Which Disc Brake Adapter
Quoted: 2026 Post(s)
Liked 1,096 Times
Your fork appears to use a "flat mount" caliper and the Spyke (now discontinued it seems) used a post mount so your fork is incompatible with them. Also, flat mounts are limited to 160mm rotors so your 180mm rotors won't work either.
Adapters for flat mount brakes like the TRP Spyre are readily available and shown on the TRP web site.
Quoted: 184 Post(s)
Liked 67 Times
It probably isn't recommended to use a 180mm rotor on that fork.
If you really wanted to do it, you could attach a P20 (160 to 180mm) post mount to post mount adapter onto the 160mm flat mount to post mount adapter.
FM to PM: https://trpcycling.com/product/flat-...mount-adapter/
PM to PM: https://trpcycling.com/product/new-p...otor-adapters/
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
The back and front brakes run the same TRP caliper. The rear rotor is 160. Could I order a 160 rotor and run it with that 160 flat to post adapter?
Likes For Paul Barnard:
