Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Knee Height?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Knee Height?
Old 04-21-15, 05:54 AM
12strings
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Knee Height?
So, I know you are supposed to measure you seat height by examining your bottom stroke...but what about the top stroke?
I'm curious, at proper seat height, how close to horizontal does your femur get when pedalling?
12strings is offline
Old 04-21-15, 06:42 AM
AnthonyG
AnthonyG's Avatar
Quoted: 3450 Post(s)
Liked 420 Times in 289 Posts
If your femur gets anywhere near level at the top of the stroke then your cranks are WAY too long.
This is also the fly in the ointment for your original question. While the knee bend at the bottom of the stroke can be set similar for different crank lengths the top of the stroke will vary greatly for different crank lengths.
What the right answer will be will also vary for different postures. If your sitting upright then your femur getting closer to horizontal might be OK. If you want to adopt an aerodynamic tuck then you don't want it to get anywhere near level.
Anthony
AnthonyG is offline
Juan Foote
General Cycling Discussion
4
02-28-17 12:40 PM
Muskoka
35
08-27-15 09:25 AM
thylton48
Bicycle Mechanics
23
06-10-15 09:46 AM
vol
Bicycle Mechanics
62
05-15-13 09:18 PM
c12mech
6
05-15-13 03:20 PM
