Help With Frameset Identification - SAB??
Hello,
Can anyone identify the model of this frameset? Thanks,
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
You will most likely have more luck in the C&V forum. Click the red ! next to your post and ask that it be moved, if you want it in that forum.
Ive read about the company and can confidently say this is from no earlier than 1990(the company wasnt around before then) and almost for sure no later than 1999(based on the headset).
I would guess 1993, but who knows.
The Zero Tre tubing used was the 3rd level of Zero tubing. It went Zero, Zero Uno, and Zero Tre.
hope you find out the model.
Likes For mstateglfr:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Look for date codes on the components.
