Wet weather bike shoe solutions for Wide feet?
Old 11-03-22, 11:17 PM
AJW2W11E
Quoted: 229 Post(s)
Liked 110 Times in 50 Posts
Went out yesterday in the cold rain here in Seattle for two hours and came back with numb feet. My sneakers and socks were soaked and I had to get them into warm water quickly. I tried shoe covers last year but couldn't get them on my wide feet. It's only November, and I'm concerned.Does anyone know about waterproof shoe covers or some other solution for wide feet Could someone get frostbite from riding like this?
AJW2W11E is offline
Old 11-04-22, 03:55 AM
Tony Marley
Bikes: Catrike 700; Bike Friday Llama single; Bike Friday Tandem Tuesday; Easy Racers Ti-Rush recumbent; Catrike Expedition; Rans Seavo tandem
Quoted: 28 Post(s)
Liked 43 Times in 29 Posts
You could wear neoprene socks. They won't keep your shoes dry, but they keep your feet warm.
Tony Marley is offline
Old 11-04-22, 06:43 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times in 267 Posts
Ther are also Gortex socks. I’ve not used the. But others swear by them. Cheap option are plastic bags used for bread over your socks. I’ve used these before.
biker128pedal is offline
Old 11-04-22, 06:55 AM
GhostRider62
Quoted: 2333 Post(s)
Liked 2,097 Times in 1,314 Posts
Thicker wool socks with "clean room" booties slipped inside waterproof hiking shoes work pretty well.
Or, just move.
GhostRider62 is offline
Old 11-04-22, 06:58 AM
staehpj1
staehpj1's Avatar
Quoted: 1251 Post(s)
Liked 757 Times in 562 Posts
I find that shoe covers work well. The ones that are like wet suit material add a bit more warmth in really cold weather. Any I have tried fit over my very wide feet with cycling shoes. Are you looking for something that covers non cycling specific shoes?
How cold is the weather you need them for? I found when I was still iving up north I got by down below freezing even in wet weather with regular bike shoes with mesh for drainage and socks that didn't hold much moisture. For MTBing and trail running where there is less wind chill the problem is reduced and I could go quite a bit colder, but shoe covers are a good idea as a safety factor..
You mention sneakers, so maybe shoe covers aren't going to fit unless you wear either bike shoes or other less bulky shoes. If that is a non starter for you. maybe try the bread bags or neoprene socks.
staehpj1 is offline
Old 11-04-22, 07:20 AM
GhostRider62
Merino Seal Skinz socks are decent for up to a couple hours if temps are at least 40F......forgot to mention that. Bread bags too. Plastic bags from the grocery store work but only in states that haven't outlawed them
Old 11-04-22, 08:51 AM
prj71
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
Waterproof hiking boots. Then you can wear whatever socks you want.
Bread bags have the opposite effect. They hold in moisture/sweat from your feet making things worse. Not a good idea at all.
prj71 is offline
Likes For prj71:
Old 11-04-22, 09:00 AM
GhostRider62
Managing moisture in adverse conditions is not so simple. Vapor barriers have their use. They work and are cheap. Sealskinz are so-so but for shortish rides up to a couple of hours, your feet will be sort of warm and wet compared to cold and wet. A real barrier and your feet would be warm and eventually wet (perspiration)
Old 11-04-22, 09:56 AM
KerryIrons
Quoted: 506 Post(s)
Liked 639 Times in 357 Posts
Along with all the other advice offered here can we assume that you have good fenders and a mud flap in the front? Keeping all that road water from pouring into your shoes is a significant factor if you want to ride in the rain, particularly a cold rain.
KerryIrons is offline
Likes For KerryIrons:
Old 11-13-22, 05:52 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,585 Times in 2,344 Posts
haven't worn these in a downpour yet, but they're good for cold wet conditions. it is not a big heavy winter boot. it is lightweight
Columbia Men's Firecamp Boot Hiking Shoe
rumrunn6 is offline
Old 11-15-22, 04:45 AM
cjenrick
Quoted: 229 Post(s)
Liked 133 Times in 100 Posts
It don't matter what kind of shoes you wear. The problem is this. If your socks are exposed to moisture, that moisture, with the help of gravity and wicking action, will eventually end up at your toes.
Once your feet get wet your cooked. Because as soon as your feet get wet, they will get cold fast. As soon as they get cold, the body's natural reaction is to shut down blood circulation to keep you from freezing to death. Your blood will get cold if it circulates through cold tissue.
You can wear baggies or seal skins or whatever but if there is a quarter inch of your sock
exposed to moisture, the socks will still get soaked. This is even true if the socks are tucked completely under your tights. Because as soon as your tights get wet, your socks get wet These small details are very important for people who venture out in freezing weather. Extreme caution has to be taken to keep dry for people like Eskimos who are around water and other people who hike in the snow near running water or even puddles. Because once wet, you will need a heated house to get unwet. If no heated house or ability to light a fire, your dead.
What do I do on 50 mile nite rides in the freezing rains of Olympia Wa while out alone? (Who wants to ride in that crap)
I wear light socks. Thick and warm merino socks will cut of your circulation in the toe box. You want to have plenty of space to wiggle your toes around to keep the blood circulating because it is going to want to shut off from the cold. Next, wear a breathable running shoe. Waterproof shoes keep water in just as good as they keep water out. And your feet sweat slot. There are more sweat glands in your feet than any other part of your body.
So light socks, light breathable running shoes, and then I use a DIY gortex shoe cover that goes up to the mid calf area, thus, completely sealing off the shoes and socks. This gortex cover gets tucked underneath the tights.
I have tried everything else, and this is the only system that will keep your feet completely dry on a 3 hour ride in freezing rain.
For extra warmth on those extra harsh days,(32 degrees and sideways rain, I slip a goose down shoe cover on and then on goes the seamless gortex thingy that resembles a small pillow case with leather on the bottom to protect the fabric from the pedals.
I have horrible blood circulation in the extremities and thus a bomber system was required if I were to venture out in dismal conditions.
A showers pass rain jacket and pants are used when it is really coming down. REI fleece gloves along with gortex covers are used under these same conditions. Mitts are a hassle for turning on lights or changing wheels. That's right. I said wheel. Because I don't change tubes and hunt microscopic blackberry thorns in the tire in the middle of the night in freezing rain. I have a rear rack which holds a single speed wheel for which there is a thread on this forum which contains laughter from people who never ride 50 miles alone at night on rural bike paths in freezing downpours. By the time you change a tube and pump up your wheel, your natural 200 watt heater that has been shut down will leave you in a state of semi hypothermia as you try to mount your bike and ride off with your cramped up muscles.
Is my **** together or is my **** together?
Oh yeah don't forget to use a Big Blue AL1300NP diving light because there is nothing else that comes close.
cjenrick is offline
Likes For cjenrick:
Old 11-15-22, 05:23 AM
rumrunn6
rumrunn6's Avatar
yup was hiking w/ a girlfriend many years ago & she slipped & got wet in the snow. I made a trailside fire & dried her off before we continued back to my car
on another occasion, during a cold blizzard, my ski goggle fogged then the fog froze. wiping did nothing, just moved the frozen fog around. didn't want to scratch the lens so made a tiny fire & it all cleared rather quickly, just needed a little warm air. I've since removed the foam vent inserts so I get more airflow
no worries, of course I know how to extinguish a fire
rumrunn6 is offline
