Removing tubular glue
Old 05-17-07, 11:04 AM
Gnarboots
Armageddon wasted.
Bikes: Cinelli 84, Masi 83, Bareknuckle, GT Mach 1
Did a pretty sloppy job on a tubie gluing yesterday (tires were EXTREMELY tight, even after a 48 hour pre-stretch) and I'm wondering what y'all have found works best for cleaning up excess glue on tire and rim.
WD40 on a rag was recommended, but seems almost ineffective. Vitorria pre-buff just seems to spread it around, and has the unpleasant side effect of getting me high as a kite.
Any suggestions?
Gnarboots is offline
Old 05-17-07, 11:08 AM
BostonFixed
Acetone and/or Laquer Thinner. Be-sure to wear gloves and work outside...
<----Gluing his tubulars soon
BostonFixed is offline
Old 05-17-07, 11:10 AM
heliumb
If time is on your side, you can use 3M Safest Stripper*.
It's has the consistency of yogurt & no fumes.
Better yet, use Tufo tape next time. It's too easy.
*I don't know if it's ok on carbon fiber.
heliumb is offline
Old 05-17-07, 11:55 AM
pitboss
cxmagazine dot com
pitboss's Avatar
Bikes: Titus road, Fort CX
you can also use VERY FINE sandpaper to remove really stubborn residue
pitboss is offline
Old 05-17-07, 12:34 PM
auk
Coasting makes you grumpy
Bikes: Specialized Stumpjumper M2Comp; Habanero Ti-Team; Slingshot Road; 1962 converted Raliegh fixer aka: The Beast
The spit of a rabid vampire bat. Takes off all but the most stubborn glue. Kinda pricey, but the best always is.
If supply of the above is short, you can always rely on Goo Off or Opps. Add a bit of elbow grease and it should take no time.
auk is offline
Old 05-17-07, 02:45 PM
Bikkhu
sVe
Bikkhu's Avatar
Bikes: Nishiki Continental fixed winter beater, Fixed Surly CrossCheck
Bikkhu is offline
Old 05-17-07, 02:48 PM
goldenskeletons
dan bones!
goldenskeletons's Avatar
Bikes: iro mark v for street, sh itamori peloton for track
i used acetone. but it requires lots and lots of elbow grease. and somewhere well ventilated. i've heard nail polish remover does the job well too.
goldenskeletons is offline
Old 05-17-07, 05:03 PM
redxj
N+1
redxj's Avatar
Bikes: A few
Liked 5 Times in 5 Posts
FYI nail polish remover is acetone
redxj is offline
Old 05-17-07, 05:37 PM
p3ntuprage
p3ntuprage's Avatar
Bikes: a tvt soon to become a s/s...
the residue from tufo tape [atleast the extreme stuff] is even worse than normal glue.
but i still use it because i'm certain that i'm never going to roll a tyre with it, and it makes things oh so simple.
in answer to the original question: wire wool with acetone or aerosol carburetter cleaner.
[remember to use proper gloves though. acetone eats through washing up gloves]
fsnl
sparky
p3ntuprage is offline
Old 05-17-07, 05:38 PM
p3ntuprage
p3ntuprage's Avatar
nailpolish remover, if it does have acetone in it [not all of them do any more], doesn't tend to have it in high enough concentration to be useful.
just get a bottle of the pure stuff from the chemist.
fsnl
sparky
