Gas pipe love and other depravities.
#126
Top Seeded Amateur
#127
Quoted: 2483 Post(s)
Liked 2,955 Times
"Third hand" tool. Holds the brake pads against the rim so that you can tighten the brake wire in the cable carrier at the appropriate height.
Likes For Trakhak:
#128
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
My Rudge uses the same system.
https://www.raleigh-katsaris.com/she...&subcat_id=203
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Likes For 1989Pre:
#129
Top Seeded Amateur
Likes For OldForerunner:
#130
Does any one remember "Halco"? I had one in the early 70s, Asian lugged frame, cotter cranks, not quite as well finished as my friend Raleigh Grand Prix but a nice bike for the price.
They were sold by the Woolco chain, so definitely a rebadged special.
A few years later I rode a borrowed Paris Sport, made me feel like I was the cannibal. Only to find out later they were parts bin junk like the halco.
#131
Quoted: 790 Post(s)
Liked 348 Times
I picked up this fine example of mid-70's gas pipe depravity today. Complete with the trifecta of depravities - turkey levers (marked LH and RH just in case you get confused), stem shifters, and horror of horrors a metal dork disc. Additional bonus, a bolt-on kickstand! What sealed the deal for me was the glitter vinyl wrapped combination chain lock that was so common BITD. Montgomery Ward 10 Speed
And by the way, the auxiliary brake levers, provided the brakes are set up well, are very nice to have when not down on the drops and just cruising around.
Likes For beng1:
#132
Quoted: 790 Post(s)
Liked 348 Times
I suppose there are all sorts of spring clamps that would do the same job in a pinch, but this design will not fall off if bumped.
Likes For beng1:
#133
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
I wonder if these were made by the Cleveland Welding Company, I think they were the ones who's own brand was Columbia. Huffy's seat-stays were attached below the seat-post differently than this, and the AMF ten-speeds I have seen also had a different treatment for the seat stays too. If you got a serial number off the bike it could be matched up with known manufacturers. My Huffy Scout is badged "Bluegrass", because it was sold through the Bluegrass chain of hardware stores, but it's serial number is a normal Huffy one, and dates it to 1973. I think your bike might be from around 1975 or a bit later going by a few of it's features.
Model number?
Serial number?
Another curiosity, this hole on the top of the BB. Looks like it may be threaded, so perhaps had a zerk fitting at one point?
#134
Quoted: 790 Post(s)
Liked 348 Times
There are 2 numbers on the left dropout, one probably a model number and the other a serial number. The one that might be the serial number is hard to read because of the crud and axle. I will get better pictures once I clean it up a little. Best guess at the serial number for now is E627289. It has Cherry branded brakes, a Huret FD and Shimano Eagle RD. Have not had a chance to clean the crud off the hubs to see what they are. The shifter and dork disc have the stylized "333" Shimano marking.
Likes For beng1:
#135
Quoted: 478 Post(s)
Liked 634 Times
I always wanted a proper 3rd hand tool like that but I use a small sliding wood clamp. It does fall off but if I were to make up some custom cauls that problem would go away. Makes MAFAC setup way easier (even if they are alloy!).
Likes For markk900:
#136
Liked 2,955 Times
For those who might be thinking about buying a 3rd hand tool, I suggest considering a 4th hand tool also. Park makes a version of that tool, among other manufacturers. The 4th hand tool is a bit awkward to use with centerpulls, but it's a great tool for adjusting sidepulls.
#137
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 599 Times
A "Favorit" of mine. NOT! This bike caused me a lot of pain after rebuilding and selling it during the pandemic. The rear wheel locked up tore up the hub and generally made a mess. I had to fix. the problem, so I fitted a set of cheap Alex wheels on it which I bought from a friend. Most of the parts were Czech specific. I wish I had kept the saddle. At least I got to use the green mudguards I purchased years before.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
#138
Quoted: 790 Post(s)
Liked 348 Times
There used to be a dealer in my town that sold the Favorit bikes, along with Czech made motorcycles, for a while forty odd years ago I worked for them. A friend of mine bought a higher-end Favorit racing bicycle back in the 70s from that shop and he still has it in mint condition. His is a higher-end piece though, it even came with sew-up tires, so definitely not a "gas-pipe" bike.
#140
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
I just found this Marukin from Japan. I don't know the year, but the components look like early 1970s. The freewheel and chain are frozen and there is a lot of surface rust on the many steel parts, so I will be swapping things out for alloy as I make it road ready.
It ticks all the boxes:
Gas pipe frame - check
Steel wheels - check
Stem shifters - check
Turkey levers - check
Dorc discs - check
Shorty fenders/splash guards - check
I just need to mount up a Pletscher rear rack.
Dorc discs - check
Likes For Pompiere:
#141
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 855 Times
Nothing wrong with basic steel, whether electroforge welded or lugged and brazed... I love old Schwinn and Raleigh 3 speeds, most of which are nothing exotic in terms of material.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
#142
Quoted: 3812 Post(s)
Liked 3,341 Times
Dorc discs - check
Dorc discs - check
thanks for sharing this
be aware that the machine's Sakae Ringyo Silstar chainset likely exhibits the odd three degree taper
if spindle pitted you may need a spot of searching to find the 68F/3F/5F replacement...
#143
Quoted: 637 Post(s)
Liked 1,287 Times
OOH Baby ............and wing nuts on the axles too! That is classic Bike Boom. We'll need "after" pics of this one.
Dorc discs - check
Dorc discs - check
#144
Quoted: 531 Post(s)
Liked 1,005 Times
#145
Quoted: 790 Post(s)
Liked 348 Times
Wow, check out this Bruce Jenner edition AMF road bike that was for sale on Facebook Marketplace. As far as gaspipe depravity goes it is hard to beat. This has to be a super-rare machine to find intact like this, unfortunately, or maybe fortunately, it was about six hours drive away from me so could not jump on it. I hope it found or finds a good loving home.
Likes For beng1:
#146
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 122 Post(s)
Liked 222 Times
Freakin' luv it!
Likes For HelpSingularity:
#147
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
^^ I would convert it to a step-through frame. haha
