Rim drilled for schrader ... using presta tube
My back rim accepts a schrader stem but I've been using tubes with presta stems.
I know some say that the stem can get ripped off when the tube slides. Is this true? I'm planning a week-long tour and I'm wondering if I should address this before I go.
I bought the bike used and it came with two different rims.
What is the easiest/cheapest solution? Get a tube with a schrader stem and get a bike pump that can handle both?
I haven't had to buy/shop for tubes for this bike yet. Do most 700 x 28c-32c tubes tend to come with a certain stem (schrader/presta) or can you get either?
Thanks
Thanks
You can get little adapters, basically a bushing, but I think they are optional. I personally would just use the presta tubes and not bother with the bushing.
Quoted: 34 Post(s)
Liked 17 Times
I use Presta-valve tubes on my MTB rims that are drilled for Schrader w/o problem. If you want belt-and-suspenders, try either a rubber grommet in the rim, or use threaded valve stems with lockrings.
Quoted: 3480 Post(s)
Liked 1,476 Times
I however recommend that you get the little bushing that goes into the rim before you put the tube in. There are a couple manufacturers, I use these.
https://wheelsmfg.com/presta-stem-savers.html
You should be able to call around to find a bike shop that carries these or similar products.
I personally prefer Presta tubes, some prefer Schrader. If you think you prefer Schrader instead of Presta, instead of buying the adapter you might want to just change your tube to Schrader and buy a few spare tubes with that valve.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
I got some of the rim bushing/adaptors from my local bike shop so I can use Presta tubes in all of my bikes (including mountain bikes) because I had Schrader and the Prestas work much better with my pump. The adaptors cost about $1 if I remember correctly. I would be concerned about damaging the valves and getting flats without using the adaptors.
While we're at it I wonder how many people have seen presta failures at the stem. I've used prestas on all of my tours and the few times I've been forced to replace a tube has been because of cracks at the joint between the stem and tube. I have yet to see the same kind of failure at a Schrader stem/tube jct. now that I've been using such on my front wheel for a couple of years. The prestas were all run in a presta-drilled rim. A full day of riding in the rain preceded at least one of the stem failures.
Also FWIW in response to the OP, I also run both types of tubes as you can see. From my experience you can't buy a good quality frame pump that doesn't convert (but don't drop the little central reversing dohicky down a drain while you are doing it) from one valve type to the other.
You can probably make due with throwing a washer over the valve. Another option would be to take an old dead tube and chop out the valve and add that over the new valve for extra protection.
I just put a small piece of electrical tape on the inside of the rim, poke a small hole in it, and push the presta stem through the tape. Never used the inserts, and never had a flat from using a presta tube in a schraeder rim hole. I do use the little nuts that come with the tubes to secure them a little better to the outside of the rim hole.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Running low enough air pressure and putting enough torque on a tube/tire to rotate it can rip the valve off a schrader tube just as easily as a presta tube. Mostly, the plastic spacers or adapters used with presta tubes in rims drilled for schrader balves keeps the threads from chewing up the rim when pumping up the tire.
Short of using those plastic inserts - a few companies like Schwalbe equip their tubes with a locknut with one side releived to fit exactly in a schrader drilled rim. Your local bike shop may have some lying around.
For the 50 cents the adapter costs, I think you should just spring for it. The ones I have just replace the securing nut on the valve with a slightly wedge-shaped one to fill the gap. Cheap, handy, and reduces the risk of flats.
I have seen someone do their valve in with a pump attached and the bike falling over and the person kept on holding onto the pump and didnt move it along with the bike as it fell, hence the valve ripping at base--but that is extreme.
really, I dunno what caused your failures, but from my experience and my friends over the years, I'd bet its probably something you are doing (unless of course the hole has some sharp bits in it or something, or the way you mount tires has the tube moving a lot and going up against the hole with pressure?)
Randomhead
Liked 3,720 Times
I've seen failures of both schrader and presta valves at the weld with the tube. The construction is very similar at that point
Mavic makes the best adapter ring, It snaps into place.. but USA division does not import them
so You have to DIY import .. SJS cycle in UK has them .. stock item #3335
some presta ring nuts now come wider with a flange to center them in the bigger hole
if i had different valves on my wheels i wouldn't be able to sleep at night.
you wanna lie awake in your tent all night worrying about mismatched valvestems?
just get the darn bushing. or drill the other rim for shraeder.
just get it done.
i'm staying up at night worrying about your non-matching tubes.
just get it done.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
I had a failure of a Presta tube in a Schrader rim once. It occurred as I was pulling the snug-fitting pump head off from the valve stem, and I must have cut the tube on the edge of the drilling. Fortunately, I was in my garage at the time, so I wasn't stranded. I don't have any mis-matched tubes & rims anymore, but I'd use one of the proper adapters if I did.
Bikes: 1985 Trek 620, Bianchi Volpe, Pake Rum Runner, Raleigh Twenty, Fuji Saratoga
I used to work as a mechanic and I saw quite a few long valve presta tubes where the tube and valve had separated. I believe most of the time this was from repetitive stress of using a hand pump to inflate the tire with the valve wiggling around a lot.
I am not sure I know what size to get. I suppose that if we had a caliper I could figure it out. Or I suppose I can find specifications for the relevant sizes of Presta and Schrader valve stem diameters.
Every day a winding road
I bought them when I switched my new Trek from Schrader to Presta. Stuck them in my drawer and they were there for years till I sold the bike. Stuck them in an envelope for the new owner to stick in his drawer.
Edit: Wait. A five year old thread??! What the heck are you doing newbie? The OP is likely long gone.
Liked 1,476 Times
Yeah, I noticed that I had commented five years ago.
I had a thorn resistant tube (extra thick rubber) and presta valve. The Wheels Manufacturing adapter that I had in the rim might have caused the puncture that I got very close to the presta valve. The tube was quite thick but was very very thin close to the valve stem. I plan to switch to Mavic presta adapters when I change tubes on wheels where I have these adapters installed.
https://www.sjscycles.co.uk/rims-tap...eder-to-presta
I was placing an order with SJS already so I bought several from them, but if you are in USA there probably are cheaper ways to buy these, maybe from a local bike shop?
Wrapping electrical tape around a presta valve would probably produce a very similar result too.
I bought a Slime extra-thick Presta tube from a vendor in eBay and after a while the stem popped off. Since it was in a rim with a hole that Schrader fits through, that might have contributed to the failure. I bought Schrader from an eBay vendor (probably the same vendor) to replace it and it also broke at the stem. I heard that Slime had a bad batch and that might have been the main reason for the failures.
Yes, I am in California and there are more than 8 bike shops relatively close by. I hope to be able to go talk with some of them. I have been having really bad luck with flats with a variety of causes.
If you've got 8 bike shops nearby, then surely you can easily obtain an adapter. It fits into the Schrader hole. They're not hard to find. There should be no need for you to mess around with tape or grommets.
