Suntour versus Campy
#76
Quoted: 2323 Post(s)
Liked 4,988 Times
One thing that can’t be ignored in this discussion is technique. If the rider just moves the shift lever in one direction or the other to change gears and stops moving the lever when the shift is complete, rear derailleurs like the SunTour do a better job as they complete the shift earlier in the movement. Savvy riders with derailleurs like a Camp Nuovo or Super Record learned that if you made a quick motion with the lever to overshift a bit and pull back that the derailleur would make a very clean and fast shift. You learn very quickly how much motion is needed….It is similar to cracking a whip but less exaggerated. In racing it was pretty important to master the skill. Of course some people just couldn’t get the technique down and for them there was SunTour and Shimano…..
So you're saying that a rider that figured out how to compensate for an imprecise, inadequate shifting system was superior to a rider who shifted a precise, fully adequate one?
Steel is real...and comfy.
Likes For jamesdak:
#77
Quoted: 3511 Post(s)
Liked 2,926 Times
#78
Quoted: 1607 Post(s)
Liked 2,216 Times
C'mon guys, it isn't about size or quantity! It is about knowledge, skills and ability, with adequate funding! Significant innovation is often found with an individual. Rarely are committees become innovative. Teams, of any size can produce innovative ideas but they too are rare. IMHO innovation often is coupled with system thinking skills.
#79
Quoted: 767 Post(s)
Liked 1,898 Times
Rest and Relaxation department?
You know, it is possible to enjoy all of it.
And if indexed shifting really is a benchmark of technological success, well, that was achieved decades before Shimano.
Sturmey-Archer for the win.
Likes For BFisher:
#80
Quoted: 702 Post(s)
Liked 672 Times
#82
Liked 4,988 Times
#83
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
For professionals it’s all about winning. Winning is about training and putting in ungodly amounts of miles. If you have not put in the miles you will not be at the finish. No amount of fast shifting makes up for that. With Campy, athletes had the confidence to go mile after mile in sun, rain, dirt and muck.
For the rest of us on our local club ride, Suntour works just fine and dandy.
Likes For embankmentlb:
#84
Quoted: 702 Post(s)
Liked 672 Times
#85
Liked 4,988 Times
#86
Liked 4,988 Times
Likes For jamesdak:
#87
Quoted: 2482 Post(s)
Liked 2,955 Times
One difference I seem to remember from my days working as a bike mechanic in the '70s was that all the Campy rear derailleurs used solid bushing pins for the four pivot points whereas Suntour used folded-over sheet steel for most of the models, with the result that the Suntour derailleurs got sloppy over time.
The top-of-the-line Suntour derailleurs probably had solid pivot pins, though, since they were such exact copies of the Campy parts, at least for a while in the early days, many of the Suntour and Campy small parts were interchangeable.
#88
Liked 4,988 Times
Ironically from my small experience I've seen the opposite. The Victory RD on my 1985ish Colnago Super was a mess when I got it with the most play I've ever seen in any jockey wheels. Where as all the Suntour kits (at least a dozen VX, Sprint Cyclone, Superbe) have all been problem free.
Now in the spirit of putting all my kidding aside, the Victory setup worked like total crap when I got it. But once I tore it down completely, serviced it all, and then rebuilt and reinstalled it the drivetrain worked quite well. For the RD though, it was now running new aftermarket jockey wheels, modern cable and housing, a new chain, and shifting over a modern 8 speed cassette. In this configuration it was precise and accurate with no need to overshift and then adjust back. Still lacked the sexy feel of my Superbe stuff but perfectly fine for use in my opinion. I would expect the higher end stuff to be better and more ALMOST the equal to Superbe. LOL, sorry Campy guys...... I just can't help myself.
#90
Quoted: 702 Post(s)
Liked 672 Times
#91
Liked 4,988 Times
#92
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Dad wasn't wrong. Suntour Cyclone and Superbe friction shifting is a miracle of the universe - but then that's also true for just about any friction system using slant parallelogram derailleurs.
Campagnolo Nuovo/Super Record friction shift quality is heavy, clunky and prone to requiring large amounts of over-shifting and trimming. The rear mech uses a simple parallelogram design, with robust pivots, so the accuracy will never be as good, even with corncob freewheels.
Doesn't matter. NR/SR rear mechs will keep working a thousand years from now.
Likes For kunsunoke:
#93
Quoted: 702 Post(s)
Liked 672 Times
#94
Quoted: 2588 Post(s)
Liked 4,824 Times
When I read some of this stuff, I have to wonder if a lot of Campy detractors have ever shifted a properly-adjusted NR or SR derailleur across a straight block - or even one with a one/two tooth jump between cogs. Because I never have any of the shifting issues called out in this thread and others like it. A user asking a racing derailleur to perform outside its range doesn't make it a bad product, it just means the end user is clueless about its intended use and the restrictions upon it due to that use.
Sloppy shifting? Far from it. Mine are, to a derailleur, precise and solid. I don't cross-chain, I regularly re-tension the cable, re-check the upper and lower limit settings, and keep the pivots lubricated. Not just blowing smoke or blindly following the blind, either; as recently as July of 2020 I had a Suntour-equipped bike and was able to make some direct comparisons. Guess what? Based on performance (both shifting and braking), I went back to Campy. It was a beautiful bike, too, with black/silver anodized derailleurs and near-mint Superbe brakeset, but beauty isn't everything - because it's all about the performance for me. As a result, I went from this:
Back to this. Note the seatpost; a Nitto 65. Why not a Campy NR/SR? Because this is longer (more practical for fit), and the serrated cradles don't slip like those on a couple SR posts I've used:
Sold the parts and chalked up the experience to "interesting, but in the end, not an improvement". YMMV - but I do admit to wondering how much of this "Campy shifts like crap compared to Suntour" is based upon anecdotal rather than empirical data.
DD
DD
#95
Quoted: 3241 Post(s)
Liked 2,512 Times
Not in my experience. I'm strictly talking about Campy NR RDs. Give me any other RD please. In fact, if Simplex hadn't made the horrible decision with Delrin, they might still be around. At least their stuff worked........until it broke. The French high end stuff was/is as good as anything else out there.
#96
Liked 2,512 Times
On a side note, I've never understood the obsession with having a matching group on a bike. Most of the actual racing bikes I have bought have had a Franken bike component mix. The last one had:
Cinelli stem/bars
Suntour derailleurs
Campy hubs/Regina freewheel/Mavic tubulars
Simplex Retrofriction DT shifters
Sugino crank
If it's for dough, instead of for show, the performance, not the brand is really what matters.
Cinelli stem/bars
Suntour derailleurs
Sugino crank
Likes For seypat:
#97
Liked 4,988 Times
Likes For jamesdak:
#98
Liked 4,988 Times
Cinelli stem/bars
Suntour derailleurs
Sugino crank
If it's for dough, instead of for show, the performance not the brand is really what matters.
Cinelli stem/bars
Suntour derailleurs
Sugino crank
Likes For jamesdak:
#99
Liked 4,988 Times
DD
DD
But seriously, I have to admit I've never ridden the high end Campagnolo stuff from the same period as when Suntour was the best. I really should find something equipped with it and give it a try. If it truly does feel better to use than my beloved Superbe stuff that will make for one orgasmic ride. Dang it, I don't need another bike, but now I'm curious.....
Likes For jamesdak:
#100
Liked 2,512 Times
I think there's a lot of BS, brand snobbery, etc out there in the C & V world. For instance, most of my bikes have friction bar end shifters. I've got them in Simplex, Campy, Suntour and Shimano. The overwhelming favorite in the C & V community is Suntour. I wonder how many of these Suntour bar end fan boys despise Campy RD shifting? They both have the same type of feel. The Campy RDs are described as "heavy, clunky and slow," but the Suntour bar ends are great because of the dependability and "positive feedback." That's BS! Put them together and you have a bicycle that shifts like an 18 wheeler.
I apologize for the rant.
Likes For seypat:
