One for the experienced Shimano component guys
Old 09-20-22, 07:41 AM
pingpong91
Hello,
I have an old Greg Lemond Zurich frame (the part carbon and part steel frame) which I bought second hand during lockdown in the UK, it was fitted with 105 groupset 5600 series (well the rear derailleur is, 10 speed and short caged)
My derailleur is now not playing nice and I think the spring has ceased up, as it is not springing back to its cocked position in some of the gears. This is causing my gears not shift correctly all the time, I am looking to remedy this issue.
I have spoke to a local cycle mechanic and he said he has a 105 10s RD-5701 derailleur ss which should be compatible with my current set up but I am not sure whether it will be, he had a little hesitation in his voice which could been brought on by a little uncertainty.
Is there any one out there who can confirm that this would work just fine? or know why it wouldn't work?
appreciate your time. BTW did try and search the forum but couldn't find the answers I was looking for.
pingpong91 is offline
Old 09-20-22, 07:57 AM
Troul
Troul's Avatar
Liked 2,971 Times in 1,918 Posts
Before swapping out the rear der, how old is the cable & housing? When you disconnect the cable at the der, does the der swing evenly & does the cable slide without any hang ups?
-Oh Hey!
Troul is offline
Old 09-20-22, 08:15 AM
pingpong91
Honestly mate, no idea - I am only a novice cyclist and definitely not brave enough to start tinkering the gear system. Why do you ask?
Old 09-20-22, 08:17 AM
pingpong91
to add to this, i think it might be the original groupset, so pretty old.
Old 09-20-22, 08:18 AM
big john
big john's Avatar
Quoted: 8280 Post(s)
Liked 9,038 Times in 4,475 Posts
Because many shifting issues are related to the cable binding.
big john is online now
Likes For big john:
Old 09-20-22, 08:21 AM
big john
big john's Avatar
Shift to the smallest cog, take the rear wheel out, and push the derailleur in with your hand. Or pull the cable and see what happens.
Old 09-20-22, 08:30 AM
wheelreason
Quoted: 501 Post(s)
Liked 626 Times in 370 Posts
As others have said, I would check the cable (in addition to the shifter), and the action on the dlr itself. Sounds like the b screw may be off, changed the cassette to a different range maybe?
But yes, 5701 will work with your shifters (assuming they are compatible with your current dlr).
wheelreason is offline
Likes For wheelreason:
Old 09-20-22, 08:43 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
If your mechanic hesitated, it's probably because they were talking to you off the top of their head without researching it. It's not like all of us can remember instantly everything we ever have seen or knew.
You could always just ask them to verify the compatibility and show you. In the 2010-2011 compatibility archive they show the RD-5700 compatible with ST-5600 shifters if those are what you have.
https://productinfo.shimano.com/down...ibility_en.pdf
5701 came out in a following year. And the 5600 stuff disappeared in the meantime from documentation as they were no longer made. However you can infer that the 5701 will work with your 5600 stuff. Your only concern might be that the 5701 DR specs for front max difference and the largest rear cog are within what your bike is. However it likely is okay, unless you've put a cassette on it with a really big tooth count low cog.
Iride01 is offline
Old 09-20-22, 08:48 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Does this mean that the upper pivot spring is not consistently pulling the derailleur body back? This can be caused by a broken or disengaged upper pivot spring, but I would expect the problem to manifest in all gears, not just some. Can you remove the chain and assess how the upper pivot spring behaves on its own? If the spring does not pull the derailleur body back when the chain is removed, it is either broken or disengaged. The simplest fix is to replace the derailleur. If the spring works, but the pivot binds in some places, it may just need a thorough cleaning and lubrication.
JohnDThompson is offline
Old 09-20-22, 09:04 AM
pingpong91
Exactly what it is, it does happen in a lot of gears but really noticeable in highest ring. I took it to a local shop prior to speaking to this guy who showed me what you've explained. they attempted a clean and lubrication and got it playing a little better but still not perfect. They suggested a new RD and whilst I was at it perhaps consider moving to Tiagra GS (minus the breaks) as in their opinion a new Tiagra gearing system would be more proficient than my old 5600 105.. as i am not an expert i really have to take their advice as true. however i spoke to this other independant guy who said he doesn't see why the 5701 wouldn't work, i wouldn't get the extra range from the new 10 speed crankset i was looking at but it's obviously cheaper to change one part than loads of it and his 2 pence was that you're still downgrading from 105 to tiagra whatever the year so his suggestion would be replace the RD with the 105 RD.. thoughts?
Old 09-20-22, 09:07 AM
pingpong91
Hi mate, I wasn't criticizing him I just don't know him so wasn't sure if uncertainty meant perhaps a lack of knowledge around the compatibility side. As I don't have the knowledge its hard to know what the best route to take is
Old 09-20-22, 09:28 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Use the 'quote' function when replying to specific posts.
cxwrench is offline
Old 09-20-22, 10:38 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
My guess would also be that it's the cable rather than the RD, especially since from what's been posted that hasn't been tested. The fact that lube helped some means that the bike hasn't been well maintained. Many riders change their cables and housing every year, just preventative maintenance.
Results matter
Carbonfiberboy is offline
Old 09-20-22, 12:29 PM
Bald Paul
Bald Paul's Avatar
Quoted: 821 Post(s)
Liked 1,655 Times in 782 Posts
Why not just ask him to check the bike over? It would be foolish to purchase a new RD, only to find out it was a bad cable/housing, or just that the RD mech was gummed up with old oil and dirt.
Bald Paul is offline
Old 09-20-22, 01:07 PM
tFUnK
Quoted: 430 Post(s)
Liked 460 Times in 318 Posts
As far as compatibility, that one has been answered - yes.
As far as old 105 vs new Tiagra, new Tiagra is probably better but psychologically it feels weird.
But the real question is what other work/tune up has been done? Sure you can replace the RD but what if it still shifts poorly? Now you've got re-do all the cables (my suggestion) anyway but you could have done that part first before deciding that a new RD was needed. If it were me, I would go for brand new cables and housing, clean up my FD and RD by taking them off, rinsing or ultrasonic clean them, and then put things together. With fresh cables and after a thorough clean it should be obvious if the parts are working as expected or if they need to be replaced. If you're lazy about the cleaning part, or if it's simply cheaper to get new RD, then I understand.
tFUnK is offline
Likes For tFUnK:
