Is it N-M or Inch Pounds?
In the attached chart, the torque numbers are supposed to be N-M. However 12 N-m is approximately 106 inch pounds, which is a higher torque than the lug nuts on my car! I called Shimano customer service and they were adamant that it is all N-m. Is there anyone on this site that can confirm? Thanks
Quoted: 366 Post(s)
Liked 276 Times
Ft-lbs are intuitive - one foot pound is the same as one pound at the end of a one foot lever (or wrench). Inch pounds are ridiculous, especially with fractional foot pounds. Often, inch pounds are used deceptively to advertise a 12x more impressive looking torque number than ft-lbs.
Also, a ft-lb is the same as a lb-ft, except it's not.
Really Old Senior Member
Likes For Bill Kapaun:
ignominious poltroon
Quoted: 2249 Post(s)
Liked 3,453 Times
The reason for this is that the cross or "vector" product is really a second-rank antisymmetric tensor; its pseudo-vector behavior is an artifact of 3D space.
To get back to Bob S's question:
The units seem most sensible if they are N x m.
Quoted: 366 Post(s)
Liked 276 Times
That's what makes it so weird. I believe that one is torque and the other is essentially resistance to torque. I would have to consult Google to get you a more scientific answer, but there really is a time and place to use one set of units or the other - even if they work out to the same thing.
and we use in-lb all the time. Did you know that the NEC has recommended torque values for almost every electrical fastener?
Quoted: 366 Post(s)
Liked 276 Times
Thirty inch pounds is exactly 2.5 foot pounds. Thirty-one inch pounds is really close to 2.6 foot pounds, and so on. I don't see the need for a special unit just for low values - it just confuses people in the middle-range values where 20 foot pounds is 240 inch pounds.
Mid range - yep. They all have their place
We have torque screwdrivers where the range is 5-20 in-lbs.....
And fasteners where the designer specified torque of a 1" A325 bolt requires a 600 ft-lb wrench and a 3:1 multiplier. Or a hydraulic wrench calibrated based on hydraulic pressure.
Quoted: 3515 Post(s)
Liked 2,930 Times
Glad we never needed torque wrenches in the shop.
