Park Tool PCS 4.1 - Clamp spins
Liked 5 Times
I got a new PCS 4.1 from Amazon yesterday and noticed that the clamp seems to bottom out when screwing to the top tube assembly before it makes full contact. This means that the clamp is free to rotate and cannot never lock it, so the bikes just swing freely. I have used the tapered sleeve for 100-5C as per manual.
I have a youtube video with demonstration, but since I am a new user can't seem to paste the link. The video id is v0N2czs5AaA
Anyone else faced this problem? Any known solutions? I can always send it back to Amazon, but disassembling it again and then ordering a new one and assembling is a bit of a pain.
Quoted: 6195 Post(s)
Liked 4,810 Times
This one?
I don't have an answer. Others probably do. Since it's new, you did put in a question to Park Tool didn't you?
Liked 5 Times
Update: Can't believe how fast Park Tool support is. They already replied and said the problem is with most probably with the top tube assembly, and they will send a replacement at no cost. Amazing
Likes For stavstav:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Yes, they are, I also have had great experiences with their customer support team
Quoted: 838 Post(s)
Liked 1,061 Times
I don't always buy Park tools but their service has swayed me a couple of times. I bought one of their PC-10 stands due to the fact that it's built like a tank, spares are available and great service. It cost more but I will not likely ever have to replace it unlike my last cheapy stand.
Likes For Crankycrank:
Sr Member on Sr bikes
If it’s similar to the Park PCS-1 (which I have)...right behind the clamp handle where the tension spring connects to it...there is a finger bolt that connects the spring to the clamp. There are three different holes that can be used to connect the spring/handle for various sizes of top tubes. Edited to add: Looking at the videos on Park’s website...it looks like the 4.1 comes with one of two different clamps. But, both are adjustable to accommodate various tube sizes.
Dan
Dan
Liked 5 Times
Dan
Dan
Thanks for your reply. Yeah, 4.1 has just one hole for the clamp and depending which clamp you use, you may need to add a shim or not. I added the shim, but still looks like it is bottoming out before it's tight enough. I suspect the screw in the top assembly where the clamp screws into, is too long. Will get the new on that Park sent and compare and update.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I got my first stand which is an old school PCS-4 (or some older variant thereof) used from a friend and it has been fantastic for what it is and only needed a little polylube after 20+ years of service.. Just added a PRS-25 because I want a better clamp for larger than 27.2 and a bit better adjustability so I can raise or lower the stand. So I the other stand might get sold or maybe donated but it is a true workhorse and looks great hanging my vintage bikes.
Hey Dan,
Dan
So, I bought the same stand, brand new from Amazon, and the bolt bottoms out before it is tight enough so that the clamp spins, as you describe. I took it on and off four times, and I think the bolt in the head is too long such that it never tightens the conical sleeve part in the head. Sigh.
I guess I will call Park Tool tomorrow.
Did you resolve your problem with a new head or some other way?
Thanks!
Larry
Thanks!
Larry
Following up to my question. I called Park Tool and they said it was a known issue and would be shipping me a new head today.
I went crazy trying to figure out what I was doing wrong, lol.
Larry
Larry
Likes For LarryRider:
