Rails got knocked out of saddle
Last night I fell off my bike, there was no real damage except that the bike seat popped off the rails. Does anyone know how to put the rails back in, do i need to take it to a shop, or just buy a new seat?
I'd rather not buy a new seat because I just bought this bike a month ago.
Any help would be appreciated, thanks.
A little North of Hell
Quoted: 71 Post(s)
Selle Italia? ProNet
Selle Italia: ProNet
The rail popped out of the saddle. Can I fix it?
The rail can pop out of the saddle if it's hit hard enough; the base flexes one way and the rail another. Don't try to reinsert the rail yourself. It takes a special tool to do this right. Send your saddle to the address below and we'll inspect it and re-insert the rail if the saddle is still sound. The charges are as follows:
Rail popped completely out - $4.50 postage only;
Rail popped out on one side - $15 plus $4. 50 postage (the rail has to be cut and replaced);
Rail bent or broken - $15 plus $ 4.50 postage;
Replace rail with tubular titanium rail - $30 plus$4.50 postage.
Don't send any money! But do send your snail mail address and email address. We will repair the saddle (if possible), return it and include a letter indicating the amount owed. Cyclists are honest (mostly)!
ProNet, Inc.
910 N Cambrian Avenue
Bremerton WA 98312
phone +1-360-782-2477
Toll free 800 279-3793
fax +1-360-782-2479
info@ProNetCycling.com
ProNet, Inc.
Bremerton WA 98312
fax +1-360-782-2479
+++ NO COURIER
Same thing happened to me in exactly the same way -- the no-name saddle that came with brand-new bike popped apart on its second ride. LBS where I bought the bike replaced the saddle for free. The replacement saddle lasted ten years.
Bikes: 2004 Cervelo R2.5, 2003 Litespeed Capella, 2002 Cannondale R2000si
The rails popped out of the stock saddle on my brand new Cannondale R2000si in a 80km charity ride a few years ago for no apparent reason. Took about half an hour for the local boy scouts to pop the rails back in - and only after bending the base of the saddle on a wire security fence to get the leverage needed. It was only my second ride ever on this bike.
Took the saddle back to the bike shop to get it replaced stating that it was a faulty saddle. I was told by the bike shop that the rails would NEVER pop out without considerable force and they refused to acknowledge responsibility or replace with a brand new saddle, only with a well used 1lb comfort saddle. Needless to say, I have not since been back to this bike shop.
I actually just took the saddle back to the bike shop where I had bought my bike. The guy was nice about it, took the seat into the back and had the rails back in the saddle in about 15 minutes at no charge.
Likes For frigidformself:
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Old thread, but thought I'd share...
After boiling the saddle for about five minutes was able to soften the plastic lip on my seat enough to bend it up, slide the rail nose in, and then bend it back down. Held it with the channel locks until it cooled, and it appears to be good as new:
Likes For Bwanna:
Likes For Soil_Sampler:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Quoted: 4806 Post(s)
Liked 3,929 Times
@veganbikes, why the hatred of old threads with good info in them being dredged up? I've never see anything on what to do with popped rails. I haven't done it yet so it hasn't mattered to me but I appreciate learning what I never would have seen if kokyman hadn't revived this. If I ever pop a rail, I now know what to look for and a couple of sources that may be out of business now but who might be able to steer me elsewhere.
Likes For 79pmooney:
Clark W. Griswold
Liked 3,994 Times
Quoted: 1858 Post(s)
Liked 664 Times
Because there is just no need to dredge up old threads unless to read them which can easily be done by searching either here or sometimes the googles does it as well. If the thread was still active it would make sense but it died in 2007. Yes the info is fine but the info would still be fine if it was left alone because in the end there are probably hundreds or thousands of threads with excellent information that would bury current discussion or make BF unusable with all the stickies.
Quoted: 4208 Post(s)
Liked 3,874 Times
The dislike of old threads has always seemed a bit narrowminded IMO. Something about failure to learn from the past and being doomed to repeat mistakes.
I've dealt with a number of these "popped rails" situations and have less then good results in fixing them. A few of the ones that I managed to reseat have repopped in time. On a few tries the rails bent, on others I gave up. Andy
AndrewRStewart
AndrewRStewart
Clark W. Griswold
Liked 3,994 Times
Y'all have a good night
Quoted: 569 Post(s)
Liked 583 Times
I suspect kokyman and other new posters could feel pounced upon and search out more relaxed/accepting forums.
Liked 664 Times
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I see this all too often. New members dredge old threads - that's how Google works, it directs them to these threads. Then old-timers dogpile on the newbie for reviving an ancient thread. On the other side of the coin, if a newbie starts a new thread, old-timers dogpile for not using the search function. Damned if you do, damned if you don't!
Likes For Lombard:
Liked 664 Times
I'm not a newbie. I just like to see people find what they need.
Clark W. Griswold
Liked 3,994 Times
