will be fine- even other Tourneys that don't have that stupid button, I never seen before.
