Vintage bike pump
Old 08-04-22, 08:43 PM
SDHawk
SDHawk's Avatar
Bikes: 1986 Schwinn High Sierra, 1989 Supergo Access Comp, 1989 Nishiki Pinnacle,1990 Trek 750, 1990 Trek 970, 1991 Miyata Quickcross, 1992 Bridgestone RB-2, 2002 Stumpjumper M4 Pro
Quoted: 157 Post(s)
Liked 263 Times in 115 Posts
Vintage bike pump
Picked this up as an extra in a bike tools deal. It's old and heavy, and the seal is dried out or at least not pushing air. I can't read the label. Any guesses as to the make and if it's worth anything? Thanks.
SDHawk is offline
Old 08-05-22, 05:46 AM
SJX426
SJX426's Avatar
Quoted: 1607 Post(s)
Liked 2,216 Times in 1,103 Posts
Not worth anything if it can't pump up tires! 230psi!?
SJX426 is offline
Old 08-05-22, 03:07 PM
juvela
juvela's Avatar
Quoted: 3811 Post(s)
Liked 3,338 Times in 2,178 Posts
looks like it may be a Schieffer-Klut (SKS brand) from Germany
these were frequently private labelled, even VAR sold them
juvela is offline
Old 08-05-22, 04:38 PM
Mad Honk
Quoted: 1303 Post(s)
Liked 1,911 Times in 1,141 Posts
Any good old school hardware store should have a box of replacement leathers for one of those pumps. My local store has to hut for the box when I go into the store but there is always one of the leather parts I'm looking for. I may have to learn to mold the leather into a cup for some of the ones that come in that cannot be sourced by my hardware store. Look around some of the family owned hardware stores in your area. Smiles, MH
Mad Honk is offline
Likes For Mad Honk:
Old 08-06-22, 09:16 AM
branko_76
branko_76's Avatar
Quoted: 702 Post(s)
Liked 672 Times in 420 Posts
Nice pump, if you were nearby, I'd give you $25 for it
branko_76 is offline
Old 08-06-22, 09:29 AM
zandoval
zandoval's Avatar
Quoted: 966 Post(s)
Liked 1,629 Times in 1,045 Posts
Check that Gauge for accuracy when you can...
zandoval is offline
Old 08-06-22, 11:14 AM
SDHawk
SDHawk's Avatar
Quoted: 157 Post(s)
Thanks, doesn't sound too special.
Yup. I think that's what it needs. It was easy to unscrew the top and pull out the plunger. Is there any way to rejuvenate the old one?
Bummer, haha, but thanks anyway.
SDHawk is offline
Likes For SDHawk:
Old 08-06-22, 12:43 PM
Mad Honk
SDHawk,
Use a light oil on the leather and give it some time to soak into the leather. After about a day you should be able to massage the leather a bit and flare the ends back out away from the plunger. Another light coat of oil and a bit more soaking in, and you should be able to get some use out of the pump. Regular re-oiling should keep the leather compliant. HTH, Smiles, MH
Mad Honk is offline
Old 08-06-22, 03:46 PM
AngryFrankie
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times in 55 Posts
Try oiling the plunger inside. That silver cap at the top of the red shaft might unscrew.
AngryFrankie is offline
Old 08-06-22, 05:08 PM
SDHawk
SDHawk's Avatar
Quoted: 157 Post(s)
SDHawk,
Thanks a lot, I'll give it shot. Cap unscrewed easily, and the leather looks to be in decent shape and not dry/brittle.
SDHawk is offline
Old 08-08-22, 10:16 AM
smd4
Quoted: 3511 Post(s)
Liked 2,926 Times in 1,775 Posts
No need to check. It's already nearly 25 psi off the peg...it's not accurate.
smd4 is offline
Likes For smd4:
Old 08-08-22, 10:57 AM
ramzilla
ramzilla's Avatar
Quoted: 700 Post(s)
Liked 322 Times in 252 Posts
That looks like an old timey version of my made in France Lezyne tire pump.
ramzilla is offline
Old 08-17-22, 10:23 AM
J_Chickles
Quoted: 29 Post(s)
Liked 26 Times in 13 Posts
Maybe a Silca leather washer would work in that
J_Chickles is offline
Old 08-17-22, 10:24 AM
J_Chickles
Quoted: 29 Post(s)
Originally Posted by SJX426
230psi!?
Sounds nuts , but people used to try to get tubular track tires up to 180 psi or so regularly, -- sounds like a serious arm workout to me though
Old 08-17-22, 04:30 PM
zukahn1
zukahn1's Avatar
Quoted: 790 Post(s)
Liked 1,767 Times in 635 Posts
Not really nuts I have run all the tires on bikes slightly over pressure for years to carry the load of me 200lb give or take and the 20lb load pack cargo . As for the pump put some heavy weight oil in it and it it should start working fine these old stand up style pumps were made to use 90 weight half don't work because they were never oiled, which was considered dealer user set up.
zukahn1 is offline
Old 08-18-22, 05:29 PM
smd4
And the gauge was meant to be most accurate at about 115 anyway.
smd4 is offline
